rdhanded2 Posted March 30, 2014 Posted March 30, 2014 I have just started messing with HLSL in mame and I am trying to get it running outside of HS and I am not having any luck. I am running mame 152 and anytime I enable HLSL, no matter the settings, when I launch mame the screen is black and I get nothing. I disable it and all works fine. I have tried several different hlsl settings and all give the same issue. I am running dual AMD Radeon HD 5670 cards, can the not handle it? I have tried adjusting my screen resolution as well but same issue. I have my hlsl folder and all the scanline pngs are in the mame artwork folder. Anyone experienced this? Am I just overlooking something simple? Any help is appreciated. My Tekken 3 pedestal conversionBasement Bar / Arcade
gigapig Posted March 30, 2014 Posted March 30, 2014 I've had a black screen if you have bezels enabled but no bezel artwork exists in the mame artwork folder. Happens with Marble Madness and Hypersports as well as plenty of others. Have a look at this recent thread and I also did a basic video guide for CreativeOne. www.hyperspin-fe.com/forum/showthread.php?31468-CANNOT-FIND-Scanlines-on-MAME-150
rdhanded2 Posted March 30, 2014 Author Posted March 30, 2014 I Will check and make sure I have bezels turned off since I don't use them. My black screen is not on specific games, it is mame itself. Not sure if I made that clear or not. I launch mame and nothing shows where the menu should be. This is all outside of HS Sent from my SAMSUNG-SGH-I337 using Tapatalk My Tekken 3 pedestal conversionBasement Bar / Arcade
BladeZX Posted April 16, 2014 Posted April 16, 2014 I am seeing a black screen as well with HLSL enabled in MAME I have sound but no video Here are the settings I am using: # # DIRECT3D POST-PROCESSING OPTIONS # hlsl_enable 1 hlslpath hlsl hlsl_ini_read 0 hlsl_ini_write 0 hlslini %g hlsl_prescale_x 0 hlsl_prescale_y 0 hlsl_preset -1 hlsl_write hlsl_snap_width 1280 hlsl_snap_height 1024 shadow_mask_alpha 0.003 shadow_mask_texture aperture.png shadow_mask_x_count 512 shadow_mask_y_count 384 shadow_mask_usize 0.125 shadow_mask_vsize 0.125 curvature 0.05 pincushion 0.05 scanline_alpha 0.73 scanline_size 1.0 scanline_height 0.7 scanline_bright_scale 0.65 scanline_bright_offset 0.6 scanline_jitter 0.10 defocus 0.0,0.0 converge_x 0.0,0.0,0.0 converge_y 0.0,0.0,0.0 radial_converge_x 0.0,0.0,0.0 radial_converge_y 0.0,0.0,0.0 red_ratio 1.0,0.0,0.0 grn_ratio 0.0,1.0,0.0 blu_ratio 0.0,0.0,1.0 saturation 1.0 offset 0.0,0.0,0.0 scale 1.0,1.0,1.0 power 1.0,1.0,1.0 floor 0.0,0.0,0.0 phosphor_life 0.0,0.0,0.0 yiq_enable 0 yiq_cc 3.59754545 yiq_a 0.5 yiq_b 0.5 yiq_o 0.0 yiq_p 1.0 yiq_n 1.0 yiq_y 6.0 yiq_i 1.2 yiq_q 0.6 yiq_scan_time 52.6 yiq_phase_count 2 HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
gigapig Posted April 16, 2014 Posted April 16, 2014 I am seeing a black screen as well with HLSL enabled in MAMEI have sound but no video Which game? and is it only when HLSL is turned on? Do you have bezels switched on, in Layout mode?
joe35car Posted April 16, 2014 Posted April 16, 2014 Have you ever got the HLSL to work before in MAME? Works fine here using MAME153. Make sure you have this downloaded or it won't work. Reboot PC after you installed it and try MAME again with HLSL enabled. Also make sure your graphics card driver is up to date.
