How do I paste my RL log here?
demonseed
Before anyone comments, I am an idiot. Now that being said, can someone please explain to me how I can paste something I copy from notepad into this new topic or reply box? I have cut my RL log and can not get it to paste here? I tried the three boxes above (paste from word etc) but its not working.  Can someone please help out an idiot? I would appreciate it.
thanks
Jim
Could be the same issue I had. This site doesn't seem to work with Internet Explorer for some reason (which seems crazy to me).
But if you click the button at the top left corner of the text box it should work. Although all the useful buttons will then quit working to you'll have to type html tags like
[code][/code] and {quote][/quote]
EDIT: I said top right corner, but it's the top left. Corrected.
Yep, I struggled with that too - so now I just use chrome for replying - the buttons in advanced reply options work then.
Sent from my SM-G925F using Tapatalk
Pastebin.com and post the link here is a nice way.
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Pinball FX2
Hyperlaunch_Path=O:\RocketLauncher\RocketLauncher.exe
The above was posted in IE using the code tags button and pasting the info into the box that appears once pressed. Although code tags still don't work as they used to on the old site so it's best to use pasterbin.
I use mostly use Opera and that is fine also. If you want to add pictures from your machine instead of a URL then use the red "More Reply Options" button next to the "Post" button.
Cool. But be aware code tags should give you a scrollable box not a wall of text. If you get a wall of text then try to use pastebin.
The admins do know about the problem.
I installed Chrome a couple weeks ago just so I could download from Mega, but 3 days ago Chrome started crashing and now it won't even open. Uninstalled/reinstalled numerous times with no luck.
Starting it opens a blank white page, no tabs at the top then after a minute says "not responding" and you have to force it closed or kill it in task manager.
My experience is that it's a ******* lame browser.
