hyperspin cannot find launcher
snstay
Ok im bound to get this working this weekend (hopefully)
Now i have Rocketlauncher all extracted in my its own folder in hyperspin. And hopefully i have it pointed in the right direction
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=DICE
RocketLauncher_Path=C:\Hyperspin\RocketLauncher/
Now everything works in rocketlauncher but when i try and launch a game it says cannot find launcher.....well its right there isnt it?
Do i have it set up right, please help.
Thanks
I'm not sure but the forward slash /  might be a problem
if you are using Hyperspin 1.3
C:\HyperSpin\RocketLauncher\
if you are using Hyperspin 1.4
C:\HyperSpin\RocketLauncher\RocketLauncher.exe
Ok using 1.3 pated as above and now it hangs for a second then nothing like its still not finding the path. Anyone else had this happen
Did you run the transition tool? Because HS 1.3 only works with HyperLaunch and you are trying to use a launcher called RocketLauncher, HyperSpin won't find it.
The transition tool changes system inis to get it working.
The simplest fix would be to use HS 1.4 which will see RocketLauncher.
Might sound lame but isnt 1.4 just the exe? How dose that change the ini's? Im just trying to get this figured out.
Thanks for all the responses
Yes HS 1.4 is just an exe but it has been made to work with RocketLauncher so there is no need to mess with the system ini's. I assume you have read what Jeremy posted, so it will be up to you if you want to use the 1.4 beta.
Alright still cant get rocketlauncher to sync up. Im using hyperspin 1.4.
Heres my log.
06:37:19 PM |  HyperSpin Started
06:37:19 PM |  Going windowed mode
06:37:19 PM |  Checking for updates
06:37:19 PM |  Update Check Complete
06:37:19 PM |  Startup program unavailable
06:37:19 PM |  Error intializing joysticks
06:37:19 PM |  Menu Mode is multi
06:37:19 PM |  Loading Main Menu.xml
06:37:19 PM |  Main Menu.xml successfully loaded
06:37:20 PM |  Main Menu wheel loaded successfully
06:37:23 PM |  Loading MAME.xml
06:37:24 PM |  Main Menu.xml successfully loaded
06:37:25 PM |  MAME wheel loaded successfully
06:37:35 PM |  Launching Game
06:37:35 PM |  Using HyperLaunch
06:37:35 PM |  Getting Launcher path
06:37:35 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
06:37:35 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
06:37:35 PM |  Running Launcher
06:37:35 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "dsmbl"
06:37:49 PM |  Loading Main Menu.xml
06:37:49 PM |  Main Menu.xml successfully loaded
06:37:50 PM |  Main Menu wheel loaded successfully
06:37:52 PM |  Exit program unavailable
06:37:52 PM |  Quiting Hyperspin
06:37:52 PM |  Bye!
And heres my settings ini
[Main]
Menu_Mode=multi
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Hyperlaunch_Path=C:\Hyperspin\RocketLauncher.exe\
Anything anybody notice is wrong?
Thanks alot
your Hyerspin is still uisng Hyperlaunch
witch is Hyperlaunch 2  not rocketlauncher.
I would suggest you start over on a fresh install,  this time around place rocketlauncher in its own folder.  Do not do what Austin does in his tutorial.
your path to rocketlauncher should be
C:\Hyperspin\RocketLauncher\RocketLauncher.exe
your Hyperspin folder will be much cleaner
without the \ end.
Edit:I also recommend a separate folder, for future updates is better.
Alright did a fresh install, took ideas from all above comments and NOW IT FINALLY WORKS!!!! Have no idea what i did diffrently from my last 2 installs but it all flowed smooth like it should have from the beginning.
Thanks to all for your help.
