HLM - Minter Helper Checker Whatever 2.0.2
horseyhorsey
Lol. You make out like it's rocket science.
Right click on an image in viewer, menu pops up to create IC.
Your presets will show in this list.
Pick one and will convert & send to your bezels folder with correct naming.
So, if you make IC's from game manuals this is even easier once you've converted to images, right click , preset, send, done.
  • Replies 290
Scan system and add videos to prep list.
Choice to overlay wheel images on the video. For now if wheel is missing the video removed from list
        Set the position and size you want the wheel to appear (Need to add opacity option, set to 0.7)
    Use the scan format to check your sizes & framerates match. You could run into problems if not.
    If you want to convert after the script is done use AviDemux with avsproxy_gui. See Video...
You could try adding videos from other systems in one list, it may work.
https://www.youtube.com/watch?v=7A9X_yM64gc&feature=youtu.be
Added Multi System Generator:
    Go through any database in manager, right click and add to prep list
        Found in Tools > MultiSys
    Nit pick one by one or multiple select.
    or add all favourites from current system into prep list.
    List of systems merged into one xml and creates a default HS settings from an existing one you provide
    for the layout or text etc.
    Creates symbolic links for the media instead of duplicating assets. (only tested on Win8)
        Artwork 1-4, Themes, Videos, Wheels
    Creates default emulator.ini for RL and populates a games.ini for rom mapping to system.
    If the game doesn't have its own theme. Option to make a link from system default.zip theme.
    Todo:
     AddGenre generate. Systemtype.
With just a few clicks and you get a Multiple system menu with system/rom map in RL :canabis:
https://www.youtube.com/watch?v=HwarMcnLWdA&feature=youtu.be
Hi, I tried downloading a game video using the YouTube feature. This works great [emoji13]. However I thought you were able to trim the videos but I can't fathom that part...is it enabled yet?
Yeah, not in yet. Can do it fine after downloaded but I was trying to figure how to download a segment instead, but haven't dedicated much time to that. I can put the trim in later if you need it.
No probs...I have no idea how to do such a thing if you could implement I way of the program asking how long to trim and fade in the start and from ending it would be a great addition. Nice work though [emoji3]
Hi, been playing around with stuff and wondered if it was possible to run this over a network. Sometimes I use my main PC to do maintenance as it's more practical and more comfortable than my cab. My PC in my cab is networked. I can't seem to be able to run hyper mint on my main PC even though I've set my paths to hyperspin:
\\mamemachine\\j\hyperspin
I would love to be able to network this it would mean much more efficient work for me.
(That code did show backslashes!)
HM isn't seeing the HS folder even though I can access it from the PC no problem. It isn't loading the main menu systems or anything. [emoji53]
I'll have a look and try it with a remote share later. You probably could just map a network drive if you need it right now.
Go the very bottom, quick explanation if you've never done that before. http://etc.usf.edu/techease/win/files-sharing/how-do-i-connect-to-a-shared-folder-on-the-network/
