Can't launch a game from Hypersearch
Rlauncher 1.0.0.3
Hyperspin 1.4 beta 015
Windows 8.1 (hypersearch, rlauncher, hyperspin all set to run in admin mode)
I'm using basically all the default settings.
My hyperspin is set to <ENTER> to select items and launch games.  However, once I perform a search in Hypersearch and select the game I want to run, ENTER doesn't launch the game.  Enter works for everything else though.
  • 3 weeks later...
I have the same problem.
If you look at the hypersearch debug you will see " Launching: E:\HYPERSPIN PROJECT\RocketLauncher\RocketLauncher.exe\Hyperlaunch.exe "Super Nintendo Entertainment System" "Street Fighter II Turbo (USA)"
That's the problem hypersearch wants to use hyperlaunch even if you specify the RocketLauncher as a launcher in the hyperspin config.
Does somebody has found a solution?
Richard
Did you set your path in the hypersearch configuration and also make sure you had one of the newer versions maker to work with rl.
Yes i have set the path in hypersearch  <add key="HyperspinPath" value="E:\HYPERSPIN PROJECT\HYPERSPIN"/> and i use the 1.4 beta version of hyperspin.
I have investigate a little bit and it seems that hypersearch has the path to the launcher hardcoded it automaticaly search for hyperlaunch. (it is written in this topic http://www.hyperspin-fe.com/topic/8816-rocketlauncher-10-release/?hl=hypersearch#entry147958)
Do you have hypersearch working with rocketlauncher?
i don't have this line in my config file so i add it.
Now i have in my log at the startup of hypersearch "02:23:39  HL path: E:\HYPERSPIN PROJECT\RocketLauncher\RocketLauncher.exe"
But the game are still not working, i still have "02:24:30  Launching: E:\HYPERSPIN PROJECT\RocketLauncher\RocketLauncher.exe\Hyperlaunch.exe "Super Nintendo Entertainment System" "Street Fighter II (USA)""
02:24:30  System.ComponentModel.Win32Exception (0x80004005): Le fichier spécifié est introuvable (file not found)
Could you tell me where you download your version?
how do i set up hypersearch?
do i just put it in the utilities folder?
needs some instructions cus ima scrub
and when i go in the folder and launch it i get a hypersearch has stopped working pop up from windows
  • 3 weeks later...
Hypersearch keeps crashing with Windows 10.
I'll do a search, it will show the results of the search and immediately after an error windows pops up saying hypersearch has stopped working.
