Where are all the tutorials?
I'm editing this since I got some help in the Chatroom (Wonderful feature BTW)
My original issue was resolved, but I guess I'll leave this up in case anyone finds an answer, that way others can search this.
Basically I was hoping to find some sort of comprehensive tutorials for Hypertheme, in english. ( I keep finding a spanish video on youtube )
  • 4 weeks later...
Just to let you know there are a lot of tutorials that don't ever end up working because there are always steps that have been left out. The best way to set up hyperspin within about 2 hours is to use LNK files. These files are only needed for pc games which in my opinion are the hardest to set up because everyone used hyperlaunch HQ/ AKA Rocketlaunch. I have set up any system I want without the complicated and not so useful programs mentioned above. If you don't use them then it is really easy to setup hyperspin. I will be creating a video in about 2 weeks that will take you step by step and will only take about 30 minutes to complete. FORGET ROCKETLAUNCH, it seems that whoever created this program intentionally made it very complicated and frustrating to use.Don't believe me then try it for yourself. The fact of the matter is this is probably the first time you will ever see a post like this because everyone thinks you need rocketlaunch to work when that is not true at all everything you need is in the hyperspin folder. Thats why rocketlaunch is not included with hyperpsin. You dont need it.................. Look for Hyperspin the easy way! on you tube in about 2 weeks. see ya , Im gonna change how people use the hyperspin program. Its time people are able to install and use hyperpsin..............the easy way!........within 30 minutes........fully working and functioning!
If your shortcut lnk files have the same name as the games in your database, you can drop shortcut lnk files on the target button in the PCLauncher module settings window and RocketLauncherUI will add all your pc games in one step to the matching game of the same name in the database.
Even using your easy method you would still need to setup emulators one by one. There is no 30 minute solution unless you use only a few emulators.
Anyways your post was off topic because the original poster was looking for how to make themes probably with swf files. This is not a question about how to get hyperspin to work. It's a question about how to theme hyperspin and change it's appearance. making things work is not the same as changing the look of hyperspin.
I do agree that tutorials or links to tutorials for the normal user to do advanced theming features like custom flash animations for themes would be appreciated.
Question for you all, say I create a default system theme and I want artwork 1 to display each file name that matches the current game, how do I do that? I tried adding art 1'and it's always the same file. Is there a way to do this? If not, I'll probably just have to create a theme for each game with the only difference being art 1
You have to tick "don't include in output" if you'd like it to be interchangeable. It's done while compiling the theme in HyperTheme
Instagram : baddeolv
Facebook : Brian Addeo
