Styphelus Posted December 9, 2016 Posted December 9, 2016 Finally updated to ver 0.180 from 0.172. Problem is, instead of the game starting, it tales me to the Mame menu screen. How do I bypass it? Fixed it. Stupid 7z was enables. Now, is there a way to remove the blue box warning that says "There are known problems with this machine" on some games?
Yeuxkes Posted December 9, 2016 Posted December 9, 2016 You would need a no nag patched version for that.
britannica Posted December 9, 2016 Posted December 9, 2016 29 minutes ago, agent47 said: You don't need a special compiled version for direct input. You can set the input type in the mame.ini, it's been that way for a few versions now. where i can set the directinput on the mame.ini? My 360 controller doesn't work with xpadder on this mame 0.180
gigapig Posted December 9, 2016 Posted December 9, 2016 14 minutes ago, britannica said: where i can set the directinput on the mame.ini? My 360 controller doesn't work with xpadder on this mame 0.180 You should not be using xpadder with mame nor any other keymapper. You should grab the xbox360 ctrlr file, which if you don't have it I will post it.
dougan78 Posted December 9, 2016 Posted December 9, 2016 You should not be using xpadder with mame nor any other keymapper. You should grab the xbox360 ctrlr file, which if you don't have it I will post it.Post it please. I will need it when I update my mame soon. Thanks!Sent from my SM-G920V using Tapatalk
gigapig Posted December 9, 2016 Posted December 9, 2016 You will find it here, bottom of the first post and also where to put it in you mame ini. If you have more than one mame ini then add it to all of them. http://forum.arcadecontrols.com/index.php?topic=100079.0
