salyangel Posted September 6, 2014 Posted September 6, 2014 If you have an UEFI Bios, is it possible anyway to change the boot logo. You have to reinstall Windows 7, but before you must change the boot option in the bios to "Legacy", something like that. Windows will be install in a "classic" mode, not in EFI mode I use a hard disk 3 TO so I have to keep the EFI... thanks for your help
knewlife Posted September 7, 2014 Author Posted September 7, 2014 thank you so much!I have to do a choosing boot system or hyperspin How to do that with one Win 7? Just install 2 instances of windows in different partitions and that creates the boot menu for you. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
paulmichel21 Posted September 9, 2014 Posted September 9, 2014 hola, knewlife.... lo conseguiste al programa irocker 6?
knewlife Posted September 9, 2014 Author Posted September 9, 2014 Hola el setup me da un error asi q no lo puedo instalar en Windows 7, asi q no pude seguir. Hay una versión mas nueva? En que SO lo instalaste? Me podes pasar tu instalador? Sent from my Nokia Lumia 520 using Tapatalk EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
paulmichel21 Posted September 9, 2014 Posted September 9, 2014 Hola si, si yo lo instale en win 7 aqui encontre un link... sino cuando llego a mi casa lo subo y te lo paso https://mega.co.nz/#!2I4ywQ5B!lQEZEnpfSzjOqRisAxVjgSJuusm5lUnGwVWfGEA0KkM
knewlife Posted September 10, 2014 Author Posted September 10, 2014 hay lo descargo EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
paulmichel21 Posted September 10, 2014 Posted September 10, 2014 hola estuve probando tu programa mainmenuchanger pero nose porque me arroja error . me dice error al crear el main xml. te subo los xml. a ver si te das cuenta donde esta el error... https://drive.google.com/file/d/0B_c5xfTVlCWva3J6T0V1dlV0S00/edit?usp=sharing gracias
paulmichel21 Posted September 10, 2014 Posted September 10, 2014 el link del programa irocker que funciona con win 7
knewlife Posted September 10, 2014 Author Posted September 10, 2014 y aqui te paso el link del programa irocker que funciona con win 7 https://drive.google.com/file/d/0B_c5xfTVlCWvSTFxZGE1ZGkxeWs/edit?usp=sharing Ya lo instale. Simplemente modifique el skin para hacerlo 1920 x 1080. Llevo trabajo pero esta, te lo paso en unos minutos. Aqui esta es muy basica pero podes modificar el archivo de fondo dentro de la carpeta imágenes. Remplaza la carpeta de imagenes de tu instalacion de i-rocker, hace backup. lo pongo tambien en ingles para que sirva a alguien mas. IN English: Here you can download a 1920x1080 skin for i-rocker 6: https://www.dropbox.com/s/u4hi3i33i7dd8ar/Imagenes.zip?dl=0 EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
knewlife Posted September 10, 2014 Author Posted September 10, 2014 TU XML tiene un error, editalos con Notepad++ y te dice cuando tenes un error de estos: En lugar de: <game name="Android"/> <genre>Smartphone</genre> <year>2014</year> </game> Tiene que ser: <game name="Android"> <genre>Smartphone</genre> <year>2014</year> </game> ------------------------------------------------ In english: Hi I tested your program mainmenuchanger but do not know why throws me error. tells me error creating the main xml. I upload the xml. see if you realize where this error ... https://drive.google.com/file/d/0B_c...it?usp=sharing thank you The problem is the close of the game tag Yo do this: <game name="Android"/> <genre>Smartphone</genre> <year>2014</year> </game> This is OK: <game name="Android"> <genre>Smartphone</genre> <year>2014</year> </game> EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
paulmichel21 Posted September 10, 2014 Posted September 10, 2014 Mil gracias funciona perfecto en 1920x1080... en cuanto a otro programa ingresaba pero no podia volver a todas las opciones hasta que me di cuenta que hay que agregar en mainmenuchanger.xml la option a mainmenuchanger y listo. no viene por defecto. gracias por tu ayuda.... idolo
knewlife Posted September 10, 2014 Author Posted September 10, 2014 Mil gracias funciona perfecto en 1920x1080... en cuanto a otro programa ingresaba pero no podia volver a todas las opciones hasta que me di cuenta que hay que agregar en mainmenuchanger.xml la option a mainmenuchanger y listo. no viene por defecto. gracias por tu ayuda.... idolo Ahhh puede ser. Seria agregar mainmenuchanger en all.xml ? Edit: Cuakquier otra cosa abrimos un post en la section en español del foro para q no se nos enojen por aca EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
paulmichel21 Posted September 10, 2014 Posted September 10, 2014 Hay que agregarlo a mainmenucharger.xml como genre. lo ultimo sobre irocker, que codigo debo modificar para el album numero cinco? salen corridas las canciones el resto perfecto.... solucionado. ya modifique unos valores. ahora anda perfecto ok seria bueno... asi te hago unas consultas mas.... me posteas el link. asi lo sigo
Francislaremote Posted September 11, 2014 Posted September 11, 2014 This is very helpful ! Thank you ! I can enjoy HyperSpin on my widescreen TV without having all the nice arts stretched.
