Screen capture software for Hyperspin systems gameplay ??
Creezz67
Hi,
Is there a screen capture software that will record actual gameplay in Hyperspin ?
I have tried Camtasia, Snagit so far, but  they just record black screens and sound only when I launch a game on any system on the Hyperspin wheel.
Thanks in advance for any info
I always use Bandicam for recording Desktop, but you could try MSI Afterburner and FRAPS which are free, I'm sure the are other free ones.
Hi, thanks for info
And they actually record your gameplay when you load up a game in Hyperspin, say if i start to play space invaders for instance ?
Camtasia record desktop etc and Hyperspin wheel, just not the gameplay.
Thanks
Hi,
Just tried it and I just get black screen as usual.
Any specific setting i need to enable Hyperspin gameplay to be recorded ?
Thanks
I have it set to desktop, but still black screen
Records everything else fine, but as soon as i load a game up in Hyperspin it just shows black screen with sound of game.
It always has done this with every screen capture software i have tried.
Did you load hyperspin up and start a game from within and it recorded it that way ?
If so i dont understand why this is not doing it here.
Thanks
ps, Im using Bandicam full version 2.3.0.834
I started recording (you can start it by pressing f12) then HS, then the game.
It could be how you have RL set up, have you tried running the game from mame then recording?
Just tried as you mentioned but same problem.
when you say it could be RL, what setting could i change in that to help ?
thanks
If they still exist then the Desktop options, hide desktop, hide emulator etc.
Did you try just recording from mame?
I was recording using the nvidia codec but that shouldn't matter.
Otherwise try some other software.
Hi,
Tried it all
found settings in RL and tried both ways, also tried them with camtasia, snagit and bandicam but still black screen
also tried mame on its own, still black screen just sound.
Thanks anyway
If you were running Windows 10 you could simply use the Xbox DVR.
It's built in already.
It works perfectly.
Lets you crop edit, change sound etc
Doesn't record an overlay on the screen
Records as MP4 etc...
I tried a few things like you and they all sucked compared to what I already had the entire time and didn't know it.
It works perfectly.
Agreed, and if you map the key combinations to start recording to joystick buttons you get have a seamless in game recording setup.
  • 1 month later...
cataclysm67,
Did you fix your problem? And how did you do? I have the exactly same problem than you...impossible to capture even mame alone!
