Make a smaller hs.
trekdropp
So i want to make a small hyperspin (500GB).
I was wonder if the is a easy way to get:
All the roms/chd that have themes?
All the videos for these roms.
Anybody made a batch file that checks the theme .zip and copy the rom .7zip that matches, to a different folder.
And the same with the .flv with the rom .7zip
Yeah sorry its late here in Holland :)
I want all my mame roms and chd that have a theme in a folder, that way i can make a cab with onlny theme games and a smaller hdd.
basically you want to copy the ROMS that have themes... my suggestion would be using one of those matching programs that will MOVE/COPY the files to another folder once they are matched. goto the THEMES folder and make a XML then use that XML to match against the ROMS and all the files that matched can now be copied/moved to a new folder.
YEAH! only... i dont know the progams. I make xml of my roms all the time. I never used a programme that moves my roms to a other folder that comperd with a nother folder.
Geen idee, maar volgens mij Don's tools inderdaad. Fatmatch was meer voor hernamen. Hope you don't have to go the manual route.
Other space saving tips:
  • use non-flash versions of themes where possible
  • remove chd games that you don't need
  • use lower res vids or at least make sure you have the latest set from emumovies
But why 500gb? 4+TB hdd's are not that expensive ;)
