Pac-Man not showing up under MAME
Haloman800
.. The only thing I've found is PuckMan
As a side note, asteroids also isn't showing up. But I'm mainly interested in Pac-Man. Any help?
Sent from my SM-N920V using Tapatalk
you should get a MAME XML WITH NO Clones , I use Don's tools to make one then use my custom XMLs to add all the games I removed
my custom XMLs
2 player versions as parents
I remove 4 player games -->  Made an XML to add  2 player versions as parents
clone games as parents
removed all clones --> Made an XML to add all the good clone games  ( such as pac-man, pac-man/Ms pac-man  speed hacks)
Clones with themes
removed all clones -->Add clone games with themes, their are a few clone games that have themes, such as Black Dragon aka Black Tiger
Cocktail versions as parents
I have a cocktail arcade,  so I set the cocktail supported clone games as parents.
Individual Games
Their are non standard Mame games I add to my wheel
Donkey Kong Pauline -- added to MAMEUIFX
Fix it felix --> PC game
Ice Cold Beer --> Visual Pinball (plays great on a cocktail arcade)
Zekes Peak --> Visual Pinball (plays great on a cocktail arcade)
filtering XMLs.zip
Simply open Merge HyperLists.exe in the Don's tools folder, and merge my XMLs with your MAME XML with NO CLONES.  And you will have a filtered XML with all your favorite clones.
if you do this their is no need to use any filters in HyperHQ
you should get a Clones only XML, I use Don's tools to make one then use my custom XMLs to add all the games I removed
my custom XMLs
Clones with themes
Individual Games
attachicon.giffiltering XMLs.zip
Simply open Merge HyperLists.exe in the Don's tools folder, and merge my XMLs with your Clones only XML.  And you will have a filtered XML with all your favorite clones.
So I downloaded your pack, I merged "clone games as parents.xml" with my MAME.xml that was in my HyperSpin > Databases >MAME folder, then I dropped in the new .xml, but it's still not showing the cloned games. What am I doing wrong?
Open your MAME XML and check to see if  their was any effects.
If you have a default MAME XML with all the clone games,  and you merge  my "clone games as parents.xml"
Don's tools will ignore duplicate games.  this is why I suggested you make or use a MAME XML with no clones.
  • 7 months later...
Newbie question... What are "Don's tools"?
A database tool, probably in the download section here.
Dons tools is a HyperSpin XML management utility,  their are 6 programs in the pack.
the most important one is Rename ROMs.exe,  witch lets you rename your roms using the Official Hyperspin XMLs.
you can use
Filter Hyperlist.exe to make your own MAME XML without clones
Split Hyperlist.exe  to make your own Manufacture/Genre specifict XMLs
