badhemi Posted January 24, 2017 Author Posted January 24, 2017 On 19/01/2017 at 0:05 AM, sonkun said: Can someone tell me the correct ini settings they used to get the game to boot directly from the Hyperspin game wheel? I have every single thing working, game boots, controllers work, all games work but only if I'm loading a game from Retroarch only. When I try to load that same game from the Hyperspin it appears to start and then just goes right back to the game wheel. I figured I misspelled something in the parameters line but everything is correct. I'm using Mednafen PC-FX. Sounds like BIOS problem. Did you set BIOS directory in another system like atari2600 then go back and try pcfx?
lilcza Posted February 1, 2017 Posted February 1, 2017 I'm having issues too. Since the beginning every time i would run Medafen PC-FX it would instantly crash regardless of running it through hyperspin or direct with Retroarch. I just downloaded a old bios to replace that other bios and now it's not instantly crashing, but still a black screen. I have a dedicated Bios folder setup on my NAS, and i also have issues with my MESS systems too. I followed the great tutorials from @thatman84 made the folders and everything but instant crash.
thatman84 Posted February 2, 2017 Posted February 2, 2017 What video driver do you have set in retroarch im gl afaik i tested mine again it works fine. My bios is local. I will try moving it to NAS tonight. Running ra 1.4 and core is about 3weeks old Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted February 2, 2017 Posted February 2, 2017 On 2/1/2017 at 2:56 PM, lilcza said: I'm having issues too. Since the beginning every time i would run Medafen PC-FX it would instantly crash regardless of running it through hyperspin or direct with Retroarch. I just downloaded a old bios to replace that other bios and now it's not instantly crashing, but still a black screen. I have a dedicated Bios folder setup on my NAS, and i also have issues with my MESS systems too. I followed the great tutorials from @thatman84 made the folders and everything but instant crash. I tested this with bios in a system folder on my nas, all working fine let us know Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
sonkun Posted February 7, 2017 Posted February 7, 2017 On 1/24/2017 at 2:08 PM, badhemi said: Sounds like BIOS problem. Did you set BIOS directory in another system like atari2600 then go back and try pcfx? I have my bios in the folder I have all my other working bios in. Maybe I ust need a new bios? And if so I still don't get how games load up from Retroarch itself but yet not when I do the same thing threw Hyperspin On 2/2/2017 at 9:09 AM, thatman84 said: What video driver do you have set in retroarch im gl afaik i tested mine again it works fine. My bios is local. I will try moving it to NAS tonight. Running ra 1.4 and core is about 3weeks old I'm gl as well. I have all my bios on an external hard drive if that counts for anything.
thatman84 Posted February 7, 2017 Posted February 7, 2017 Afaik the bios should be called pcfx.rom. It has changed to this name recently Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
sonkun Posted February 7, 2017 Posted February 7, 2017 4 hours ago, thatman84 said:Afaik the bios should be called pcfx.rom. It has changed to this name recentlyTHANK YOU! That did the trick. Such a little thing like switching a few ext. letters now let's me run everything ?
thatman84 Posted February 7, 2017 Posted February 7, 2017 Yeah it's the 1st system I setup to test on PC a week or 2 ago and I used the retroarch debug logging thing. There was a line right at the top showing the bios name mednafen was looking for. Completely different to what's stated in all retroarch documents. Your one of 4 people in a week I have seen with same issue Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
