7Z Support
demonseed
Hey
Ok so my HD is filling up and I wanted to try to 7z my games. I first started with dreamcast which is using Null Dc. I have the game Cadillacs and Dinosaurs (USA).cdi.. I zipped it be Cadillacs and Dinosaurs (USA).7z which took the size of the image down to half! Great..... BUT
I try to manually load the game via nulldc but 7z is not supported..
I go to HyperlaunchHQ.. GLOBAL settings, NULLDC and change extension format to 7z only. I go under Sega Dramcast, General, and click 7z support True.
I go to the game list hit refresh no games found? what did I do wrong? I would like to compress all my games to add serious space as many are unzipped.
I 7z it as ULTRA compression to.
I know I am likely an idiot but can someone explain? Is there any systems that WILL NOT support 7z or other compressions?
Thanks
Jim
UPDATE-ok cannon spike was not in my database.... I 7z another game and now it sees it.. but I get an error saying 7z is not a set ext? I have nulldc set to only 7z. and its set to true.....
LOG-ok how do I do that? what is the file called I need to past?
Ok I turned on trouble shooting and all check boxes checked for logs... I am not sure where the log file is.. there is a log, and log1.. log is super short.
When I load the 7z it says there is not 7z file ext set up or I need to turn on skip error... I have 7z set in global for NULL DC.. I tried various skip ererrors no luck,...
Heres what I find for error logs... LOG1 looks like the detailed one but it is not updating? I have all check boxes checked under logging, tried debug1 and troubleshooting. It wont show the detailed one?
09:42:00 AM | HyperSpin Started
09:42:00 AM | Going windowed mode
09:42:00 AM | Checking for updates
09:42:00 AM | Update Check Complete
09:42:00 AM | Startup program: HyperSpin Startup Script.exe
09:42:00 AM | Startup params not set
09:42:00 AM | Working directory: E:\Hyperspin\Utilities\Startup Script\
09:42:00 AM | Window State: NORMAL
09:42:00 AM | Launching HyperSpin Startup Script.exe
09:42:00 AM | Command Line is HyperSpin Startup Script.exe
09:42:00 AM | Playing intro video
09:42:02 AM | Error intializing joysticks
09:42:02 AM | Menu Mode is multi
09:42:02 AM | Loading Main Menu.xml
09:42:02 AM | Main Menu.xml successfully loaded
09:42:02 AM | Main Menu wheel loaded successfully
09:42:03 AM | Loading Sega Dreamcast.xml
09:42:03 AM | roms_only is true, checking files
09:42:03 AM | Main Menu.xml successfully loaded
09:42:04 AM | Sega Dreamcast wheel loaded successfully
09:42:04 AM | Launching Game
09:42:04 AM | Using HyperLaunch
09:42:04 AM | Getting HyperLaunch path
09:42:04 AM | HyperLaunch located at E:\Hyperspin\HyperLaunch.exe
09:42:04 AM | Running HyperLaunch.exe
09:42:04 AM | HyperLaunch Command Line is: E:\Hyperspin\HyperLaunch.exe "Sega Dreamcast" "102 Dalmatians - Puppies to the Rescue (USA)"
09:42:09 AM | Launching Game
09:42:09 AM | Using HyperLaunch
09:42:09 AM | Getting HyperLaunch path
09:42:09 AM | HyperLaunch located at E:\Hyperspin\HyperLaunch.exe
09:42:09 AM | Running HyperLaunch.exe
09:42:09 AM | HyperLaunch Command Line is: E:\Hyperspin\HyperLaunch.exe "Sega Dreamcast" "102 Dalmatians - Puppies to the Rescue (USA)"
09:42:10 AM | Loading Main Menu.xml
09:42:10 AM | Main Menu.xml successfully loaded
09:42:11 AM | Main Menu wheel loaded successfully
09:42:12 AM | Exit program unavailable
09:42:12 AM | Quiting Hyperspin
09:42:12 AM | Bye!
DemonSeed, please don't edit your posts by adding info, the people trying to help may not notice that you've added it and then not reply. Just do a new post.
You will need to add the cdi extension as well as 7z under global.
Mine are all 7z and contain .gdi
Your HyperLaunch log will be in the HyperLaunch folder, possible just called Hyperlaunch if you have hide extensions set.
It's probably a good Idea to use pastebin and then post a link as the log is very long if set to troubleshooting. Code tags weren't working last time I checked
IS THIS THE correct log file? Sorry I wont edit posts . I was going to ask if I need 7z and format that are unzipped in
09:42:04:957 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.5b BETA (www.hyperlaunch.net)
09:42:04:957 | HL |  WARNING  | +0     | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
09:42:04:957 | HL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
09:42:04:957 | HL |  WARNING  | +0     | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching.
