HyperSearch
pietie
AH AH AH  :facepalm: I thought it was you the designer, sorry, i'm stupid, I understand why you did not want to do some thing for that and other little problems.
It's weird because on a French forum they say it is too, because you can be is very active here.
Thank you very much for your help me a lot already informed you, I miss him more than the possibility of editing this shortcut and I can finally use it
  • Replies 485
Lol yes. I've asked pietie for the ahk since he isn't on much but he said it was a mess. There are a number of requests for this app, it's just about perfect though. Please pm pietie what you need still and in like three months he may get to it :D. It is true that I uploaded it to the site since he isn't ever around and I added the few extra stuff like the art and wheel addition. I think the wheel is sick but that's just me.
I manage the third party apps and wanted to make sure it was on there
Tapatalk signature
Hello !
I'm having a hard time running Hypersearch on my system (Windows XP 64Bit)
When i launch the program, it won't hide in the system tray as it is supposed to do, and here's what's in the log :
17:28:45  System.Windows.Markup.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'. ---> System.Xaml.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'.
   at MS.Internal.Xaml.Parser.MePullParser.<Parse>d__0.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<LogicStream_Attribute>d__6f.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_EmptyElement>d__14.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_Element>d__7.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementContent>d__4a.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementBody>d__23.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_PropertyContent>d__5f.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_NonemptyPropertyElement>d__42.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<P_PropertyElement>d__35.MoveNext()
   at MS.Internal.Xaml.Parser.XamlPullParser.<Parse>d__0.MoveNext()
   at MS.Internal.Xaml.NodeStreamSorter.ReadAheadToEndOfAttributes()
   at MS.Internal.Xaml.NodeStreamSorter.ReadAheadAndSortCtorProperties()
   at MS.Internal.Xaml.NodeStreamSorter.MoveNext()
   at System.Xaml.XamlXmlReader.Read()
   at System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
   at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   --- End of inner exception stack trace ---
   at System.Windows.Markup.XamlReader.Load(XamlReader xamlReader, ParserContext parserContext)
   at System.Windows.Markup.XamlReader.Load(XmlReader reader, ParserContext parserContext, XamlParseMode parseMode)
   at System.Windows.Markup.XamlReader.Load(Stream stream, ParserContext parserContext)
   at MS.Internal.AppModel.AppModelKnownContentFactory.XamlConverter(Stream stream, Uri baseUri, Boolean canUseTopLevelBrowser, Boolean sandboxExternalContent, Boolean allowAsync, Boolean isJournalNavigation, XamlReader& asyncObjectConverter)
   at System.Windows.ResourceDictionary.set_Source(Uri value)
   at HyperSearch.MainWindow..ctor() in c:\00-Work\Projects\HyperSpinClone\HyperSearch\MainWindow.xaml.cs:line 204
Anyone knows what went wrong please ?
Thanks in advance for your response !
My HyperSearch won't open in Hyperspin. When I open HyperSearch.exe in the folder I get an error
http://pastebin.com/AamzF8ps
18:23:03  System.Windows.Markup.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'. ---> System.Xaml.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'.
  • 4 weeks later...
