oldhag270 Posted December 2, 2015 Posted December 2, 2015 File Name: MAME x64 No Nag+Direct Input+Hi Score 0.168 File Submitter: oldhag270 File Submitted: 02 Dec 2015 File Category: Other Credits: MAME developers,oldhag270 Here is MAME 0.168 x64 No Nag+Direct Input+Hi Score Click here to download this file
NewYears1978 Posted January 1, 2016 Posted January 1, 2016 Thank you! I wish I could compile it on my own but couldn't figure out what to change or any guides about it. Are you an HTPC user? Do you like Kodi/XBMC?If so, check out these Kodi Style Themes!-----------------------------------------------------------------------------------------------------Aeon Nox 13 by @dark13Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress-----------------------------------------------------------------------------------------------------If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
knewlife Posted January 5, 2016 Posted January 5, 2016 Hi i just end downloading the romset 168 to use with this... there is an oficcial database somewhere? I dont want to use a custom database because of all the artwork and files that depends on the database. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
Yeuxkes Posted January 5, 2016 Posted January 5, 2016 You do know that Mame has a fixed naming scheme? Every custom db found on these forums will adhere to that naming scheme. It is not like there are sets from no-intro or tosec which use different names. The only thing that could happen between different romset versions is that Mame itselfs renames/adds/removes/combines certain roms which would also be reflected in the db for that particular version.
knewlife Posted January 6, 2016 Posted January 6, 2016 Sure, but i want to use the official database because i use the database with some scripts to batch apply settings to games based on the genre and i understand that the genre are modified in the hyperspin database comparing to the mame xml. its that right? Thats the reason i wait for the oficial database... also that way i eventualyi get the media named correctly from hyperbase. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
