angryfruitsalad Posted February 15, 2017 Posted February 15, 2017 Slight problem I'm hoping someone can help me with. New to emulators and HyperSpin and rocket launcher, got roms loaded and tested in rocket launcher, works fine, start hyperspin and can select any console with the enter button but when I want to select a game nothing happens, enter button is the start button. Is there some settings I haven't addressed? Edit: Get this in the HyperSpin log 11:28:01 PM | HyperSpin Started 11:28:01 PM | Going windowed mode 11:28:01 PM | Checking for updates 11:28:01 PM | Update Check Complete 11:28:01 PM | Startup program unavailable 11:28:01 PM | Playing intro video 11:28:20 PM | Error intializing joysticks 11:28:20 PM | Menu Mode is multi 11:28:20 PM | Loading Main Menu.xml 11:28:20 PM | Main Menu.xml successfully loaded 11:28:20 PM | Main Menu wheel loaded successfully 11:28:25 PM | Loading Nintendo Entertainment System.xml 11:28:26 PM | Main Menu.xml successfully loaded 11:28:28 PM | Nintendo Entertainment System wheel loaded successfully 11:29:00 PM | Launching Game 11:29:00 PM | Using HyperLaunch 11:29:00 PM | Getting HyperLaunch path 11:29:00 PM | HyperLaunch located at H:\hyperspin\HyperLaunch.exe 11:29:00 PM | Running HyperLaunch.exe 11:29:00 PM | HyperLaunch Command Line is: H:\hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "Mario Bros. (World)" 11:29:05 PM | Loading Main Menu.xml 11:29:05 PM | Main Menu.xml successfully loaded 11:29:06 PM | Main Menu wheel loaded successfully 11:29:07 PM | Exit program unavailable 11:29:07 PM | Quiting Hyperspin 11:29:07 PM | Bye! And in the HyperLaunchLog I get this ( different games loaded): 11:37:06 PM | HyperLaunch v2.25c 11:37:06 PM | System Specs: HyperSpin Dir: H:\hyperspin OS: WIN_7 OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY11): 1920x1080 (1920x1040 work) HyperSpin Res: 800x600 AHK Version: 1.1.07.03 11:37:06 PM | HyperLaunch received "Nintendo Entertainment System" and "1943 - The Battle of Midway (USA)" 11:37:06 PM | INI Keys read 11:37:06 PM | Possible duplicate launch. is already running, closing HyperLaunch Any ideas as to what's happening?
BATTLEDONKEY Posted February 15, 2017 Posted February 15, 2017 Have u also set hyperspin to use rocketlauncher from the settings.ini file. By default it's pointing to hyperlaunch so just open the settings.ini with notepad and edit the path pointing it to rocketlauncher
angryfruitsalad Posted February 16, 2017 Author Posted February 16, 2017 20 hours ago, BATTLEDONKEY said: Have u also set hyperspin to use rocketlauncher from the settings.ini file. By default it's pointing to hyperlaunch so just open the settings.ini with notepad and edit the path pointing it to rocketlauncher Yes, I followed the official HyperSpin tutorials.
gigapig Posted February 16, 2017 Posted February 16, 2017 I can see by you HS log that the path is set to you Hyperlaunch. Battledonkey is correct.
adamg Posted February 16, 2017 Posted February 16, 2017 Yep. And that is a really easy step to miss so don't feel bad. Honestly to be as new as you say, you are doing quite well.
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 Where do I change that and to what?