09:42:05:019 | HL |     INFO  | +62    | Main - System Specs:
					HyperLaunch Dir: E:\Hyperspin
					HyperLaunch is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8016.31 MB
					Free Memory: 6141.27 MB
					Used Memory: 1875.047 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics
					GPU 1 RAM: -1924.00 MB
					GPU 1 Driver Version: 9.17.10.3347
					Sound 1 Device: High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: High Definition Audio Device
					Sound 2 Status: Enabled
					OS Admin Status: Yes
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work)
					Monitor #1 Orientation: Landscape
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
09:42:05:019 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\HyperLaunch.exe exists
09:42:05:022 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	Your favorite Front End companion! Visit us @ www.hyperlaunch.net
					FileVersion             	3.1.0.5
					LegalCopyright          	©2014 HyperLaunch
					CompanyName             	HyperLaunch BETA
					File Size:			971264 bytes
					Created:			5/20/2015 - 6:19:35 PM
					Modified:			4/22/2015 - 2:29:13 PM
09:42:05:022 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\dxwnd\dxwnd.ini exists
					File Size:			409 bytes
					Created:			5/22/2015 - 1:38:27 AM
					Modified:			4/22/2015 - 2:29:14 PM
09:42:05:022 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\dxwnd\dxwnd.exe exists
					FileDescription         	DxWnd MFC application
					FileVersion             	1, 0, 0, 1
					InternalName            	DxWnd
					LegalCopyright          	Copyright (C) 2004/2012
					OriginalFilename        	DxWnd.exe
					ProductName             	DxWnd application
					ProductVersion          	1, 0, 0, 1
					File Size:			539136 bytes
					Created:			5/22/2015 - 1:38:26 AM
09:42:05:022 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\BinHexRW.ahk exists
09:42:05:027 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:027 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Created:			5/22/2015 - 1:38:21 AM
09:42:05:027 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
09:42:05:027 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\CLR.ahk exists
09:42:05:029 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
09:42:05:029 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10586 bytes
					Created:			5/22/2015 - 1:38:22 AM
09:42:05:029 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\COM.ahk exists
09:42:05:029 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
09:42:05:032 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26342 bytes
09:42:05:032 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\Control_AniGif.ahk exists
09:42:05:032 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			5716 bytes
09:42:05:032 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\dxwnd\dxwnd.ini exists
09:42:05:032 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\dxwnd\dxwnd.exe exists
					InternalName            	DxWnd
09:42:05:032 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\gdip.ahk exists
09:42:05:034 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
09:42:05:034 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			5/22/2015 - 1:38:23 AM
09:42:05:034 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\gdip_alt.ahk exists
09:42:05:037 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:037 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3394 bytes
09:42:05:037 | HL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.1
09:42:05:037 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\gsdll32.dll exists
					File Size:			13090816 bytes
09:42:05:037 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			5/22/2015 - 1:38:25 AM
09:42:05:037 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\Java.ahk exists
09:42:05:039 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:039 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
09:42:05:039 | HL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
09:42:05:039 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\JSON.ahk exists
09:42:05:039 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			9203 bytes
09:42:05:039 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\Origin.ahk exists
09:42:05:042 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:042 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4901 bytes
09:42:05:042 | HL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.1
09:42:05:042 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\PacDrive32.dll exists
					File Size:			69120 bytes
09:42:05:042 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\RegRW64.ahk exists
09:42:05:042 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			6915 bytes
09:42:05:042 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\RIni.ahk exists
09:42:05:044 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
09:42:05:044 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
09:42:05:044 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\SevenZipSharp.dll exists
09:42:05:047 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
09:42:05:047 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\Steam.ahk exists
09:42:05:047 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5344 bytes
09:42:05:047 | HL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.1
09:42:05:047 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\VA.ahk exists
09:42:05:049 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
09:42:05:049 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
09:42:05:049 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\VA_Extension.ahk exists
09:42:05:049 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:052 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
09:42:05:052 | HL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
09:42:05:052 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Bezel.ahk exists
09:42:05:052 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:054 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			101738 bytes
					Created:			5/21/2015 - 10:46:04 PM
09:42:05:054 | HL |   DEBUG1  | +0     | Bezel.ahk Version: 1.0.9
09:42:05:054 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Fade.ahk exists
09:42:05:054 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			36402 bytes
09:42:05:054 | HL |   DEBUG1  | +0     | Fade.ahk Version: 1.0.9
09:42:05:054 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Fade Init.ahk exists
09:42:05:057 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			999 bytes
09:42:05:057 | HL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
09:42:05:057 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Fade Animations.ahk exists
09:42:05:057 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			67602 bytes
09:42:05:057 | HL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.1
09:42:05:057 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\HyperPause.ahk exists
