Bliss Box 4-play compatibility
brudibru
  • Replies 258
Intigod can you test?
Tapatalk signature
Sorry. I'd love to test it out but I'm extremely time poor atm.
Give me a couple weeks.
It appears to only happen if I use two ps2 or one ps2 and n64 controllers. Do you get the same thing?
Plug in bliss
Plug in ps2 in port 1 press reset
Plug in n64 in port 2, press reset
Port 2 disappears
If you do the same thing above but do the following first it works
Plug in bliss
Plug in snes in port 2, press reset
Unplug snes from port 2
It works
  • 4 weeks later...
Does anyone here know anything about  Steam Link in the way of working with the 4-play.
I don't own one but I think it is using the Steam Streaming system to play games on deported devices.
I tried this system in the past but I ran into a wall trying to make my controllers work (a G27 wheel, a Saitek X52 joystick) so I gave up quickly.
Might be because it works only with xinput devices but I'm not sure.
Is there a set in stone method to getting all this to work?  At times I can get port 1 to read a controller for a few minutes but it cuts out after a while.  As of right now I plug it in, windows 10 tells me it malfunctioned, 3 ports show up 1, 2 and 4.  Port 3 when I try to flash it says no hex file or directory found.  I wish I would've seen the headaches coming and I would've gone another route for a controller setup
Which method have you followed for flashing the blissbox? My system works perfectly and I have tested it on windows and on my raspberry pi.
Look back a few posts, I had the exact same problems. I wrote a lengthy tutorial when really it's just a few steps (I included the fils I used) but I think the slow love and the time it takes you to do each step will give it enough time for you to set it up. It's long but gets around ur issue you have
