DarkTemplarGS
    75
Everything posted by DarkTemplarGS
  1. Yes, it was a clean install for all instances. The thing is, I shouldn't have to do a clean install every time there's an update. The update itself should not break something simply because it is overwriting files and changes the process.
  2. Still having the same media issues after upgrade to 2.0.60.
  3. I have recently upgraded to version .60. The version before that I was having problems with just the auto import of ROMs for MAME, but now I'm seeing it for all systems. Based on the logs, it looks like the tasks are completing, it's just the progress bars are not completing and closing. I've turned off Auto Import for the time being, but that's just a work around to make the progress bars not show up. Please see the image below for reference.
  4. Still having media issues after upgrading to 2.0.58.
  5. Just wondering if there's going to be any resolution to this? I see it's been viewed quite a bit, but in two weeks, no admin has responded to say it's being looked at. I hope this gets some resolution soon. This makes QA testing quite difficult not knowing if this is affecting other aspects of the application.
  6. Exactly! With some new coding, an option to set it to on or off, and a settings page once it's turned on.
  7. After this last update to HyperHQ, version 2.0.54, the media does not display in HyperSpin. The clear logos are missing from the wheel and none of the videos play. I have tried deleting all media and reinstalling using the HyperHQ tool, and I cleared all caches. But when I start HyperSpin, all of the wheel art is text and the videos are the default TV static video. All of the videos and logos are in their corresponding media folders after they were downloaded from EmuMovies by HyperSpin. It appears they're not being associated to the games properly.
  8. Where did downloads for user created content go? Like the current MAME NO NAG files?
  9. Is there any way that the functionality of HyperSpeech can be incorporated into HyperHQ for use in HyperSpin? HyperSpeech 1.0.1.zip
  10. In the previous version of HyperSpin, you could either select the video game sounds or the "click" sound when cycling through the wheel. Is there anywhere in this version of HyperHQ to change that setting? I find the video game sounds to be a little annoying after a while.
  11. Is there anywhere in the setting to set the amount of time HyperSpin waits before spinning?
  12. After moving to a system in the system wheel or a game in the game wheel, the wheel will disappear. Is there any way to make the wheel stay showing?
  13. HyperHQ version .49 fixed the issue. THANKS!!!
  14. It's any version of MAME. I tried multiple versions.
  15. I am having the same problem. However, mine appears to finish, but apparently doesn't. This is after my last clean install and upgrade download.
  16. I believe that it would be extremely helpful to see the version number displayed somewhere on the main screen.
  17. I completely deleted everything to do a clean install of the latest version. When I downloaded and installed HyperHQ, I rebooted and checked to see if the version was up to date. It said there was a new version so I downloaded it. Supposedly I am running 2.0.45. When I try to add MAME as a system. It goes through all the normal procedure up to the point where it's unpacking and installing. At that point it just sits there churning. The insytall window does not pop up like it used to and I checked in the HyperSpin Emulator folder and nothing is happening. The MAME .exe is still sitting in the _temp folder in the C:\Program Data\HyperSpin\emulators directory. No log for HyperHQ so I can't attach it. So, DEAD IN THE WATER...AGAIN.
  18. Ok guys. I finally figured out what the issue was and HyperSpin is now functioning. First I'll let you know what the issue was, then I'll offer some recommendations on how to help with something like this in the future. The issue was that I am using an older machine. I connected my DVI to HDMI cable to the video port on the motherboard so I could update my NVIDIA graphics card drivers. The problem was, that I never put the cable back and the onboard graphics chip is not strong enough to handle HS new HD display. Once I moved the cable to my graphics card, HyperSpin was running like a champ. Now, I would have never even thought to check that until I went back through the steps that I went through to get this computer ready to use it exclusively for testing HQ and HS. What I would like to recommend is error pop ups. HS was obviously erroring out or just getting stuck, but having something pop up stating that was occurring would be an extremely helpful tool in the future. Another thing that kind of threw me, is the HS log only contained three lines in it (please see log I attached earlier in the thread. Is the logging not set to a higher level and that's why there's only the three lines? Can you please look into that when you have a chance? I know you guys are busy, but I feel these two things would go a long way in resolving issues without relying on you all so much.
  19. Provide options during the uninstall process: "Light" uninstall: Runs the process as it is now. This leaves some files and directories in place that are used by HyperHQ and HyperSpin when it is re-installed. "Full" Uninstall: Removes all files and directories associated with HyperHQ and HyperSpin. Deletes HS folder from ProgramData. Deletes .HyperHQ and .Hyperspin from the C:\Users\*user* folder. Deletes HyperHQ and Hyperspin folders from the C:\Users\*user*\AppData folder. This would allow the option of a true clean install when HyperHQ is re-installed.
  20. Here is my HS log showing little to nothing occurring when I start it. hyperspin-2025-02-03-02-50-41.log
  21. When performing a clean install of the newest version of HQ (2.0.39), the tile showing the extraction of the HS core just hangs there spinning. As far as I can tell, the extraction is complete when looking in the HS folder.
  22. Ok. First, a big thank you to @thatman84 for giving me the location of the logs. After reviewing the ROM import process in the logs, it appears that part of the issue of not all ROMs being imported, is because of the 2-player priority selection when setting up the import parameters. The import process is rejecting all 3-player and 4-player games, even though almost all of them can still be played by 2 players. It seems like instead of this "prioritizing" the games it is filtering and only importing 2-player games. I feel there should be an option that allows that parameter to be ignored. The rest are being filtered out because they are "imperfect". I feel here there should be an option to allow us as users to either skip imperfect ROMs or allow them to be imported. I know that several of the ROMs are imperfect, but most still work. This could also be a possible mismatch of ROM to MAME version. Please let us know if that's an accurate deduction. Another issue I see in the log is, only the first letter of the game name is displayed on the line stating it was "Filtered Out". I feel it would be beneficial to display the entire game name so we can go out and get the latest version of the ROM, if I am correct in the fact it was filtered out because of the ROM version and MAME version mismatch. I hope this adds some clarity as to what the issue is. I know I feel better. HyperHQ-2025-01-31-05-36-24.log
  23. Ok. Figured out how to get rid of the folders in the HyperSpin/Emulators folder and keep them from coming back. Just delete them from the Emulators section in HQ, then delete the folders from the HyperSpin/Emulators folder. HQ will no longer see them as installed when you go to add MAME again. HyperSpin still will not run. Still loads, but won't run. I'm now going to try to uninstall HQ and reinstall to see if that changes anything.
  24. I accidentally had Hyper HQ install a second version of MAME and now HyperSpin won't launch. It reaches the end of its loading screen, but won't launch. I've tried uninstalling and reinstalling HQ, but it doesn't appear to do a clean uninstall and clear all the settings, so after reinstall it recreates both MAME version folders and the RetroArch folder in the Emulators directory in HS. I would look through the log to try to resolve this myself or I would attach it here, but I can't find any logs anywhere. This computer is a clean install of Windows 11 and the only things installed are Hyper HQ, Photoshop and Chrome.
  25. Where do we submit artwork for wheel art, bezels or marquees?
