Official HyperWiki User Login Issue Thread
nogarth
ok i have pinn pointed the issue on why people aint able to log in. some were the groups we were in which was my issue but other peoples are diffrent due to mediawiki naming space which u can only have characters that are
a-z A-Z 0-9
so if your name containts an _ . , - = anything like that this is why you cant log in.
Only post here if you are having issues log in so we can look further into it.
also try when logging in your name in Caps and Lowercase incase that is the issue.
the fix might be a change to your username which we can do but will be discussed through PM.
So post here do not PM me direct as i'll only be checking against this forum till i contact you.
[sIGPIC][/sIGPIC]
Login error
There is no user by the name "Rodent.Vienna". Check your spelling.
just tried, doesn't work.
I'd accept a global username edit to RodentVienna (without dot)
thanks
alex
I could use some help. I'm using my normal username so I don't have any special character. I've also tried the password reset a few times. I use the temporary password from the email, type in my new password, confirm it, then hit "Set Password and Log In". It then takes me to a "Login error - Incorrect password entered. Please try again." screen and I'm back at square one.
Thanks!
EDIT: Oh, and I even switched from Tor over to Firefox and still nothing.
Hi Ashek...are you still having login problems into Wiki site?
[sIGPIC][/sIGPIC]
Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
Gimme. An hour and ill look at your profile bud.
Sent from my HTC Sensation XE with Beats Audio using Tapatalk 4
[sIGPIC][/sIGPIC]
Ashek have you tried typein your password in upercase as u see it and all in lower
[sIGPIC][/sIGPIC]
I just tried it again using all caps, still nothing. I copy paste the password reset from the email and when it asks for me to type in a new one, when I hit continue it gives me the error. Trying to log in again using the temp password or the one I set (all caps or not) doesn't work.
Have u tried loggin in using ye forum user and password.
[sIGPIC][/sIGPIC]
I couldn't remember it since I was saved forever ago. So I reset my forum password and it worked; if anyone else runs into this, hope it helps them out.
Thanks!
No probs bud. Was puzzled why u coupdnt log in as it profile looked fine.
[sIGPIC][/sIGPIC]
Alrighty Folks.....working on the Wiki again!!!! Trying to finalize the formatting with TTX so the rest of the Wikis should be easier to post :)
[sIGPIC][/sIGPIC]
  • 4 weeks later...
I think its just iffi as it happens to me as well
Sent from my GT-N7105 using Tapatalk 4
[sIGPIC][/sIGPIC]
Alrighty folks....Taito Type X wikis are 95% complete! TTX Q&A is about 75% complete! Should be done in the next day our two and then a new system can be worked on! Thanks to all that have contributed in making this system available to the community!
[sIGPIC][/sIGPIC]
  • 1 month later...
Still can't login. Driving me nuts. I can send myself the forgot your password automatic email without a problem. I then can login with the temp password. It then tells me to change the password. I put in the new passwords and doesn't matter what combination I use it fails.
Hmm very odd.....give Mr. NoGarth a pm to see if he can take care of it.
[sIGPIC][/sIGPIC]
+1....... cant login either