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 I have this which I had before. [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Nintendo Entertainment System Hyperlaunch_Path=H:\RocketLauncher\RocketLauncher.exe
jfp Posted February 17, 2017 Posted February 17, 2017 And are you sure rocket launcher is in H:\ maybe you put it it a different HDD
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 Yes, all programs are set to run as admin. I re installed HyperLaunch and RocketLauncher in H:, they're the only programs I have in my H drive.
jfp Posted February 17, 2017 Posted February 17, 2017 Hmm maybe :? check your rlauncher log not your hyperlaunch log. hyperlaunch isn't used anymore that log is old
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 5 minutes ago, jfp said: Hmm maybe :? Can you rename hyperlaunch.exe to hyperlaunch.old and send us another log. please. 10:23:24 PM | HyperSpin Started 10:23:24 PM | Going windowed mode 10:23:24 PM | Checking for updates 10:23:24 PM | Update Check Complete 10:23:24 PM | Startup program unavailable 10:23:24 PM | Playing intro video 10:23:42 PM | Error intializing joysticks 10:23:42 PM | Menu Mode is multi 10:23:42 PM | Loading Main Menu.xml 10:23:43 PM | Main Menu.xml successfully loaded 10:23:43 PM | Main Menu wheel loaded successfully 10:23:45 PM | Loading Nintendo Entertainment System.xml 10:23:45 PM | Main Menu.xml successfully loaded 10:23:46 PM | Nintendo Entertainment System wheel loaded successfully 10:23:49 PM | Launching Game 10:23:49 PM | Using HyperLaunch 10:23:50 PM | Getting HyperLaunch path 10:23:50 PM | HyperLaunch located at H:\Hyperspin\HyperLaunch.exe 10:23:50 PM | Cannot find Hyperlaunch.exe 10:24:08 PM | Loading Main Menu.xml 10:24:08 PM | Main Menu.xml successfully loaded 10:24:08 PM | Main Menu wheel loaded successfully 10:24:10 PM | Exit program unavailable 10:24:10 PM | Quiting Hyperspin 10:24:10 PM | Bye!
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 This is with HyperLaunch renamed to .old 22:02:32:410 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com) 22:02:32:437 | RL | WARNING | +16 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 22:02:32:442 | RL | TRACE_DLL | +16 | RLDLL.setLogMode - Setting DLL log mode in thread "RL" to "1" in file "1" 22:02:32:456 | RL | TRACE_DLL | +15 | RLDLL.splitPath - Splitting "H:\RocketLauncher\Module Extensions\Gdip.ahk" 22:02:32:479 | RL | TRACE_DLL | +16 | RLDLL.getFullPathFromRelative - Converting ".\Media" 22:02:32:505 | RL | TRACE_DLL | +31 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Media" 22:02:32:513 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Data" 22:02:32:538 | RL | TRACE_DLL | +31 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Data" 22:02:32:543 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Modules" 22:02:32:586 | RL | TRACE_DLL | +47 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Modules" 22:02:32:593 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\RocketLauncherUI" 22:02:32:620 | RL | TRACE_DLL | +32 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\RocketLauncherUI" 22:02:32:626 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\hyperspin\HyperSpin.exe" 22:02:32:660 | RL | TRACE_DLL | +46 | RLDLL.getFullPathFromRelative - Converted to "H:\hyperspin\HyperSpin.exe" 22:02:32:668 | RL | TRACE_DLL | +0 | RLDLL.getServiceStatus - Getting status of service: "Winmgmt" 22:02:32:943 | RL | TRACE_DLL | +282 | RLDLL.getSystemLocale - Getting current system locale 22:02:32:952 | RL | TRACE_DLL | +0 | RLDLL.getFormatsLocale - Getting current locale format 22:02:32:964 | RL | TRACE_DLL | +15 | RLDLL.getWindowsUILanguage - Getting current Windows language being displayed 22:02:32:976 | RL | TRACE_DLL | +16 | RLDLL.getTextEncoding - Getting ANSI text encoding for Windows 22:02:32:991 | RL | TRACE_DLL | +16 | RLDLL.getDisplaySettings - Getting display settings for: "\\.\DISPLAY11" 22:02:32:009 | RL | TRACE_DLL | +15 | RLDLL.getDisplayScalingPercentage - Getting display scaling percentage for: "\\.