Final Burn Alpha SVN
mihaliousa
This version is based on the latest final burn alpha v0.2.97.38
Which command should be used to launch games through hyperspin? I've already got final burn alpha on my setup (that is the older version - v0.2.97.30) and i use  fb_alpha_libretro_android.so. What about the latest version though? Would it be the same?
Where is the Android version?   Did they add an Android intent that allows for ROM launching?
On the same 'rom launching' topic, has anyone figured out if the Phoenix 3DO emulator supports this?
it's In New retroarch nightly but there is no directory for bios to choose use this directory
when you use online updater look at the bottom of screen where it shows it downloading and use that.
I think it is the same as the older fba core. Thing is though i ve got them both installed and the newer core supports more games. So my question is: if i wanna use the newer core on a wheel, which of the two will retroarch use, when i launch a game through hyperspin, since they both have the same command line?
Yeah a load of arcade boards and some wip consoles like sega and NEC
This version is based on the latest fba release for the pc which also supports neo geo cd games - this functionality does not seem to apply on android as retroarch stops working everytime a neo geo cd game is loaded
Cool I have the SNK Neo Geo CD in the Non working systems thread.
If you get this working post an update so where and I will note it for when I do my next update. (Still a few weeks off that ATM Bit slow at getting through HS, keep getting distracted by other HS projects!)
  • 6 months later...
