HSBezel
knewlife
index.php?app=downloads&module=display&s
File Name: HSBezel
File Submitter: knewlife
File Submitted: 06 May 2015
File Category: Artwork tools
Credits: knewlife
Lets you create a bezel for Hyperspin when using it in Non 4:3 Resolutions.
UPDATE: NOW YOU CAN EDIT THE INI FILE INCLUDED TO RUN APPS, THE APP ALSO HIDE THE MOUSE CURSOR (can be disabled by ini setting: 1 enabled, 0 disabled)
CTRL+ALT+H SHows hide cursor.
How to use:
1- Set in HyperHQ hyperspin to use WIndow mode in 1024x768 resolution.
2- Set your monitor resolution to something like 1280x768 or 1360x768, you can set something like FULL HD resolutions but hyperspin is not designed to run like that.
3- Create a HSBezel1280x768.png file (change the number with your resolution values) whit the left and right bars... the center should be transparent.
You can use the ones included here as model.
4- Launch HSBEZEL.exe... this will launch hyperspin and keep runing in the background.
Every time HS Window is active AND the position of the window or the bezel has changed they will be centered again.
This normally happens when enter an application that changes monitor resolution. This problem dont exist when runing HS in full screen,
but remember we are in Window mode here.
5- You can compile the app again to include all the app you normally run before hyperspin... its not so hard: http://hyperspin-fe.com/oldsite/index.php?option=com_content&view=article&id=97&Itemid=108
PD: Sorry for my english again XD
  • Replies 60
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
I'm trying to get this running but cant seem to get it to work. I have the HsBezel folder in my hyperspin folder and have renamed the bezel file that matches my resoloution. What am I doing wrong?
Edit: Got it all figured out :)
Check out my MAME Arcade classics themes
  • 4 weeks later...
hello knewlife, I would like to use your wheel with clone, TV and PC
Can you show me how you do it?
I see your auto boot can you show me how you're doing that?
Thanks!
Thanks!
Search for "shelled hyperspin" on google. For the change screens features I have to search in my backup as I don't use it the same way
Hola es buenismo este codigo
tambien soy de argentina jcpaz.... por eso te escribo en castellano
quisiera enterder un poco mas este codigo...
yo por ejemplo uso un programa que se llama irocker dentro del hyperspin pero no soporta resolucion 1920x1080 lo que hice es centrarlo con nircmd pero me quedan amplios bezel en negro.
por lo que comentas podria utilizarlo para ponerle unas lindas imagenes.
me podrias ayudar...
no logro entender bien el proceso en ingles.
gracias genio.
(Don't Know if this already exists... anyway...)
How to use:
3- Copy HyperBezel Files to your HyperSpin directory. Create a HSBACKGROUND1280x768.png file (change the number with your resolution values) with the left and right bars... the center should be transparent. You can use the ones included whit the app as model.
4- Launch HSBezel.exe... this will launch hyperspin and keep runing in the background.
5- You can compile the app again to launch all the apps you normally run before hyperspin... its not so hard: http://hyperspin-fe.com/oldsite/index.php?option=com_content&view=article&id=97&Itemid=108
Just fallow the examples on the code.
basically:
Run, YOur\app.exe
Run, YOur\app.exe
etc...
UPDATE: NOW YOU CAN EDIT THE INI FILE INCLUDED TO RUN APPS, HS ALSO HIDE THE MOUSE CURSOR (can be disabled by ini setting: 1 enabled, 0 disabled) CTRL+ALT+H Shows hide cursor.
Find it my Upload Here Folder at the FTP or DOWNLOAD HERE.
PD.: This is the first version that really works for me, please test it and let me know if you have any problem.
A little Video (This include just the bezel for HS, ask if you like other things in my setup, also i forgot to disable mouse pointer... still making change to my setup :) )
EDIT: Little update with some changes and renamed to HSBezel
EDIT: New Version 18-04-2014
EDIT: Added new alternative bezel art. DOWNLOAD
[ATTACH=CONFIG]40823[/ATTACH][ATTACH=CONFIG]40824[/ATTACH]
Very nice Thank you,
I try to change with Windows 7 Boot Updater but it's not working with EFI disk ...