09:42:05:064 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:064 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
09:42:05:064 | HL |   DEBUG1  | +0     | HyperPause.ahk Version: 1.0.8
09:42:05:064 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\HyperPause Init.ahk exists
09:42:05:067 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:067 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			537 bytes
09:42:05:067 | HL |   DEBUG1  | +0     | HyperPause Init.ahk Version: 1.0.1
09:42:05:067 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Keymapper.ahk exists
					File Size:			32953 bytes
09:42:05:067 | HL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.0.9
09:42:05:067 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Keymapper Init.ahk exists
09:42:05:069 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:069 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3435 bytes
09:42:05:069 | HL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.2
09:42:05:069 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\MultiGame.ahk exists
09:42:05:072 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			40584 bytes
09:42:05:072 | HL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.6
09:42:05:072 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\MultiGame Init.ahk exists
09:42:05:072 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			161 bytes
09:42:05:072 | HL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
09:42:05:072 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\MultiPlayer.ahk exists
09:42:05:074 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:074 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58605 bytes
09:42:05:074 | HL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.4
09:42:05:074 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Password.ahk exists
					File Size:			10035 bytes
09:42:05:074 | HL |   DEBUG1  | +0     | Password.ahk Version: 1.0.0
09:42:05:074 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Rom Mapping Launch Menu.ahk exists
09:42:05:077 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:077 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73560 bytes
09:42:05:077 | HL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.3
09:42:05:077 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Shared.ahk exists
09:42:05:079 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:082 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			145962 bytes
09:42:05:082 | HL |   DEBUG1  | +0     | Shared.ahk Version: 1.2.3
09:42:05:082 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Statistics.ahk exists
09:42:05:082 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			26170 bytes
09:42:05:082 | HL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.2
09:42:05:082 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\Statistics Init.ahk exists
09:42:05:084 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
09:42:05:084 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
09:42:05:084 | HL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
09:42:05:084 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\XHotkey.ahk exists
09:42:05:087 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29623 bytes
					Created:			5/21/2015 - 10:46:05 PM
09:42:05:087 | HL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.2
09:42:05:087 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Lib\XHotkey Init.ahk exists
09:42:05:087 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			1236 bytes
09:42:05:087 | HL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
09:42:05:087 | HL |   DEBUG1  | +0     | Main - Raw CLI received: "Sega Dreamcast 102 Dalmatians - Puppies to the Rescue (USA)"
09:42:05:087 | HL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "102 Dalmatians - Puppies to the Rescue (USA)"
09:42:05:087 | HL |   DEBUG1  | +0     | Main - dbName: 102 Dalmatians - Puppies to the Rescue (USA)
09:42:05:087 | HL |  WARNING  | +0     | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-f <PATH_TO_MY_FE\FRONTEND.exe>"
09:42:05:089 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x320 y150 w800 h600
09:42:05:089 | HL |  WARNING  | +0     | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-p <PLUGINTYPE>"
09:42:05:089 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Plugins\HyperSpin.plugin exists
09:42:05:089 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			8999 bytes
					Created:			5/22/2015 - 1:38:36 AM
09:42:05:089 | HL |     INFO  | +0     | Main - HyperLaunch received "Sega Dreamcast" and "102 Dalmatians - Puppies to the Rescue (USA)"
09:42:05:097 | HL |     INFO  | +15    | Main - 102 Dalmatians - Puppies to the Rescue (USA) is using the default emulator: NullDC
09:42:05:097 | HL |     INFO  | +0     | Main - Checking for a [NullDC] section in E:\Hyperspin\Settings\Sega Dreamcast\Emulators.ini
09:42:05:097 | HL |     INFO  | +0     | Main - Checking for a [NullDC] section in E:\Hyperspin\Settings\Global Emulators.ini
09:42:05:099 | HL |     INFO  | +0     | Main - Found [NullDC] in E:\Hyperspin\Settings\Global Emulators.ini
09:42:05:099 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Modules\NullDC\NullDC.ahk exists
09:42:05:099 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10567 bytes
					Created:			5/22/2015 - 1:38:33 AM
09:42:05:099 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
09:42:05:099 | HL |     INFO  | +0     | Main - 102 Dalmatians - Puppies to the Rescue (USA) will use module: E:\Hyperspin\Modules\NullDC\NullDC.ahk
09:42:05:109 | HL |     INFO  | +16    | Main - Did not find a "E:\Hyperspin\Settings\Sega Dreamcast\Game Options.ini" file, skipping any game-specific options.
09:42:05:109 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
09:42:05:112 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\NullDC-r150\nullDC_Win32_Release-NoTrace.exe exists
09:42:05:112 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			352256 bytes
					Created:			5/20/2015 - 11:19:05 PM
					Modified:			2/3/2013 - 10:53:01 AM
09:42:05:112 | HL |     INFO  | +0     | Main - INI Keys read
09:42:05:112 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\7z.exe exists
09:42:05:114 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
09:42:05:114 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\7z.dll exists
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
09:42:05:114 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\FontReg.exe exists
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
09:42:05:147 | HL |     INFO  | +31    | Main - "102 Dalmatians - Puppies to the Rescue (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
09:42:05:147 | HL |     INFO  | +0     | CheckPaths - Started
09:42:05:147 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\NullDC-r150\roms\102 Dalmatians - Puppies to the Rescue (USA).7z
09:42:05:164 | HL |     INFO  | +16    | CheckPaths - Found rom: E:\Hyperspin\Emulators\NullDC-r150\roms\102 Dalmatians - Puppies to the Rescue (USA).7z