\DISPLAY11" 22:02:33:082 | RL | DEBUG | +78 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:02:33:094 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 22:02:33:101 | RL | INFO | +16 | Main - System Specs: RocketLauncher Dir: H:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 16327.57 MB Free Memory: 9298.46 MB Used Memory: 7029.113 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: NVIDIA GeForce GTX 1070 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 21.21.13.7866 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Sound Blaster Recon3Di Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-CA Formats Locale: en-CA Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY11): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 22:02:33:108 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\RocketLauncher.exe exists 22:02:33:117 | RL | TRACE_DLL | +16 | RLDLL.splitPath - Splitting "H:\RocketLauncher\RocketLauncher.exe" 22:02:33:139 | RL | DEBUG | +15 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.2.0.1 LegalCopyright ©2016 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.2.0.1 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2195456 bytes Created: 2/15/2017 - 10:10:51 PM Modified: 2/15/2017 - 10:10:53 PM 22:02:33:144 | RL | INFO | +16 | GetSystems - Started 22:02:33:150 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml exists 22:02:33:154 | RL | TRACE_DLL | +0 | RLDLL.splitPath - Splitting "H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml" 22:02:33:190 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 21 bytes Created: 2/15/2017 - 10:10:06 PM Modified: 2/15/2017 - 10:10:06 PM 22:02:33:196 | RL | INFO | +16 | GetSystems - Found a RocketLauncher Systems.xml: "H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml" 22:02:33:203 | RL | INFO | +0 | GetSystems - Parsing the systems xml 22:02:33:215 | RL | INFO | +15 | GetSystems - Ended 22:02:33:238 | RL | INFO | +32 | Main - RocketLauncher launched directly 22:02:36:243 | RL | INFO | +3000 | GuiClose - User exited via GUI 22:02:36:273 | RL | INFO | +31 | ExitScript - Started 22:02:36:397 | RL | DEBUG | +125 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:02:36:445 | RL | DEBUG | +47 | Registry.Read - Registry Read finished, returning 0 22:02:36:477 | RL | TRACE | +31 | StringUtils.Contains - "false" does not contain "true|kill" 22:02:36:507 | RL | TRACE | +31 | StringUtils.Contains - "false" does not contain "do_not_restore|kill_&_do_not_restore" 22:02:36:545 | RL | INFO | +31 | SystemCursor - Restoring mouse cursor 22:02:36:596 | RL | INFO | +47 | ExitScript - Restored cursor 22:02:36:625 | RL | INFO | +32 | ExitScript - Ended Edit: when HyperLaunch was renamed to .old, I got a message ' Cannot find rocketLauncher.exe'
jfp Posted February 17, 2017 Posted February 17, 2017 sigh..... run a game in hyperspin and check if it changed, if it did post it. DO not open rocketlauncherui just hyperspin....... please post hyperspin log aswell
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 HyperSpin log: 10:39:26 PM | HyperSpin Started 10:39:26 PM | Going windowed mode 10:39:26 PM | Checking for updates 10:39:26 PM | Update Check Complete 10:39:26 PM | Startup program unavailable 10:39:26 PM | Playing intro video 10:39:44 PM | Error intializing joysticks 10:39:45 PM | Menu Mode is multi 10:39:45 PM | Loading Main Menu.xml 10:39:45 PM | Main Menu.xml successfully loaded 10:39:45 PM | Main Menu wheel loaded successfully 10:39:46 PM | Loading Nintendo Entertainment System.xml 10:39:46 PM | Main Menu.xml successfully loaded 10:39:47 PM | Nintendo Entertainment System wheel loaded successfully 10:39:52 PM | Launching Game 10:39:52 PM | Using HyperLaunch 10:39:52 PM | Getting HyperLaunch path 10:39:52 PM | HyperLaunch located at H:\Hyperspin\HyperLaunch.exe 10:39:52 PM | Running HyperLaunch.exe 10:39:52 PM | HyperLaunch Command Line is: H:\Hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "After Burner (USA) (Unl)" 10:39:59 PM | Loading Main Menu.xml 10:39:59 PM | Main Menu.xml successfully loaded 10:39:59 PM | Main Menu wheel loaded successfully 10:40:01 PM | Exit program unavailable 10:40:01 PM | Quiting Hyperspin 10:40:01 PM | Bye! RocketLauncher log: 22:02:32:410 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com) 22:02:32:437 | RL | WARNING | +16 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 22:02:32:442 | RL | TRACE_DLL | +16 | RLDLL.setLogMode - Setting DLL log mode in thread "RL" to "1" in file "1" 22:02:32:456 | RL | TRACE_DLL | +15 | RLDLL.splitPath - Splitting "H:\RocketLauncher\Module Extensions\Gdip.ahk" 22:02:32:479 | RL | TRACE_DLL | +16 | RLDLL.getFullPathFromRelative - Converting ".