Windows 7 Boot Updater is exactly what i use so i can not help you so much in that case. In the screens thing i have a set of exe files that call dysplayswitch. A native windows app that change the displays. I will upload t exes here and the database that is just the exes names. Then you can create a new system in hyperhq and call it something like 'change screens' user the database and configure in hyperhq the system to launch the exes directly as PC games (exe files) all this without the usage of hyperlaunch, all native Hs commands. The bezel script should take care of center the hyperspin window position.
Here https://www.dropbox.com/s/0z5vn2xtisgs7fo/DisplaySwitch.zip?dl=0
Screenshot of HyperHQ: https://www.dropbox.com/s/zxobt13fs9qdmat/Captura%20de%20pantalla%202014-09-04%2014.24.10.png?dl=0
gracias genio.
Buenas Como estas. No conosco esos programas pero el código lo mas complicado que tiene es la parte de dibujar la imagen en pantalla usando gdi. Que supongo que es la parte del código que quisieras usar... Si puedo te la separo del resto y te lo paso por acá saludos
Este es el codigo que muestra una imagen:
			img := A_ScriptDir . "\HSBezel\HSBezel_" . A_ScreenWidth . "x" . A_ScreenHeight . ".png"   ;ESTE ES EL NOMBRE DEL ARCHIVO DE IMAGEN
		;If the image dont exists... skip all this...
		if( FileExist(img) )
			; Start gdi+
			If !pToken := Gdip_Startup()
				MsgBox, 48, gdiplus error!, Gdiplus failed to start. Please ensure you have gdiplus on your system
				ExitApp
			; Create a layered window (+E0x80000 : must be used for UpdateLayeredWindow to work!) that is always on top (+AlwaysOnTop), has no taskbar entry or caption
			Gui, 1: -Caption +E0x80000 +LastFound +ToolWindow +OwnDialogs
			; Show the window
			Gui, 1: Show, NA
			; Get a handle to this window we have created in order to update it later
			hwnd1 := WinExist()
			; Get a bitmap from the image
			pBitmap := Gdip_CreateBitmapFromFile(img)
			;MsgBox, 48, File loading error!, % A_ScriptDir . "\HyperBezel\HSBACKGROUND" . A_ScreenWidth . "x" . A_ScreenHeight . ".png"
			; Check to ensure we actually got a bitmap from the file, in case the file was corrupt or some other error occured
			If !pBitmap
				MsgBox, 48, File loading error!, Could not load the image specified
				ExitApp
			; Get the width and height of the bitmap we have just created from the file
			; This will be the dimensions that the file is
			Width := Gdip_GetImageWidth(pBitmap), Height := Gdip_GetImageHeight(pBitmap)
			; Create a gdi bitmap with width and height of what we are going to draw into it. This is the entire drawing area for everything
			; We are creating this "canvas" at half the size of the actual image
			; We are halving it because we want the image to show in a gui on the screen at half its dimensions
			hbm := CreateDIBSection(Width, Height)
			; Get a device context compatible with the screen
			hdc := CreateCompatibleDC()
			; Select the bitmap into the device context
			obm := SelectObject(hdc, hbm)
			; Get a pointer to the graphics of the bitmap, for use with drawing functions
			G := Gdip_GraphicsFromHDC(hdc)
			; We do not need SmoothingMode as we did in previous examples for drawing an image
			; Instead we must set InterpolationMode. This specifies how a file will be resized (the quality of the resize)
			; Interpolation mode has been set to HighQualityBicubic = 7
			Gdip_SetInterpolationMode(G, 7)
			; DrawImage will draw the bitmap we took from the file into the graphics of the bitmap we created
			; We are wanting to draw the entire image, but at half its size
			; Coordinates are therefore taken from (0,0) of the source bitmap and also into the destination bitmap
			; The source height and width are specified, and also the destination width and height (half the original)
			; Gdip_DrawImage(pGraphics, pBitmap, dx, dy, dw, dh, sx, sy, sw, sh, Matrix)
			; d is for destination and s is for source. We will not talk about the matrix yet (this is for changing colours when drawing)
			Gdip_DrawImage(G, pBitmap, 0, 0, Width, Height, 0, 0, Width, Height)
			; Update the specified window we have created (hwnd1) with a handle to our bitmap (hdc), specifying the x,y,w,h we want it positioned on our screen
			; So this will position our gui at (0,0) with the Width and Height specified earlier (half of the original image)
			UpdateLayeredWindow(hwnd1, hdc, 0, 0, Width, Height)
			; Select the object back into the hdc
			SelectObject(hdc, obm)
			; Now the bitmap may be deleted
			DeleteObject(hbm)
			; Also the device context related to the bitmap may be deleted
			DeleteDC(hdc)
			; The graphics may now be deleted
			Gdip_DeleteGraphics(G)
			; The bitmap we made from the image may be deleted
			Gdip_DisposeImage(pBitmap)
			Sleep, 10000    ; ACA PONGO UNA ESPERA DE 10 SEGUNDOS PARA MOSTRAR LA IMAGEN, VAS A TENER QUE CAMBIAR ESTO.
