New Bezel Art Location And Approval
rfancella
What aspect ratio are you using? (Your screen width devided by your screen height)
278 members have voted
  1. 1. What aspect ratio are you using? (Your screen width devided by your screen height)
    • 4x3 (Your Aspect = 1.33333)
    • 16x9 (Your Aspect = 1.77777)
    • 16x10 (Your Aspect = 1.6)
Yes of course, but this depth background can't be placed anywhere and be expected to work with any bezel, it would have to be set up to fit, (for example) Ashs' bezels?
Yes very true, this is the same even in Photoshop. I have been converting my "depth background" to fit the various bezels. If there is any interest, you guys can add a sub founder to the _Hyperlaunch Media folder on the FTP, and I'll submit them ;). I have a few different ideas for these.
Instagram : baddeolv
Facebook : Brian Addeo
  • Replies 988
So, I got around to downloading all of these excellent bezels... Next question. Is there anyway to get parent bezels to load for child/clones?
I'm pretty sure you'd have to manually rename copies of them, or else HL would just use the assigned "default bezel"
Upload!
45 Bezels done.
Ash
if anyone has the solution to add the plastic bezels depth, and it is possible to add it without modification. I'm willing help to add them and editing the ini files if necessary.
thank you!!! No time for editing files? :adore:
Ash
if anyone has the solution to add the plastic bezels depth, and it is possible to add without modification. I'm willing help to add them and editing the ini files if necessary.
Ash
I'm gonna look at the background option tonight ash. In the meantime, I added them in Photoshop to my copies of your bezels, if you want them. Both ratios. 16x9 and 16x10. Ini files included :) Vertical and horizontal
Thank you baddie, I have a friend who needs the 16x10 release!
You got it, I think we should call them BADASH Bezelz (joking) where should I upload them?
Created a folder on the FTP in hyperlaunc Media\Bezels\Submissions Open\Badash ^^ \ 16x10 versions and put them in. I will continue to do them in the same format. In my case, I would add that Bezels background, when we'll find a way to add them.
Thanks
Ash
exedexes
Upload!
46 bezels done!
Ash
Now just ataxx is missing for commando z80 based hardware! (distibuted by Capcom but manufacturer by leland) Capcom sectionZ is now complete.
The old Capcom system will be over soon.
Ash
ataxx
Thanks to all themes creators whose I operates some elements!!! They will recognize.
47 bezels done
Upload!
Ash
Is that a bad translation on the top of that bezel or was that actually written on the art? Seems like it should say "do you think that you can successfully kill the five demons?"
If a background has the "same name" of the bezel image and it is on the same folder, it will be selected prioritarily even if you have multiple backgrounds on the folder.
For example:
bezel image: HyperLaunch\Media\Bezels\MAME\avengers\Bezel - 16:9 (ash).png
background images: HyperLaunch\Media\Bezels\MAME\avengers\Background - 16:9 (ash).png
This was a request from rfancella some time ago and it is added to the HL beta.
So, the way I see you guys have two options:
1) Edit these bezel files in photoshop and create a merged bezel image to share both the original ash and the modified BADASH bezels (like you are doing).
2) Create the background image for each bezel, and share the original bezel and the background image with the same name.
I personally prefer the second alternative, as any user that wants to remove or modify only the depth image will need only to remove or replace the background image without the need to have to mess with the bezel image. Besides, most of the backgrounds will be simply copied between different bezels saving some of the conversion time.
No need to duplicate files or manually copy them. HyperLaunch will look at the parent folder if no bezel was found on the game folder.
For example, when running the game sf2a if no bezel was found on the folder HyperLaunch\Media\Bezels\MAME\sf2a, HL will look on the folder HyperLaunch\Media\Bezels\MAME\sf2 if the parent info is defined on the database.
Again this was introduced on the last beta, so make sure to have your files up to date.
I ask you one thing although, it is difficult to dig into media related threads like this to try to answer technical hyperlaunch questions like. If you want a better help on that, please post these questions on the HL forums (hyperlaunch.net). Besides, having all the answers there avoids me of having to repeat myself what can be tiresome some times.
Also, Dazz, we made a lot of changes to be able to use HyperLaunch on pincabs also. So if you like the HL 3 features now you could use it on the pinball machine too. ;)
When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS!
Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher).
Ass. Bleasby - RocketLauncher Development Team.
you would have to manually rename each one.
where are these bad ?
i shared a dropbox folder with ash, if u want any of those templates..he has permissions to invite you, then maybe u could drop your stuff in there for me also :]
i am very close to getting back to individ bezels again for mame :]
thanks my friends!
Thanks baddie i'll fix it!
For example:
Must have missed the boat on this one, thanks.
Hello all,
Another busy week by the Grizz man!!
A total of 75 bezels.
25 systems in all three aspect ratios. Samples below:
Arcade Vertical "dirty":
Arcade Vertical "clean":
Atari 2600 "large":
Atari Lynx Vertical:
Atari Lynx Vertical (Scan Lines):
Bandai Wonderswan Horizontal:
Banai Wonderswan Vertical:
Commodore VIC-20:
Emerson Arcadia 2001:
Magnavox Odyssey 2:
Microsoft MSX:
Microsoft MSX2:
NEC PC-FX:
Nintendo DS:
Nintendo Game Boy Advance:
Nintendo Game Boy Color:
Nintendo Virtual Boy:
PC Games:
Sega SG-1000:
Sega ST-V:
Sinclair ZX Spectrum:
SNK Neo Geo Pocket:
SNK Neo Geo Pocket Color:
Texas Instruments TI 99-4A:
Watara Supervision:
Thank you Grizz for all that you do for the bezel community!!
Thanks,
Ron
muahahah
thanks my friend!
kakunk!
doing the mortal kombat series for mame now!
Holy artistic boarders Grizzly Ashams, it's a bezel frenzy. :beer:
Good Job Bro!!!
Can wait for Mortal combat series! ^^
Ataxx is now fixed
Here is the Mortal Kombat bezel fixed up by Grizz!!
All three aspect ratios!!
mk:
In HyperLaunch Media\Bezels\Submissions Final\MAME\mk directory.
Thanks Grizz!!!
Thanks,
Ron
msh
Upload
48 Bezels done.
Ash
