Administrator
    1,261
    27
Everything posted by fr0stbyt3
  1. To confirm. You went to control panel and uninstalled HQ. Then installed 2.0.33. Then updated to 2.0.34? The fix is only applied if you use a newer installer
  2. Changed Severity to 4 - Low Priority Changed Current Status to Investigation Changed Development Feedback to Those delete cache like what emulators are available or system cache for add system. They do not remove media. To do this, use the refresh option and select delete. Is there a use case for clearing media?
  3. Changed Severity to 2 - High Priority Changed Current Status to In Work
  4. We're going to track them together for now. If I find that its not related i'll split it up
  5. Changed Current Status to Fixed
  6. Changed Development Feedback to NOTE: Video files like FLV are not supported
  7. Changed Severity to 2 - High Priority Changed Current Status to In Work
  8. Changed Severity to 2 - High Priority Changed Current Status to In Work
  9. Changed Severity to 3 - Medium Priority Changed Current Status to Investigation
  10. Changed Severity to 3 - Medium Priority Changed Current Status to Investigation
  11. Changed Fixed in Version to 2.0.34
  12. Changed Severity to 1 - Highest Priority Changed Current Status to Fixed Changed Fixed in Version to 2.0.27
  13. I can tweak this a little but its needs to have some level of sensitivity to allow for all interactions work.
  14. Changed Severity to 1 - Highest Priority Changed Current Status to Investigation Changed Fixed in Version to 2.0.34
  15. Changed Severity to 1 - Highest Priority Changed Current Status to Fixed Changed Fixed in Version to 2.0.34
  16. Changed Severity to 2 - High Priority Changed Current Status to Fixed Changed Fixed in Version to 2.0.27
  17. Changed Severity to 4 - Low Priority Changed Current Status to Investigation Changed Development Feedback to Does this show correctly in the wheel manager?
  18. Changed Severity to 3 - Medium Priority Changed Current Status to Investigation
  19. Changed Severity to 1 - Highest Priority Changed Current Status to Fixed Changed Fixed in Version to 2.0.34
  20. Changed Severity to 1 - Highest Priority Changed Current Status to Deployed Changed Fixed in Version to 2.0.34
  21. HQ System - view type persists Videos - videos were downloading to the wrong directory in some configurations Plugins - HS should update on startup UI - don't allow user to launch HS until its installed Wheel Manager - when setting something to not visible, the UI didn't persist MAME - refresh disabled for now until custom system can be made specifically for MAME Media Overrides - You can now override media for most media types. You can find the new overrides in [installDir]\media\Systems\_overrides Using items in these folders take priority over the media in the HS managed directories. In a future update, this will also allow video marquee and video themes. HS Media override support Bug fixes for Menu Keyboard service fixes
      • 9
      • Like
      • Super Like
  22. fr0stbyt3
    Steam
    This shows 81 games for me. Which is mostly correct because you have a few apps in there. Can you please delete steam and add it again?
  23. I think someone else found this too. We're on it!
