gkny Posted March 26, 2016 Posted March 26, 2016 is there a setting to set it up so when i exit a game it returns to hyperspin menu instead of going into retroarch menu and having to exit that first
kylecp1979 Posted March 26, 2016 Posted March 26, 2016 Are you sure you have hyperspin setup right? Are you using rocketlauncher with hyperspin? It should automatically go back to the hyperspin main menu when you exit a game.
Sting Posted March 26, 2016 Posted March 26, 2016 Are you sure you have hyperspin setup right? Are you using rocketlauncher with hyperspin? It should automatically go back to the hyperspin main menu when you exit a game. Retroarch (settings/Input/Input Hotkey Binds/Quit RetroArch)
Norkusa Posted March 27, 2016 Posted March 27, 2016 Anyone have tips for a good 'exit' button config? I currently have R3 stick set as my exit but sometimes I accidentally back out of games when playing. What is everyone else using as an exit?
Sting Posted March 27, 2016 Posted March 27, 2016 Anyone have tips for a good 'exit' button config? I currently have R3 stick set as my exit but sometimes I accidentally back out of games when playing. What is everyone else using as an exit? I just use back or L3+R3
Norkusa Posted March 29, 2016 Posted March 29, 2016 I just use back or L3+R3 I tried using L3 + R3 but it only lets me select one or the other. Not both Also, how do I reset the keymap config to original settings?
Sting Posted April 22, 2016 Posted April 22, 2016 I tried using L3 + R3 but it only lets me select one or the other. Not both Also, how do I reset the keymap config to original settings? Sorry mate, thought I replied back to this :/ There's a setting in the hot key menu that says enable hot key.Example you can use (L1) as your enable hot key button and (R1) as your quit RetroArch, so if you press (R1) on it's own it will do whatever it's programmed to do, but if you press and hold (L1) first now (R1) will exit RetroArch. You can do a hot key function for every button I think if you wish, I only have the exit set though Don't know how to remap to original though, I'd probably just uninstall/reinstall