09:42:05:164 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: 102 Dalmatians - Puppies to the Rescue (USA)
09:42:05:164 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: E:\Hyperspin\Emulators\NullDC-r150\roms
09:42:05:164 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .7z
09:42:05:164 | HL |     INFO  | +0     | CheckPaths - Ended
09:42:05:164 | HL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 2
					pluginPath = E:\Hyperspin\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit =
					hlMode =
					hlTitle = HyperLaunch
					hlVersion = 3.1.0.5b BETA
					hlAuthor = djvj
					hlURL = www.hyperlaunch.net
					langFile = E:\Hyperspin\Data\Language\Localization.ini
					frontendPID = 4728
					frontendPath = E:\HyperSpin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = E:
					exitEmulatorKey = ~Esc
					exitEmulatorKeyWait = 0
					forceHoldKey = ~Esc
					restoreFE = false
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = E:\Hyperspin\Emulators\NullDC-r150\nullDC_Win32_Release-NoTrace.exe
					emuPath = E:\Hyperspin\Emulators\NullDC-r150
					emuName = NullDC
					emuExt = exe
					romPath = E:\Hyperspin\Emulators\NullDC-r150\roms
					romPathFromIni = E:\Hyperspin\Emulators\NullDC-r150\roms
					romExtension = .7z
					romExtensionOrig = .7z
					romExtensions = 7z
					executable = nullDC_Win32_Release-NoTrace.exe
					systemName = Sega Dreamcast
					dbPath =
					dbName = 102 Dalmatians - Puppies to the Rescue (USA)
					dbExt =
					romName = 102 Dalmatians - Puppies to the Rescue (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = E:\Hyperspin\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = E:\Hyperspin\HyperLaunch.log
					logLevel = 5
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = true
					logCommandWindow = true
					hlDebugConsoleStdout =
					sysType = 64-bit
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					dtEnabled = false
					dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					dtUseSCSI = false
					dtAddDrive = true
					servoStikEnabled = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = E:\Hyperspin\Profiles\LEDBlinky
					ledblinkyHLProfile = E:\Hyperspin\Profiles\LEDBlinky\HyperLaunch
					emuIdleShutdown = 0
					hideCursor = false
					hideEmu = false
					hideFE = false
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = E:\Hyperspin\Media\Fade
					HLDataPath = E:\Hyperspin\Data
					HLMediaPath = E:\Hyperspin\Media
					HLErrSoundPath = E:\Hyperspin\Media\Sounds\Error
					modulesPath = E:\Hyperspin\Modules
					moduleFullName = E:\Hyperspin\Modules\NullDC\NullDC.ahk
					moduleName = NullDC
					modulePath = E:\Hyperspin\Modules\NullDC
					moduleExtension = ahk
					moduleExtensionsPath = E:\Hyperspin\Module Extensions
					libPath = E:\Hyperspin\Lib
					7zEnabled = true
					7zPath = E:\Hyperspin\Module Extensions\7z.exe
					7zDllPath = E:\Hyperspin\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					hpEnabled = false
					hpKey = ~NumpadAdd
					hpBackToMenuBarKey = X
					hpZoomInKey = C
					hpZoomOutKey = V
					hpHiToTextPath = E:\Hyperspin\Module Extensions\HiToText.exe
					hpSaveStateKeyCodes =
					hpLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = E:\Utilities\Xpadder\xpadder.exe
					joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = E:\Hyperspin\Profiles\xpadder
					keymapperFrontEndProfileName = HyperLaunchHQ
					JoyIDsEnabled = false
					JoyIDsPreferredControllersSystem = use_global
					JoyIDsPreferredControllersGlobal =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = E:\Hyperspin\Profiles\xpadder\HyperLaunchHQ
					defaultProfile = E:\Hyperspin\Profiles\xpadder\_Default
					systemProfile = E:\Hyperspin\Profiles\xpadder\Sega Dreamcast
					xPadderSystemProfile = E:\Hyperspin\Profiles\xpadder\Sega Dreamcast\_Default
					emuProfile = E:\Hyperspin\Profiles\xpadder\Sega Dreamcast\NullDC
					romProfile = E:\Hyperspin\Profiles\xpadder\Sega Dreamcast\102 Dalmatians - Puppies to the Rescue (USA)
					HyperLaunchProfile = E:\Hyperspin\Profiles\xpadder\HyperLaunch
					blankProfile = E:\Hyperspin\Profiles\xpadder\_Default\blank
					ahkFEProfile = E:\Hyperspin\Profiles\AHK\HyperLaunchHQ
					ahkDefaultProfile = E:\Hyperspin\Profiles\AHK\_Default
					ahkSystemProfile = E:\Hyperspin\Profiles\AHK\Sega Dreamcast
					ahkEmuProfile = E:\Hyperspin\Profiles\AHK\Sega Dreamcast\NullDC
					ahkRomProfile = E:\Hyperspin\Profiles\AHK\Sega Dreamcast\102 Dalmatians - Puppies to the Rescue (USA)
					ahkHyperLaunchProfile = E:\Hyperspin\Profiles\AHK\HyperLaunch
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = E:\Hyperspin\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = E:\Hyperspin\Module Extensions\dxwnd\dxwnd.exe
					mon1O = 0
					pacDrivedllFile = E:\Hyperspin\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = E:\Hyperspin\Lib\User Fade Animations.ini
09:42:05:169 | HL |     INFO  | +15    | BuildScript - Loaded XHotkey Init.ahk scripts
09:42:05:169 | HL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
09:42:05:169 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
09:42:05:169 | HL |  WARNING  | +0     | BuildScript - "E:\Hyperspin\Lib\User Functions Init.ahk" not found
09:42:05:169 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
09:42:05:169 | HL |     INFO  | +0     | BuildScript - Validating module
09:42:05:169 | HL |     INFO  | +0     | BuildScript - Validation complete
09:42:05:169 | HL |     INFO  | +0     | BuildScript - Module:
					MEmu = NullDC
					MEmuV =  r141
					MURL = https://code.google.com/p/nulldc/
					MAuthor = djvj & bleasby
					MVersion = 2.0.5
					MCRC = E9F6474E
					iCRC = C2786503
					MID = 635038268910409317
					MSystem = "Sega Dreamcast"
					; NullDC works with these disc images:
					; - CDI: Padus DiscJuggler image
					; - MDS: Alcohol 120% Media Descriptor image (must be accompanied by a MDF file)
					; - NRG: Nero Burning ROM image
					; - GDI: Raw GDI dump
					; - CHD: MAME's Compressed Hunk of Data
					; Helpful guide for getting the basics setup for NullDC: http://www.dgemu.com/forums/index.php/topic/474318-guide-configuring-nulldc-104-r136/
					; If you want to use specific configs per game, create a folder called Cfg inside nullDC folder and copy your nullDC.cfg
					; config files into it naming them to match the database names. Make sure you keep a copy of nullDC.cfg on the Cfg folder as well.
					; If you want to convert your roms from gdi to chd, see here: http://www.emutalk.net/showthread.php?t=51502
					; FileDelete(s) are in the script because sometimes demul will corrupt the ini and make it crash. The script recreates a clean ini for you.
					; Setup the user settings in the moduleName ini to your liking
					; Games can have a custom Cable Type (per game). Not all games work on VGA, so use the below option in the ini
					; Cable can be 0 (VGA(0)(RGB)), 1 (VGA(1)(RGB)), 2 (TV(RGB)) or 3 (TV(VBS/Y+S/C)), default is 0.
