HLM - Minter Helper Checker Whatever 2.0.2
horseyhorsey
Great to see the best app being updated...still would love the feature of being able to edit and add to the xml on the fly.
Thanks for the update!
  • Replies 290
Have you tried HyperSpin-XML-Bidouilleur for editing xml?
http://www.hyperspin-fe.com/forum/showthread.php?14002-Release-HyperSpin-XML-Bidouilleur-0-1
Cool. It does sound like what you're after.
The roms tab works but can't get the analyse button to work on artwork - does it work on your version?
Never used it for that. It's a nice way to visually edit xml without a text editor.
If you get a minute can you check if yours does the same please?
I agree the editor is good.
Cheers
Hopefully I can get something up tonight but the problem is I keep adding new things and not finishing them up. I'll try and list off the top of my head what I've added.
Hyperspin media scanning, exporting texts & filters (Including Main menu)
Launch random game from current scanned list
Simple wheel creator is now a part of this app.
Quick game/system theme creator : Drag in an image to a games theme cell (for a background), which will spit out a simple theme.zip with background & video placement. I was thinking back to a time where just making one theme with hypertheme and setting it's directory's, adding background,making theme, copying to theme folder, renaming, can take a bit of time. With this, if you have your simple game theme made this could just be used as is with HS or opened for editing in Hypertheme and just saved from there with less pa lava.
Sounds real promising!
Hi mate,
Just wondered how you were getting on? Really looking forward to testing the new version. Hope all is going according to plan;-)
  • 3 weeks later...
Hi mate,
Sorry guys all is ok, should've finished this off but I got sucked into playing poker. Can't believe it's been a whole month looking at my last post! I'll get it done this week.
A month of poker? ;-)
No probs mate
Not doing that bad, it's my only source of income :) I worked in a chlorine factory a few weeks back and that was nasty.
I'll put out a version in an hour or so maybe but it maybe missing some stuff, probs a couple of bugs.
All the HS stuff is in. The wheel creator isn't 100% yet, that does need some work but it's something to play with.
Had a very quick look. What is the purpose of the yes boxes turning to no if you click on them? Also the a yes artwork doesn't appear to be display in the preview box...
Cheers
Bug probably where the scan is correct but when you click it checks files, can you tell me what folder column it is? HS or HLM?
In HS it turns yes to no and in hlm turns yes to empty. It would be good if there was a column for instruction cards also. They are placed on the bezels folder and named
Instruction card - name - author - position
I guess a check for the word instruction card would create the hit.
Cheers
