mar00n Posted January 11, 2016 Posted January 11, 2016 Anyone got this working? I can't find any information on this running on Hyperspin. My Hyperspin system so far: Atari 5200 100% -Atari Jaguar 100% -Atari Lynx 100% -Gameboy 100% -Gameboy Color 100% -NEC TurboGrafx- 16 100% -Nintendo 64 100% -Nintendo Entertainment System 100% -Nintendo Gameboy Advance 100% -Nintendo Virtual Boy 100% -Sega 32X 100% - Sega CD 100% -Sega Game Gear 100% -Sega Genesis 100% - Sega Master System 100% -Sega Model 2 100% -Sega Saturn 100% -SNK Neo Geo 100% -SNK Neo Geo Pocket Color 100% -Super Nintendo System 100%
Styphelus Posted January 11, 2016 Posted January 11, 2016 Nope. There aren't any proper emulators for it.
Rotgut Posted January 11, 2016 Posted January 11, 2016 Nope. There aren't any proper emulators for it. What a trip to read this. I guess I assumed that by now, someone found a way. Must be technically very difficult to pull off, I'm guessing...?
mikeis300 Posted January 12, 2016 Posted January 12, 2016 ill have to double check my setup, but im sure i have two if not three emulators that run jaguar cd. RetroArch being one of them. i do know that not every game works on the emulators. but using project tempest v.95 i was playing primal rage, world tour racing and the one where you can be alien, predator or the marine. let me know if you need help with anything specifically in the setup
mar00n Posted January 13, 2016 Author Posted January 13, 2016 Those games are not for the Atari Jaguar CD - Just the Jaguar. My Hyperspin system so far: Atari 5200 100% -Atari Jaguar 100% -Atari Lynx 100% -Gameboy 100% -Gameboy Color 100% -NEC TurboGrafx- 16 100% -Nintendo 64 100% -Nintendo Entertainment System 100% -Nintendo Gameboy Advance 100% -Nintendo Virtual Boy 100% -Sega 32X 100% - Sega CD 100% -Sega Game Gear 100% -Sega Genesis 100% - Sega Master System 100% -Sega Model 2 100% -Sega Saturn 100% -SNK Neo Geo 100% -SNK Neo Geo Pocket Color 100% -Super Nintendo System 100%
pinsanity Posted January 14, 2016 Posted January 14, 2016 Baldies, Primal Rage and maybe one or two others works with the Project Tempest emulator. Can't remember which ones as haven't tested since I set it up over a year ago. The rest just crash.
ninja2bceen Posted February 12, 2016 Posted February 12, 2016 Does anyone have Img/ccd/sub based files that are zipped working for jaguar cd? I can't figure out the configurations to test the few working games in rocketlauncher Any help is great Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Guest Posted February 12, 2016 Posted February 12, 2016 Does anyone have Img/ccd/sub based files that are zipped working for jaguar cd? I can't figure out the configurations to test the few working games in rocketlauncher Any help is great I've got most Jaguar CD games and its setup in RL working fine, at least for the two games that do work. What do you need specifically? Sent from my iPhone using Tapatalk
Guest Posted February 12, 2016 Posted February 12, 2016 Project Tempest is the emulator to use. Sent from my iPhone using Tapatalk
ninja2bceen Posted February 12, 2016 Posted February 12, 2016 I have a pd set that are bin/cue and Img/ccd/sub 7zip files. The cues work but the ccd ones don't. I have skip checks to rom only and the cue works. How do you get the ccd working? Maybe I need a different set? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
abodetti Posted May 29, 2017 Posted May 29, 2017 Emulator only uses cdi format. So you'll need to convert. The PD set isn't helpful right out of the gate.
abodetti Posted May 29, 2017 Posted May 29, 2017 I was able to get Project Temptest to load games on its own. But when I try to load them through RoketLauncher literally nothing happens. Doesn't even kick off the fade then give me an error. It does nothing. Any tips?
badboo Posted May 31, 2017 Posted May 31, 2017 On 5/29/2017 at 7:36 PM, abodetti said: I was able to get Project Temptest to load games on its own. But when I try to load them through RoketLauncher literally nothing happens. Doesn't even kick off the fade then give me an error. It does nothing. Any tips? Oh man, good luck with this because I would need it too. I have the Jaguar CD on my hyperspin as a decoration only. I am now thinking of removing it since there is sooo little information about it. I am just giving it more time before letting it behind lol. So I am interested if someone has a solution.
abodetti Posted June 1, 2017 Posted June 1, 2017 I actually got it to work no problem with project temptest inside rocketlauncher. My original issue was that when i exited the emulator it still ran on the system. But once i closed it all out through task manager everything worked perfect from then on. Only a couple of games actually work - like primal rage - but i got it up and running
badboo Posted June 6, 2017 Posted June 6, 2017 On 5/31/2017 at 9:18 PM, abodetti said: I actually got it to work no problem with project temptest inside rocketlauncher. My original issue was that when i exited the emulator it still ran on the system. But once i closed it all out through task manager everything worked perfect from then on. Only a couple of games actually work - like primal rage - but i got it up and running Really you did? any hint how you made it work? or is it the only those 2 games work only?
abodetti Posted June 7, 2017 Posted June 7, 2017 16 hours ago, badboo said: Really you did? any hint how you made it work? or is it the only those 2 games work only? i think only 2 or 3 games work. Didn't require any special tinkering. Just use priject temptest and the project temptest module in rocketlauncher. Test everything with primal rage since we know that works.
badboo Posted June 7, 2017 Posted June 7, 2017 3 hours ago, abodetti said: i think only 2 or 3 games work. Didn't require any special tinkering. Just use priject temptest and the project temptest module in rocketlauncher. Test everything with primal rage since we know that works. Well, I think it is better than nothing then lol Thanks