					; For additional setup steps prior to running, see this link: http://www.hyperspin-fe.com/forum/showpost.php?p=99852&postcount=138
					; Not all builds work with swapping discs, it's mostly broken and is a nulldc problem, not HyperLaunch's. See here: http://code.google.com/p/nulldc/issues/detail?id=264
					StartModule()
					BezelGUI()
					ExtraFixedResBezelGUI()
					If systemName not contains dreamcast,dc
						ScriptError(systemName . " is not a supported system for this module. Only " . MSystem . " is supported.")
					FadeInStart()
					nullDCcfg := checkFile(emuPath . "\nullDC.cfg")
					fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1)
					dualMonitors := IniReadCheck(settingsFile, "NullDC", "DualMonitors","false",,1)
					autoStart := IniReadCheck(settingsFile, "NullDC", "autoStart","1",,1)
					noConsole := IniReadCheck(settingsFile, "NullDC", "noConsole","1",,1)
					autoHideMenu := IniReadCheck(settingsFile, "NullDC", "autoHideMenu","0",,1)
					alwaysOnTop := IniReadCheck(settingsFile, "NullDC", "alwaysOnTop","1",,1)
					showVMU := IniReadCheck(settingsFile, "NullDC", "showVMU","0",,1)
					VMU1Pos := IniReadCheck(settingsFile, "NullDC", "VMU1Pos","topLeft",,1) ; topRight, topCenter, topLeft, leftCenter, bottomLeft, bottomCenter, bottomRight, rightCenter
					VMU2Pos := IniReadCheck(settingsFile, "NullDC", "VMU2Pos","topRight",,1) ; topRight, topCenter, topLeft, leftCenter, bottomLeft, bottomCenter, bottomRight, rightCenter
					VMU3Pos := IniReadCheck(settingsFile, "NullDC", "VMU3Pos","bottomLeft",,1) ; topRight, topCenter, topLeft, leftCenter, bottomLeft, bottomCenter, bottomRight, rightCenter
					VMU4Pos := IniReadCheck(settingsFile, "NullDC", "VMU4Pos","bottomRight",,1) ; topRight, topCenter, topLeft, leftCenter, bottomLeft, bottomCenter, bottomRight, rightCenter
					VMUHideKey := IniReadCheck(settingsFile, "Settings", "VMUHideKey","F10",,1)
					loadDefaultImage := IniReadCheck(settingsFile, "NullDC", "loadDefaultImage","1",,1)
					patchRegion := IniReadCheck(settingsFile, "NullDC", "patchRegion","1",,1)
					cable := IniReadCheck(settingsFile, romName, "Cable","0",,1)
					hideEmuObj := Object("ahk_class ConsoleWindowClass",0,"nullDC ahk_class ndc_main_window",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					specialCfg = %emuPath%\cfg\%romName%.cfg
					defaultCfg = %emuPath%\cfg\nullDC.cfg
					If (FileExist(specialCfg) && FileExist(defaultCfg))
						FileCopy, %specialCfg%, %emuPath%\nullDC.cfg, 1
					Else If FileExist(defaultCfg)
						FileCopy, %defaultCfg%, %emuPath%\nullDC.cfg, 1
					;Detect game region based on rom name
					IfInString, romName, (Europe)
						region = 2
					Else IfInString, romName, (Japan)
						region = 0
					Else IfInString, romName, (World)
						region = 2
					Else
						region = 1
					If romExtension In %7zformats%
						ScriptError(MEmu . " does not support compressed formats. Please extract your images first or enable 7z.")
					BezelStart()
					;Write Settings
					IniWrite, % (If (Fullscreen = "true" )?("1"):("0")), %nullDCcfg%, nullDC_GUI, Fullscreen
					IniWrite, %autoStart%, %nullDCcfg%, nullDC, Emulator.AutoStart
					IniWrite, %noConsole%, %nullDCcfg%, nullDC, Emulator.NoConsole
					IniWrite, %autoHideMenu%, %nullDCcfg%, nullDC_GUI, AutoHideMenu
					IniWrite, %alwaysOnTop%, %nullDCcfg%, nullDC_GUI, AlwaysOnTop
					IniWrite, %showVMU%, %nullDCcfg%, drkMaple, VMU.Show
					IniWrite, %loadDefaultImage%, %nullDCcfg%, ImageReader, LoadDefaultImage
					IniWrite, %patchRegion%, %nullDCcfg%, ImageReader, PatchRegion
					IniWrite, %region%, %nullDCcfg%, nullDC, Dreamcast.Region
					IniWrite, %cable%, %nullDCcfg%, nullDC, Dreamcast.Cable
					Log("Module - Telling ImageReader plugin to load this game: """ . romPath . "\" . romname . RomExtension)
					IniWrite, %romPath%\%romname%%RomExtension%, %nullDCcfg%, ImageReader, DefaultImage
					;Fixes hanging previous nullDC on bad exits or loads
					Process("Exist", executable)
					If !ErrorLevel = 0
						Process("Close", executable)
					; This hides nullDC's menu when running dual screens
					If dualMonitors = true
					{	MouseGetPos X, Y
						SetDefaultMouseSpeed, 0
						MouseMove %A_ScreenWidth%,%A_ScreenHeight%
					HideEmuStart()	; This fully ensures windows are completely hidden even faster than winwait
					Run(executable, emuPath)
					; TESTING TO HIDE THE CONSOLE WINDOW POPUP, NOTHING WORKS
					; WinWait("nullDC ahk_class ndc_main_window")
					; WinSet, Transparent, On, nullDC ahk_class ndc_main_window
					; WinSet, Transparent, On, ahk_class ConsoleWindowClass	; makes the console window transparent so you don't see it on exit
					; Sleep, 2000 ; Enough to hide the startup logo
					; WinHide, ahk_class ConsoleWindowClass
					WinWaitActive("nullDC ahk_class ndc_main_window")
					ndcID:=WinExist("A")	; storing the window's PID so we can toggle it later
					ToggleMenu(ndcID) ; Removes the MenuBar
					; DllCall("SetMenu", uint, WinActive( "A" ), uint, 0) ; Removes the MenuBar
					;Let's completely hide the menu by slighly moving the window off screen
					;nullDC will self adjust once the menu autohides
					If fullScreen = true
					{	yOffset = -20
						winHeight := A_ScreenHeight - yOffset
						WinMove, nullDC,, 0, %yOffset%, %A_ScreenWidth%, %winHeight%
					; WinShow, nullDC ahk_class ndc_main_window ; without these, nullDC may stay hidden behind HS
					; WinActivate, nullDC ahk_class ndc_main_window
					HideEmuEnd()
					BezelDraw()
					If !(showVMU="0")
						SetTimer, CheckforVMU, 10000
					FadeInExit()
					WinSet, Transparent, Off, nullDC ahk_class ndc_main_window
