How to exit Dolphin emulator
jcrowley30
I have tried looking it the settings but I am unable to figure out how to exit without a keyboard.  I am using an xbox 360 controller. Any ideas?
Use a key mapper like joytokey or xpadder to map a button on the controller to the key that exits the emulator.
Or set up a button combo in the "Exit Emulator " section of RLUI. I have the Start & Back buttons mapped, I hold them down for 2 seconds.
I thought I had that mapped already. I will have to double check. Thanks
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Did I read correctly that with the new version of Dolphin, RocketLauncher doesn't close it properly?
Hopefully that is now fixed, but I haven't updated it in a while.
  • 3 months later...
Hi giga,
I updated my HS and RL this week and Dolphin is hanging on exit. I get a black screen, pc totally totally locks up and I have to reboot.
I've turned exit fade to - false, as simply Austin advised, I'm running 6089 version of dolphin(I think?, cant get to my machine right now)
Gfx card is gtx670
Any help would be great, I want to get GC and Wii running again
Thanks
Some releases make it impossible to exit when using certain Display settings.  It depends on the build of the Dolphin to depend on if it plays ball with the module correctly.  You have a few options...
 - Change the display options
 - Change the build of the Dolphin your using
 - Edit the Dolphin Key settings to match the exit key you use.