ah ok... pero como lo utilizo....
te cuento
yo abro el hyperspin luego en la rueda selecciono el programa de rockola que es irocker.... este como no tiene la resolucion 1920x1080 abre en 1280x1024 por lo que me queda mal en la pantalla yo lo logre centrar con nirmcd.exe pero tu codigo me sirve para mejorarlo... lo que no entiendo aun es como.
donde asigno el irocoker.exe?
gracias
te cuento
gracias
Ahh ahora te entiendo pero para lo que queres hacer tenes que saber como programar porque esto esta armado para correr con hyperspin o tendria que bajarme el programa que me decis y programarlo yo pero ando sin tiempo ahora.
El script que hice esta programado para HyperSpin. Creo que te convendria mas usar las Bezels de HyperLaunch si es para otro programa lanzado desde hyperspin, usas hyperlaunch no?
si uso hyperlaunch. por lo que interpreto en tu codigo es puede asignar una aplicacion externa en el archivo ini..... es correcto?
[settings]
HideCursor=1
Run_1=irocker.exe
Nop porque solamente detecta hyperspin para ver si se esta ejecutando y centrarlo. Las demas apps las podes ejecutar pero son solo otras que necesites ejecutar junto con hyperspin. Usa un codigo muy especifico para detectar la ventana de Hyperspin y centrarla por eso te decia que si es para otra app hay que modificar el codigo.
If you have an UEFI Bios, is it possible anyway to change the boot logo. You have to reinstall Windows 7, but before you must change the boot option in the bios to "Legacy", something like that. Windows will be install in a "classic" mode, not in EFI mode ;)
ah ok entiendo. y reemplazando hyperspin.exe por otro exe modificando obviamente el ahk class? o tu podrias crear una app como esta pero que pueda por ejemplo centrar Mame u otro programa yo podria ayudarte en algunas cosas. que te parece?
en ese apartado mensionas que se pueden utilizar otras apps junto con hyperspin....... yo ejecuto irocker dentro de hyperspin. es posible entonces que pueda asignarle un bezel con tu programa.
Me refiero a apps tipo expadder que se ejcutan en segundo plano y si seria posible hacer un script que funcione con cualquier aplicación. En estos dias veo q puedo hacer.
ah ok perfecto.... si te sirve de ayuda para la creacion del script. hay un programa dentro de las carpetas modules extension de hyperlaunch que se llama nirmcd.exe y sirve para ejecutar muchas cosas lo bueno que se mantiene oculto y funciona a traves de archivos bat. con ese mismo programa cree un bat que inicio antes que se inicie el irocker.exe para que me redimensione la pantalla y lo que logre es centrarlo.. Si puedo ayudarte en algo hazmelo saber. gracias. aguardo novedades.
Gracias. Todo eso lo puedo hacer con ahk asi que no seria necesario a ver que me sale. Yo pienso que seria mejor hacer un modulo de hyperlaunch para el programa que me decis. Es mas creo que es mas coerente porque hyperlaunch ya tiene integrado soporte para bezels mmm me lo voy a bajar al programa a ver que sale. La cuestion es que queres tener un bezel al rededor del programa no importa mucho como no? jajaj
Como lo ejecutas actualmente. Con o sin hyperlaunch. Desde el menú principal o desde un sub menú-wheel?