					7zCleanUp()
					BezelExit()
					ExtraFixedResBezelExit()
					FadeOutExit()
					ExitModule()
					 ; Toggle the MenuBar
					!a::
						ToggleMenu(ndcID)
					Return
					MultiGame:
						; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
						ToggleMenu(ndcID) ; Restore the MenuBar
						Loop {
							WinMenuSelectItem,nullDC ahk_class ndc_main_window,,Options,GDRom,Select Default Image
							WinWait("Select Image File ahk_class #32770")
							WinWaitActive("Select Image File ahk_class #32770")
							If WinActive("Select Image File ahk_class #32770")
								Break
						OpenROM("Select Image File ahk_class #32770", mgRomPath . "\" . mgRomName . "." . mgRomExt)	; unsure if Select Image File needs to be translated via i18n
						Sleep, 300 ; giving time for emu to mount the new image
						WinMenuSelectItem,nullDC ahk_class ndc_main_window,,Options,GDRom,Swap Disc	; DC does not support swapping discs on-the-fly like psx because the console reset when the drive was opened. This basically tells the emu to reset.
					Return
					BezelLabel:
					disableHideToggleMenu := true
					Return
					HaltEmu:
						If VMUHideKey
							XHotKeywrapper(VMUHideKey,"VMUHide","OFF")
					Return
					RestoreEmu:
						If VMULoaded
						{	Loop, 4
							{	WinSet, Transparent, 0, % "ahk_ID " . VMUScreenID%A_Index%
								WinSet, AlwaysOnTop, On, % "ahk_ID " . VMUScreenID%A_Index%
								WinShow, % "ahk_ID " . VMUScreenID%A_Index%
							WinSet, AlwaysOnTop, On, ahk_ID %extraFixedRes_Bezel_hwnd%
							WinShow, ahk_ID %extraFixedRes_Bezel_hwnd%
							If !(VMUHidden)
								Loop, 4
									WinSet, Transparent, off, % "ahk_ID " . VMUScreenID%A_Index%
						If VMUHideKey
							XHotKeywrapper(VMUHideKey,"VMUHide","ON")
					Return
					CheckforVMU:
						Loop, 4
						{ 	Transform, letter, Chr, % A_Index + asc("A") - 1  ; transform number to letter
							If ((!(VMU%A_Index%Draw)) and (VMUScreenID%A_Index%:=WinExist("nullDC VMU " . letter . "0 ahk_class #32770")))
								ExtraFixedResBezelDraw(VMUScreenID%A_Index%, "VMU",VMU%A_Index%Pos, 144, 96, 8, 8, 28, 8)
								VMU%A_Index%Draw := true
								If !(VMULoaded){
									VMUHideKey := xHotKeyVarEdit(VMUHideKey,"VMUHideKey","~","Add")
									xHotKeywrapper(VMUHideKey,"VMUHide")
									VMULoaded := true
						If ((VMU1Draw) and (VMU2Draw) and (VMU3Draw) and (VMU4Draw))
							SetTimer, CheckforVMU, off
					Return
					VMUHide:
						If (VMUHidden)
						{	Loop, 4
							UpdateLayeredWindow(extraFixedRes_Bezel_hwnd, extraFixedRes_Bezel_hdc,0,0, A_ScreenWidth, A_ScreenHeight,255)
							VMUHidden := false
						} Else {
							Loop, 4
							UpdateLayeredWindow(extraFixedRes_Bezel_hwnd, extraFixedRes_Bezel_hdc,0,0, A_ScreenWidth, A_ScreenHeight,0)
							VMUHidden := true
					Return
					CloseProcess:
						If VMULoaded
							SetTimer, checkforVMU, off
						FadeOutStart()
						; WinClose("ahk_class ConsoleWindowClass")
						WinClose("nullDC ahk_class ndc_main_window")
					Return
09:42:05:282 | HL |     INFO  | +109   | BuildScript - Loaded Multi-Player scripts
09:42:05:282 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
09:42:05:282 | HL |  WARNING  | +0     | BuildScript - "E:\Hyperspin\Lib\User Functions.ahk" not found
09:42:05:282 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
09:42:05:284 | HL |     INFO  | +0     | Main - Module is built
09:42:05:284 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\AutoHotkey.dll exists
09:42:05:284 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			5/20/2015 - 6:19:33 PM
09:42:05:284 | HL |     INFO  | +0     | Main - Running module
09:42:05:397 | MD |     INFO  | +N/A   | Module initialized
09:42:05:397 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
09:42:05:399 | MD |   DEBUG1  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
09:42:05:399 | MD |   DEBUG1  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
09:42:05:399 | MD |   DEBUG1  | +0     | fadeLyr3Animation: DefaultFadeAnimation
09:42:05:399 | MD |   DEBUG1  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
09:42:05:399 | MD |     INFO  | +0     | StartModule - Started
09:42:05:399 | MD |     INFO  | +0     | StartModule - MEmu: NullDC
					MEmuV: r141
					MURL: https://code.google.com/p/nulldc/
					MAuthor: djvj & bleasby
					MVersion: 2.0.5
					MCRC: E9F6474E
					iCRC: C2786503
					MID:
					MSystem: "Sega Dreamcast"
09:42:05:399 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Sega Dreamcast"
09:42:05:402 | MD |     INFO  | +0     | PluginInit - Started
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
09:42:05:402 | MD |     INFO  | +0     | CheckFile - Checking if E:\HyperSpin\Databases\Sega Dreamcast\Sega Dreamcast.xml exists
09:42:05:402 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			112919 bytes
					Created:			5/20/2015 - 6:19:48 PM
					Modified:			5/22/2015 - 9:06:08 AM
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "102 Dalmatians - Puppies to the Rescue (USA)"
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Eidos Interactive"
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "2000"
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
09:42:05:402 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Platform"
09:42:05:424 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Rating
09:42:05:424 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "ESRB - E (Everyone)"
09:42:05:424 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value:
					GameInfo Label: Manufacturer | GameInfo Value:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
					GameInfo Label: Year | GameInfo Value:
