Deezdrama Posted December 10, 2015 Author Posted December 10, 2015 But i went through the automatic profiler...so it asked me to "push key for x" etc....and thats the way it did the profile. Also when testing it in the same menu with the test ahk option.... it worked as expected, but then when loading the game all keys are still default. Ill try reversing them when I get home though.
Deezdrama Posted December 11, 2015 Author Posted December 11, 2015 I tried reversing the keys in the ahk profile ... it made the ssed_launcher.exe vanish. Its not in the game folder anymore and changing the ahk profile is all it could be. Maybe I shouldnt be running it from the launcher.exe but it wont load with game.exe or the game.bat file Cant believe how frustrating this game is being to setup keys for
Metalzoic Posted December 11, 2015 Posted December 11, 2015 I tried reversing the keys in the ahk profile ... it made the ssed_launcher.exe vanish. Its not in the game folder anymore and changing the ahk profile is all it could be. Maybe I shouldnt be running it from the launcher.exe but it wont load with game.exe or the game.bat file Cant believe how frustrating this game is being to setup keys for You're right, the "+ add new keymap entry" icon doesn't work right. The instructions are worded backwards. I've never used it before as I always just manually type in what it should be. I'll tell DJVJ. I don't see any possible way that the AHK keymapper could make your ssed_Launcher file disappear. You're just typing some text into a RocketLauncher AHK profile. It isn't even connected in any way to Hyperspin or your emulator/game/roms folders in any way. Bummer that you're having weird trouble. Should have only taken a few minutes that way. Launching the game from the launcher.exe won't run the game with any of the resolution or settings you fixed.
Deezdrama Posted December 11, 2015 Author Posted December 11, 2015 I dont know either but have been stuck on this game for weeks....messing with it for an hour or so everyday after work trying to get the keys mapped and the launcher.exe only dissapeared after flipping the keys on the ahk profile. I reversed them,saved it,launched, and got an error that the launcher.exe could not be found. I looked in the game folder and it was gone. I have 2 different file sets for the game. One set will run from the bat but nomatter what I do I cant get the res to change, the other set...the res works fine but having these issues. Im about to give up on it. I still have a couple more wheels to setup and a bunch of pc games to figure out controls for.
Metalzoic Posted December 11, 2015 Posted December 11, 2015 Just remake your SSED_Launcher by re-running SShodown through the Arcade PC Launcher, re-set your res and settings, launch the game to update the SSED_Launcher file (I believe). Then just map the controls correctly (sounds like you already did). That should hopefully only take a few minutes and you should be solid. Ah, just remembered that you couldn't get your game to run through Arcade PC Launcher for some reason.
Deezdrama Posted December 13, 2015 Author Posted December 13, 2015 Running the game through arcadepclauncher would not create a new launcher.exe file nomatter what I tried. Started all over will a freshly extracted set of game files. This time I made the AHK game profile putting new key first then :: then old key When launching the game from RL the AHK mappings are not being used for whatever reason and the game loads with all the default keys loaded. If I cant figure out why ahk profiles are not being used then I wont be able to map none of my pc games either
gigapig Posted December 13, 2015 Posted December 13, 2015 Running the game through arcadepclauncher would not create a new launcher.exe file nomatter what I tried. Started all over will a freshly extracted set of game files. This time I made the AHK game profile putting new key first then :: then old key When launching the game from RL the AHK mappings are not being used for whatever reason and the game loads with all the default keys loaded. If I cant figure out why ahk profiles are not being used then I wont be able to map none of my pc games either Post your RocketLauncher log set to troubleshooting.
