gregmol Posted September 11, 2016 Posted September 11, 2016 I bought preconfigured drive with hyperspin/rocket launcher everything is working on drive D. I wanna change this to drive K L ...Z. what I have to do ? which files I have to change ? Thaks for every sugestion or help
kylecp1979 Posted September 11, 2016 Posted September 11, 2016 You might want to ask that question to the seller you bought the drive off of. He can tell you what needs changed.
gregmol Posted September 11, 2016 Author Posted September 11, 2016 I asked - his answer -- " Hi, Unfortunately this drive needs to be set to D so you can't change it to another letter. Sorry I couldn't be more help"
ci2own Posted September 11, 2016 Posted September 11, 2016 On 9/11/2016 at 5:21 PM, gregmol said: I bought preconfigured drive with hyperspin/rocket launcher everything is working on drive D. I wanna change this to drive K L ...Z. what I have to do ? which files I have to change ? Thaks for every sugestion or help Why is the reason to change your drive letter? I have a script which i used a few months ago, but as agent47 said you'l have to change some Emulators config files.
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 A script that's interesting. You should probably drop it on the downloads page under third party apps but ya the emulators would still be a problem Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
JoyStickKilla Posted September 12, 2016 Posted September 12, 2016 On 9/11/2016 at 10:36 PM, ci2own said: Why is the reason to change your drive letter? I have a script which i used a few months ago, but as agent47 said you'l have to change some Emulators config files. A script just to change the drive letter? That can just be done under drive management
ci2own Posted September 12, 2016 Posted September 12, 2016 On 9/12/2016 at 1:47 AM, JoyStickKilla said: A script just to change the drive letter? That can just be done under drive management A script to batch change drive leter into hyperspin config files.
kylecp1979 Posted September 12, 2016 Posted September 12, 2016 On 9/11/2016 at 5:38 PM, gregmol said: I asked - his answer -- " Hi, Unfortunately this drive needs to be set to D so you can't change it to another letter. Sorry I couldn't be more help" What emulators is your dive using? I can try to help you out a bit.
orphen92 Posted September 12, 2016 Posted September 12, 2016 Hey Ci2own If your batch file just look fot ini files and change letters of DD (not entire path) i'm interesterd too Orphen
ninja2bceen Posted September 12, 2016 Posted September 12, 2016 Makes me wonder, is there a way to put in the ini a path to a text file or something so anyone could make a change in just updating one text file? Like could there be a way to put in all the emulator inis the path to the same text file that has paths per system? That would be amazing I think but until then I think you have to manually update each ini for emulators, rocket launcher, and Hyperspin settings Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
DJQuad Posted September 12, 2016 Posted September 12, 2016 You can map your D drive to another drive/directory - http://www.ntwind.com/software/utilities/visual-subst.html
ci2own Posted September 12, 2016 Posted September 12, 2016 On 9/12/2016 at 4:06 PM, orphen92 said: Hey Ci2own If your batch file just look fot ini files and change letters of DD (not entire path) i'm interesterd too Orphen Download it from here: https://mega.nz/#!cZdQTJSb!jxwOEkiQchx7WHM3GInYZJVXr5S3pidAXByapcih8jA But REMEMBER!!! Before use it, do a backup of your folder. You'll may need to edit bat file. (Script is done to change from C: to D: and for ini, ahk, cfg, xml, ink files. Just edit it for your requisites. Backup! Backup!!!
kylecp1979 Posted September 12, 2016 Posted September 12, 2016 On 9/12/2016 at 5:56 PM, ci2own said: Download it from here: https://mega.nz/#!cZdQTJSb!jxwOEkiQchx7WHM3GInYZJVXr5S3pidAXByapcih8jA But REMEMBER!!! Before use it, do a backup of your folder. You'll may need to edit bat file. (Script is done to change from C: to D: and for ini, ahk, cfg, xml, ink files. Just edit it for your requisites. Backup! Backup!!! Thanks for the share!!!
ci2own Posted September 12, 2016 Posted September 12, 2016 On 9/12/2016 at 8:37 PM, kylecp1979 said: Thanks for the share!!! You're welcome! And remember, try it with a clean installation before use it. And always back up!
ninja2bceen Posted September 13, 2016 Posted September 13, 2016 Please post on the dl page third party apps and include instructions how to change various letters Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
FhMoTa Posted September 14, 2016 Posted September 14, 2016 This is easy to resolve without resorting to third party apps etc.If you d drive is a CD drive then change the drive letter. If your d drive is a hard drive then you can use a symbolic link, which the system uses as a hard coded shortcut eg all access to d:\arcade stuff is redirected e:\arcade stuff. Off the top of my head the command would be mklink /d "d:\arcade stuff" "e:\arcade stuff". This will work with any program as it windows which receives the call for the file and redirects it. If you post your path I will write the command out for you.I must echo the sentiments about these hard drive sellers though and not knowing the first thing about changing paths etc. I mean picking d for a drive letter! If you went up the alphabet 6 letters or so your unlikely to conflict with anyone's system. I have mine set to I: so if i make a copy for a friend it's generally plug and play.Sent from my Nexus 5 using Tapatalk