09:42:05:424 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\Sega Dreamcast\Images\Wheel\102 Dalmatians - Puppies to the Rescue (USA).png
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sega Dreamcast.png
09:42:05:424 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  E:\HyperSpin\Media\Sega Dreamcast\Images\Wheel\102 Dalmatians - Puppies to the Rescue (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  E:\HyperSpin\Media\Main Menu\Images\Wheel\Sega Dreamcast.png | Asset Extension1:  png | Asset Type1:  system
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\Sega Dreamcast\Images\Artwork1\102 Dalmatians - Puppies to the Rescue (USA).png
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\Sega Dreamcast\Images\Artwork2\102 Dalmatians - Puppies to the Rescue (USA).png
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\Sega Dreamcast\Images\Artwork3\102 Dalmatians - Puppies to the Rescue (USA).png
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\Sega Dreamcast\Images\Artwork4\102 Dalmatians - Puppies to the Rescue (USA).png
09:42:05:424 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\Sega Dreamcast\Images\Letters
09:42:05:459 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\Sega Dreamcast\Images\Other
09:42:05:462 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Cartridge | Asset Path1:  E:\HyperSpin\Media\Sega Dreamcast\Images\Artwork3\102 Dalmatians - Puppies to the Rescue (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\Sega Dreamcast\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\Sega Dreamcast\Images\Other\pointer.png | Asset Extension1:  png | Asset Type1:  system
09:42:05:462 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
09:42:05:462 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
09:42:05:462 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: E:\HyperSpin\Media\Sega Dreamcast\Video\102 Dalmatians - Puppies to the Rescue (USA).*
09:42:05:462 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 System Video: E:\HyperSpin\Media\Main Menu\Video\Sega Dreamcast.*
					Asset Label: FLV Game Video | Asset Path1:  E:\HyperSpin\Media\Sega Dreamcast\Video\102 Dalmatians - Puppies to the Rescue (USA).flv | Asset Extension1:  flv | Asset Type1:  game
					Asset Label: MP4 Game Video | Asset Path1:  E:\HyperSpin\Media\Sega Dreamcast\Video\102 Dalmatians - Puppies to the Rescue (USA).mp4 | Asset Extension1:  mp4 | Asset Type1:  game
					Asset Label: MP4 System Video | Asset Path1:  E:\HyperSpin\Media\Main Menu\Video\Sega Dreamcast.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
09:42:05:462 | MD |     INFO  | +0     | PluginInit - Ended
09:42:05:462 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to HyperLaunch: 102 Dalmatians - Puppies to the Rescue (USA)
09:42:05:462 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
09:42:05:462 | MD |     INFO  | +0     | StartModule - Ended
09:42:05:462 | MD |   DEBUG1  | +0     | FadeInStart - Started
09:42:05:462 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
09:42:05:462 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
09:42:05:462 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseFadeIn"
09:42:05:462 | MD |   DEBUG2  | +0     | Fade screen scale factor: X=0.750000, Y= 0.833333
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\102 Dalmatians - Puppies to the Rescue (USA)\Layer 1*.*
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Horizontal\Layer 1*.*
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.*
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.png
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.gif
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.tif
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.bmp
09:42:05:462 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1*.jpg
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1.jpg
09:42:05:464 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Layer 1.jpg
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\102 Dalmatians - Puppies to the Rescue (USA)\Extra Layer 1 - Console*.*
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Horizontal\Extra Layer 1 - Console*.*
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: E:\Hyperspin\Media\Fade\Sega Dreamcast\_Default\Extra Layer 1 - Console*.*
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: E:\Hyperspin\Media\Fade\_Default\Horizontal\Extra Layer 1 - Console*.*
09:42:05:464 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: E:\Hyperspin\Media\Fade\_Default\Extra Layer 1 - Console*.*
09:42:05:544 | MD |     INFO  | +94    | DefaultAnimateFadeIn - Started
09:42:05:544 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
09:42:06:084 | MD |     INFO  | +530   | DefaultAnimateFadeIn - Ended
09:42:06:112 | MD |   DEBUG1  | +31    | FadeInStart - Ended
09:42:06:112 | MD |   DEBUG1  | +0     | CoverFE - Started
09:42:06:177 | MD |   DEBUG1  | +63    | CoverFE - Ended
09:42:06:177 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\NullDC-r150\nullDC.cfg exists
09:42:06:177 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5301 bytes
					Modified:			5/22/2015 - 9:29:07 AM
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - DualMonitors: false
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - autoStart: 1
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - noConsole: 1
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - autoHideMenu: 0
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - alwaysOnTop: 1
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - showVMU: 0
