71
Everything posted by Aorin
The King of Fighters '97 (NGM-2320) - kof97 (MAME)
Aorin reviewed BadBoyBill's file in Game Themes (4:3)
Version 1.0
1,704 downloads
This pack contains Main and Default themes with three options each, PSX, Xbox and Arcade Buttons (Widescreen 16:9) It comes with wheels, letters, pointer, settings and database, everything is widescreen ready (16:9) Notes: Sony PSP Minis.ini goes under the main Settings folder, which are the HyperHQ settings, it will stylize the letters and position them to the right spot, also will deactivate unneeded special arts. In case special arts are still showing, delete, rename or move the special folder. Sony Playstation Minis.ini Sony PSP Minis.xml -
Results are now smooth thanks for your script and zero's. Check my last post here http://www.hyperspin-fe.com/topic/11681-new-themes-all-aspect-ratios/page-8 I didn't forget to give you guys the credits for this improvement. Thanks again!
Perfect Avar, tomorrow morning I'll try that, didn't know the script could be edited that easily! Thanks for that!
Dark, thanks for your script it's working fine here, except my resolution is 1920x1200, and it results in a black bar in the right. Can I easily edit this script here? If not can you edit it to work for 16:10 resolutions? Thanks!
Glutch, I was using your script for months now without any problem, but today something weird happened, I don't know what happened, but now it's not working anymore, it gives me this error. My Settings ini [Main] Last_System=SNK Neo Geo CD [LEDBlinky] Active=True [startup Program] Executable=HyperSpin Startup Script.exe Working_Directory=K:\HyperSpin\ WinState=NORMAL [Exit Program] Executable=HyperSpin Startup Script.exe Working_Directory=K:\HyperSpin\ WinState=NORMAL [P1 Joystick] Enabled=False Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 Joy=0 One thing that I should point out is that strangely today I had to point Daemon Tools and some other third party programs, such as xpadder because these settings were blank, and now I get the above error, is it easy to fix? It's a windows 8.1 64 bits machine. Thanks Glutch. EDIT: I didn't notice Glutch hasn't been active since october, so I had to try solving this myself, and I managed to. What I noticed is that it had something to do with the main settings of Hyperspin, that Settings.ini that is under Settings folder in the root HS folder, I have a backup of the Settings folder, so I copied that settings.ini from my backup and I don't get the above error anymore, now the script works flawlessly. For those who face this problem, here is my settings.ini, it can help you if you face the same problem as I did. [Main] Menu_Mode=multi Single_Mode_Name=Sony Playstation Minis Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Sony Playstation hyperlaunch_Path=K:\HyperSpin\RocketLauncher\RocketLauncher.exe [Resolution] FullScreen=true Width=1920 Height=1200 Scanlines_Active=false Scanlines_Image= Scanlines_Scale=3.7 Scanlines_Alpha=0.1 [Optimizer] CPU_Priority=high Quality=BEST Image_Smoothing=true Animated_Backgrounds=true Inter_Backgrounds=true Level1_Backgrounds=true Level2_Backgrounds=true Level3_Backgrounds=true Level4_Backgrounds=true Special_Backgrounds=true Wait_For_Special=false Animated_Artworks=true Level1_Artworks=true Level2_Artworks=true [introVideo] Use_Intro=false Stop_On_Keypress=true [sound] Master_Volume=70 Video_Volume=70 Wheel_Volume=60 Interface_Volume=100 [AttractMode] Active=true Time=300 MaxSpinTime=5 HyperSpin=true Wait_For_Video=true [Keyboard] Key_Delay=true [P1 Controls] Start=13 Exit=27 Up=38 Down=40 SkipUp=37 SkipDown=39 SkipUpNumber=70 SkipDownNumber=86 HyperSpin= Genre=71 Favorites=76 [P2 Controls] Start=69 Exit=81 Up=87 Down=83 SkipUp=65 SkipDown=68 SkipUpNumber=74 SkipDownNumber=77 HyperSpin=88 Genre=72 Favorites=90 [P1 Joystick] Enabled=false Joy=0 Threshold=60 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_6 SkipDownNumber=Button_5 HyperSpin=Button_6 Genre=Button_10 Favorites=Button_9 [P2 Joystick] Enabled=false Joy=1 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [Trackball] Enabled=false Sensitivity=90 [spinner] Enabled=false Sensitivity=90 [startup Program] Executable=HyperSpin Startup Script.exe Paramaters= Working_Directory=K:\HyperSpin\Utilities\Hyperspin Tools\HyperSpin Startup Script\ WinState=NORMAL [Exit Program] Executable=HyperSpin Startup Script.exe Paramaters= Working_Directory=K:\HyperSpin\Utilities\Hyperspin Tools\HyperSpin Startup Script\ WinState=NORMAL [LEDBlinky] Active=false Path=\ [HiScore] Active=true Y=550 Delay=2
Thanks mate, that's all I needed to know.
