gr0bda Posted June 6, 2015 Posted June 6, 2015 Can't find anywhere how to achieve this. I would like to keep windows and HS on SSD C:\ drive but of course due to limited size of SSD I'd like to link the media to another drive. How can I do it? Which ini to alter (if any)? I have HS 1.3 with RL 1.0 If you going to link to something please point out to the part that deals with that specifically not a 2 hours long setup video that the step I'm looking for is buried somewhere at 1h 39min and I'll miss it because I'm snoring by then. I have a goldfish attention span and I'll zone out before I'll ever get there. Thank you!
gr0bda Posted June 6, 2015 Author Posted June 6, 2015 Really!?! So is it at all possible to use SSD with Hyperspin? Let's assume worst case scenario that I am some kind of a nut that has all the time in the world on hands to put this together. If I'd collect artwork for every media imaginable, there is now way that will fit on a 128GB SSD with a system already on it. I doubt it would even fit on 256GB (anything above that it's rather expensive at the moment). Or am I wrong in my assumption? Btw about the videos how do I link to videos on another drive?
JayC Posted June 6, 2015 Posted June 6, 2015 To link the videos...just open HyperHQ and select "Wheel Settings" then select your system and click on the Video Tab. If you use HyperSync you will have to select "use alternate video folder" from the main options! I can fit my systems fine on a 120GB SSD if I want. Depends on what kinds of media you want. If you just need the basics ie, Wheels, Themes, Carts, Pointers and Sounds then you can fit a lot of stuff since it's just PNG's basically. If you wan't everything else like manuals and that kind of stuff you will probably run out of space at some point, but most of the stuff is pretty small in size.
gr0bda Posted June 7, 2015 Author Posted June 7, 2015 To link the videos...just open HyperHQ and select "Wheel Settings" then select your system and click on the Video Tab. If you use HyperSync you will have to select "use alternate video folder" from the main options! I can fit my systems fine on a 120GB SSD if I want. Depends on what kinds of media you want. If you just need the basics ie, Wheels, Themes, Carts, Pointers and Sounds then you can fit a lot of stuff since it's just PNG's basically. If you wan't everything else like manuals and that kind of stuff you will probably run out of space at some point, but most of the stuff is pretty small in size. Thank you about the video folder Regarding the media though just to be sure. Let's assume worst case scenario and let's say only what you mention minus anything out of ordinary like manuals. Would EVERY system imaginable including pc, steam etc still fit on 128/256GB HD SSD?
32assassin Posted June 7, 2015 Posted June 7, 2015 If you really wan't "every" system; I would worry more about your 4 TB drive. A full set of COMPRESSED PS2 ISOS is allot more than 4 TB.
gr0bda Posted June 7, 2015 Author Posted June 7, 2015 Thank you for clarification. No I'm not planning to have every system or even anywhere close to that. Just wanted to get an idea on how to plan everything and what is the approximate size of HS fully loaded on HD. Thanks again.
ninja2bceen Posted June 7, 2015 Posted June 7, 2015 I was thinking about an sd card bug maybe I shouldn't? So you don't see any additional speed ups vs a external hard drive on the media? Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted June 7, 2015 Posted June 7, 2015 Thanks. Things work fine but figured an sd card could add speed but sounds like I should just save the few bucks Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
dsync89 Posted June 8, 2015 Posted June 8, 2015 This will perhaps the future approach that I will take after I got my arcade cabinet The most ideal solution that I would do is simply create a hardlink in your HyperSpin root folder pointing to the Media folder that you stored in an external drive.