09:42:06:177 | MD |     INFO  | +0     | Module Setting - [NullDC] - VMU1Pos: topLeft
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [NullDC] - VMU2Pos: topRight
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [NullDC] - VMU3Pos: bottomLeft
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [NullDC] - VMU4Pos: bottomRight
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [Settings] - VMUHideKey: F10
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [NullDC] - loadDefaultImage: 1
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [NullDC] - patchRegion: 1
09:42:06:179 | MD |     INFO  | +0     | Module Setting - [102 Dalmatians - Puppies to the Rescue (USA)] - Cable: 0
09:42:06:179 | MD |     INFO  | +0     | 7z - Started, received E:\Hyperspin\Emulators\NullDC-r150\roms\102 Dalmatians - Puppies to the Rescue (USA).7z. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS
09:42:06:179 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
09:42:06:179 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
09:42:06:179 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError"
09:42:06:594 | MD |   DEBUG1  | +421   | ScriptError - Playing error sound: error10.mp3
09:42:09:677 | MD |     INFO  | +3089  | 7zCleanUp - Started
09:42:09:677 | MD |   DEBUG1  | +0     | 7zCleanUp - Deleted
09:42:09:678 | MD |     INFO  | +0     | 7zCleanUp - Ended
09:42:10:730 | MD |   DEBUG2  | +1045  | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
09:42:10:730 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc"
09:42:10:730 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
09:42:10:730 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
09:42:10:730 | MD |    ERROR  | +0     | ScriptError - You did not supply any valid rom extensions to search for in your compressed roms. Please turn off 7z support or add at least one rom extension to Rom_Extension: "7z". If this archive has no roms with a standard romName inside, you may need to set Skip Checks to "Rom Extension."
09:42:10:730 | MD |     INFO  | +0     | ExitModule - Started
09:42:10:730 | MD |     INFO  | +0     | Starting Updating Statistics:
09:42:10:730 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
09:42:10:730 | MD |   DEBUG2  | +0     | gameSectionStartTime:2048277
09:42:10:730 | MD |   DEBUG2  | +0     | ElapsedTime:5
09:42:10:730 | MD |   DEBUG2  | +0     | Statistics cleared game name: 102 Dalmatians - Puppies to the Rescue
09:42:10:765 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
					Number_of_Times_Played: 7
					Last_Time_Played: Friday May 22, 2015 09:41:42 AM
					Average_Time_Played: 6
					Total_Time_Played: 45
					System_Total_Played_Time: 414
					Total_Global_Played_Time: 9358
09:42:10:765 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 8
					Last_Time_Played: Friday May 22, 2015 09:42:05 AM
					Total_Time_Played: 50
					System_Total_Played_Time: 419
					Total_Global_Played_Time: 9363
09:42:10:860 | MD |     INFO  | +94    | Game section statistics updated.
09:42:10:860 | MD |     INFO  | +0     | ExitModule - Ended
09:42:10:860 | MD |     INFO  | +0     | End of Module Logs
09:42:11:012 | HL |     INFO  | +5726  | Main - Module ended, exiting HyperLaunch normally
09:42:11:012 | HL |     INFO  | +0     | ExitScript - Started
09:42:11:105 | HL |   DEBUG1  | +93    | ExitScript - Checking what application is currently in focus.
09:42:11:107 | HL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
09:42:11:107 | HL |     INFO  | +0     | ExitScript - Ended
Ok I added the ext and it worked! easy! sweet thanks.. now my other question is, does it unzip to a temp folder? is there a way to have it auto delete it?
Great thanks so much. On a side note I'm missing a few games for dreamcast and wondered instead of getting all them is there a tool to verify what I have to confirm its the legit and proper working game?
And I am new to 7z, how do I select a bunch of files, select them all and have them be made into individual 7z files? I don't see an option. Works with WinRAR..
Hey
Drizzle zip stuck at idle.... does nothing. I run it and it does not do anything, I checked task manger and CPU is at 0%.
The 7z wont work for some reason either.. I tried 32 and 64 bit versions of 7zip, over wrote the files as told but there is no option for me to 7z individual files in a batch :(
Yes I got that program installed. I dragged some sega bins to it.. a Command windows pop up saying its starting but it stays at 0% after a bit it switches the game and does the same thing. I checked the directory no 7z are being made... I wonder if it will make them after it the command prompt goes through the games? I hate this.. WinRAR.. I right click add to archive and its done...
you can use archives rar with RocketLauncher, 7zip support it. Me use it for games with audio cd (best compress this case that 7zip).
Sal2.
Ok so the 7zip batch did not work.. I ran it.. it made ISO files and inside the files was some very weird names!
Archive.rar??? no idea what that is..can you explain please?
rars will work? I thought 7z was way more compressed? If I use rar... do I need to enable7z in settings or no?
if need active 7z support if emulator no work with compress games. 7zip better compression for almost everything, but rather slower.
The latest builds of Demul and nullDC support native CHD loading, which is a great lossless compressed ISO format. There's an easy to use batch script for converting GDI ISOs to CHD here. I couldn't figure out how to convert CDIs to CHD unfortunately. You want GDIs anyways since CDIs have lossy compressed audio and video files and sometimes cut out music entirely.
