potts43 Posted July 8, 2015 Posted July 8, 2015 Ok just for the benefit of the thread...hyper mint is now working on a network. Also make sure you place the backslash on the RL media location even though it isn't required for the HS location.
potts43 Posted July 8, 2015 Posted July 8, 2015 Query...tried drag and dropping artwork into fade location but it wouldn't let me. If artwork is already in that folder you can right click and then edit and save it as a layer but the presets didn't seem to have any affect and didn't save the file. Also 3 out of 4 vids saved from the YouTube plugin were corrupt. I then downloaded them using a download manager and all 3 were no problem. Have you seen this before?
horseyhorsey Posted July 8, 2015 Author Posted July 8, 2015 No, never problem with YT-horse. If you can get to push enter in cmd line its 100% good, unless your internet goes down half way through download. Probably to do with network & full path. Fades were always drag and drop but they used to ask you what you wanted to do with the file first, like create layer 1 as you dragged over. That is not there anymore. Will take a look. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
Yardley Posted July 15, 2015 Posted July 15, 2015 Can anyone help, this utility used to work flawless for me but not nothing happens when I choose a system and click start scan. I hadn't tried it since making the change from RocketLauncher3 to RL, did that break it or should it still work?
potts43 Posted July 15, 2015 Posted July 15, 2015 Can anyone help, this utility used to work flawless for me but not nothing happens when I choose a system and click start scan. I hadn't tried it since making the change from RocketLauncher3 to RL, did that break it or should it still work? There is a new version called hypermint
Yardley Posted July 15, 2015 Posted July 15, 2015 There is a new version called hypermint Oh nice! Where can it be found?
potts43 Posted July 15, 2015 Posted July 15, 2015 You need to ask for the beta link... http://www.rlauncher.com/forum/showthread.php?t=1426
Yardley Posted July 15, 2015 Posted July 15, 2015 You need to ask for the beta link... http://www.rlauncher.com/forum/showthread.php?t=1426 Thanks!
itoh Posted July 18, 2015 Posted July 18, 2015 this version not run with hs 1.4 + rocketlauncher? I can just scan my menu systems
ninja2bceen Posted August 25, 2015 Posted August 25, 2015 Hey man, can you add a feature of filter xml by parent vs clones in names xml in hyper mint? Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
horseyhorsey Posted August 25, 2015 Author Posted August 25, 2015 Yes, it should already be in there but have added no button or checkbox. Will do it soon as I can. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
iNTiGOD Posted October 1, 2015 Posted October 1, 2015 Mr Horsey is there an option to convert bezels to 5:4 (for lcd monitors). Could it be added in? MAME High Score Tutorial For HyperSpin
horseyhorsey Posted October 1, 2015 Author Posted October 1, 2015 The bezels aren't actually converted in this. What you are referring to is the tag that is used to name the bezel. If it gets named 16:9 that would make no difference. It's just for reference for when you upload or something, so someone would know the ratio. You have to prep your bezel image size how you would like it first then add into the editor and set your points. I will add in 5:4 into tags though. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
iNTiGOD Posted October 1, 2015 Posted October 1, 2015 The bezels aren't actually converted in this. What you are referring to is the tag that is used to name the bezel. If it gets named 16:9 that would make no difference. It's just for reference for when you upload or something, so someone would know the ratio. You have to prep your bezel image size how you would like it first then add into the editor and set your points. I will add in 5:4 into tags though. Ok so all the resizing would need to be done through something like photoshop? Sorry I'm new to this sort of thing MAME High Score Tutorial For HyperSpin
horseyhorsey Posted October 1, 2015 Author Posted October 1, 2015 Yeah, prep the image beforehand and all this is doing is creating your settings for the bezel points and renaming it with your chosen author name , ratio & description. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
ljubinko Posted October 1, 2015 Posted October 1, 2015 Yeah, prep the image beforehand and all this is doing is creating your settings for the bezel points and renaming it with your chosen author name , ratio & description. Hi horseyhorsey, my pc monitor is 16:10 widescreen, in hypermint do i need to use resize and stretch option checked or not checked for 16:9 bezels .Thanks.