DIEx3 Posted October 1, 2014 Posted October 1, 2014 I found a bug in HSBezel_alt_cursor_hide: HideCursor works if it is 0, not if it is 1. So it is reversed. Thanks for the good work.
ninja2bceen Posted October 4, 2014 Posted October 4, 2014 Where did you get the dbz theme? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
knewlife Posted October 4, 2014 Author Posted October 4, 2014 Where did you get the dbz theme? Dont remember but I can upload it. I think it comes in a pack I downloaded some time ago. https://www.dropbox.com/s/icpw6dv9okqbhhw/Dragon%20Ball%20M.U.G.E.N%20Edition%202011.zip?dl=0 EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
damageinc86 Posted December 13, 2014 Posted December 13, 2014 My widescreen monitor is 1440x900 which puts hyperspin in the middle of the screen with area not only on the sides, but also on the top and bottom. So I made my own custom bezel that surrounds hyperspin window, and renamed it HSBezel_1440x900.png - hyberbezel doesn't display my bezel unfortunately. any idea why not? It worked before using your original bezel when i changed my desktop resolution to match your png resolution. ----------------- Nevermind again, put it in the right folder and then it worked!
knewlife Posted December 13, 2014 Author Posted December 13, 2014 My widescreen monitor is 1440x900 which puts hyperspin in the middle of the screen with area not only on the sides, but also on the top and bottom. So I made my own custom bezel that surrounds hyperspin window, and renamed it HSBezel_1440x900.png - hyberbezel doesn't display my bezel unfortunately. any idea why not?It worked before using your original bezel when i changed my desktop resolution to match your png resolution. ----------------- Nevermind again, put it in the right folder and then it worked! Great EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
knewlife Posted May 7, 2015 Author Posted May 7, 2015 File Name: HSBezel File Submitter: knewlife File Submitted: 06 May 2015 File Category: Artwork tools Credits: knewlife Lets you create a bezel for Hyperspin when using it in Non 4:3 Resolutions. http://www.hyperspin-fe.com/topic/2910-hyperbezel-show-two-images-at-the-sides-of-hyperspin-when-using-169-monitors/?hl=hsbezel UPDATE: NOW YOU CAN EDIT THE INI FILE INCLUDED TO RUN APPS, THE APP ALSO HIDE THE MOUSE CURSOR (can be disabled by ini setting: 1 enabled, 0 disabled) CTRL+ALT+H SHows hide cursor. How to use: 1- Set in HyperHQ hyperspin to use WIndow mode in 1024x768 resolution. 2- Set your monitor resolution to something like 1280x768 or 1360x768, you can set something like FULL HD resolutions but hyperspin is not designed to run like that. 3- Create a HSBezel1280x768.png file (change the number with your resolution values) whit the left and right bars... the center should be transparent. You can use the ones included here as model. 4- Launch HSBEZEL.exe... this will launch hyperspin and keep runing in the background. Every time HS Window is active AND the position of the window or the bezel has changed they will be centered again. This normally happens when enter an application that changes monitor resolution. This problem dont exist when runing HS in full screen, but remember we are in Window mode here. 5- You can compile the app again to include all the app you normally run before hyperspin... its not so hard: http://hyperspin-fe.com/oldsite/index.php?option=com_content&view=article&id=97&Itemid=108 UPDATE: NOW YOU CAN EDIT THE INI FILE INCLUDED TO RUN APPS, THE APP ALSO HIDE THE MOUSE CURSOR (can be disabled by ini setting: 1 enabled, 0 disabled) CTRL+ALT+H SHows hide cursor. PD: Sorry for my english again XD Click here to download this file EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
dekk Posted July 26, 2015 Posted July 26, 2015 Hi there! Awesome project this HSBezel but for some reason for me the mouse cursor is always hidden, no matter if I change hidecursor= in the .ini file or not. Any ideas? Using Windows 7 Pro 64.
ninja2bceen Posted October 18, 2015 Posted October 18, 2015 Dont remember but I can upload it. I think it comes in a pack I downloaded some time ago. https://www.dropbox.com/s/icpw6dv9okqbhhw/Dragon%20Ball%20M.U.G.E.N%20Edition%202011.zip?dl=0 just saw this a year later lol ty!Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
damageinc86 Posted December 12, 2015 Posted December 12, 2015 Downloaded the new version from may of 2015 and it doesn't even launch hyperspin now. Made the mistake of deleting the first version,...ugh. Any chance you could upload the first version? Or update this project again?
knewlife Posted December 15, 2015 Author Posted December 15, 2015 Downloaded the new version from may of 2015 and it doesn't even launch hyperspin now. Made the mistake of deleting the first version,...ugh. Any chance you could upload the first version? Or update this project again?This App as not changed in years I think... It just get uploaded again when hyperspin site changes... Gonna look at home what can be wrong as I'm now use a custom version of this app that does many other things in my setup.EDIT: The new version run apps from an ini file I think... You have edited the file? EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
knewlife Posted December 15, 2015 Author Posted December 15, 2015 Here is a new version that is working fine for me, please test it, and REMEMBER TO BACKUP YOUR OLD VERSION, FOLDERS, EVERITHING BEFORE TEST https://www.dropbox.com/s/ioiwruuj15g4veq/HSBezel2015-12-15.7z?dl=0 Changes: RandomBezel option in ini If RandomBezels=1 you can store more than one bezel file per resolution in HSBezel folder and the program will load them randomly. Beacuse of this, files must be named like this: HSBezel_1280x720_N.png (Where N must be a number from 1 to 10) Examples: HSBezel_1280x768_1.png HSBezel_1280x768_2.png Etc... If RandomBezels=0 bezel files must be named like this: HSBezel_1280x720_0.png (Note the final _0 before extension) I tested all this at 1980x1080 (screen) and 1440x1080 / 1280x1024 (hyperHQ) and works ok. To use 1280x1024 you must modify the bezel to cover the gap that HS left. In 1440x1080 it fits perfect with the included bezels. If someone knows how to update the app in HS downloads please tellme. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
