bigcam Posted May 29, 2015 Posted May 29, 2015 hi all of a sudden my themes are moving choppy especialy when artwork fades in it stops and then just appears. my computer is fine this just started happening. can someone give me a hand with this please. thanks
SIMPLYAUSTIN Posted May 29, 2015 Posted May 29, 2015 It can normally be due to read speeds from you HDD. Are you doing something with your PC, have virus scanner kicking in or maybe just one of those "PC moments"? Simply Austin's YouTube
bigcam Posted May 29, 2015 Author Posted May 29, 2015 no im only using1.3.2 not sure thats it i started my computer over today and the same thing happened ive got 3.73 ghz processor and 4gb ram. i just started happening recently. i omly have 13gb left on hd could tht be it? thanks
newoski Posted May 30, 2015 Posted May 30, 2015 This is a problem in having as well. Upgrading to 1.4 solves the problem. Downgrading brings it back.
bigcam Posted May 30, 2015 Author Posted May 30, 2015 can i just swap the 1.4 exe or do i have to do everything all over?
justice999 Posted May 30, 2015 Posted May 30, 2015 no im only using1.3.2 not sure thats it i started my computer over today and the same thing happened ive got 3.73 ghz processor and 4gb ram. i just started happening recently. i omly have 13gb left on hd could tht be it? thanks HS 1.3.0.0 will solve this problem, I had the same issue. You need HyperLaunch Forwarder to downgrade or you can upgrade.