\Media" 22:02:32:505 | RL | TRACE_DLL | +31 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Media" 22:02:32:513 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Data" 22:02:32:538 | RL | TRACE_DLL | +31 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Data" 22:02:32:543 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Modules" 22:02:32:586 | RL | TRACE_DLL | +47 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\Modules" 22:02:32:593 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\RocketLauncherUI" 22:02:32:620 | RL | TRACE_DLL | +32 | RLDLL.getFullPathFromRelative - Converted to "H:\RocketLauncher\RocketLauncherUI" 22:02:32:626 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\hyperspin\HyperSpin.exe" 22:02:32:660 | RL | TRACE_DLL | +46 | RLDLL.getFullPathFromRelative - Converted to "H:\hyperspin\HyperSpin.exe" 22:02:32:668 | RL | TRACE_DLL | +0 | RLDLL.getServiceStatus - Getting status of service: "Winmgmt" 22:02:32:943 | RL | TRACE_DLL | +282 | RLDLL.getSystemLocale - Getting current system locale 22:02:32:952 | RL | TRACE_DLL | +0 | RLDLL.getFormatsLocale - Getting current locale format 22:02:32:964 | RL | TRACE_DLL | +15 | RLDLL.getWindowsUILanguage - Getting current Windows language being displayed 22:02:32:976 | RL | TRACE_DLL | +16 | RLDLL.getTextEncoding - Getting ANSI text encoding for Windows 22:02:32:991 | RL | TRACE_DLL | +16 | RLDLL.getDisplaySettings - Getting display settings for: "\\.\DISPLAY11" 22:02:32:009 | RL | TRACE_DLL | +15 | RLDLL.getDisplayScalingPercentage - Getting display scaling percentage for: "\\.\DISPLAY11" 22:02:33:082 | RL | DEBUG | +78 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:02:33:094 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 22:02:33:101 | RL | INFO | +16 | Main - System Specs: RocketLauncher Dir: H:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 16327.57 MB Free Memory: 9298.46 MB Used Memory: 7029.113 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: NVIDIA GeForce GTX 1070 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 21.21.13.7866 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Sound Blaster Recon3Di Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-CA Formats Locale: en-CA Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY11): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 22:02:33:108 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\RocketLauncher.exe exists 22:02:33:117 | RL | TRACE_DLL | +16 | RLDLL.splitPath - Splitting "H:\RocketLauncher\RocketLauncher.exe" 22:02:33:139 | RL | DEBUG | +15 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.2.0.1 LegalCopyright ©2016 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.2.0.1 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2195456 bytes Created: 2/15/2017 - 10:10:51 PM Modified: 2/15/2017 - 10:10:53 PM 22:02:33:144 | RL | INFO | +16 | GetSystems - Started 22:02:33:150 | RL | INFO | +0 | CheckFile - Checking if H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml exists 22:02:33:154 | RL | TRACE_DLL | +0 | RLDLL.splitPath - Splitting "H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml" 22:02:33:190 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 21 bytes Created: 2/15/2017 - 10:10:06 PM Modified: 2/15/2017 - 10:10:06 PM 22:02:33:196 | RL | INFO | +16 | GetSystems - Found a RocketLauncher Systems.xml: "H:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml" 22:02:33:203 | RL | INFO | +0 | GetSystems - Parsing the systems xml 22:02:33:215 | RL | INFO | +15 | GetSystems - Ended 22:02:33:238 | RL | INFO | +32 | Main - RocketLauncher launched directly 22:02:36:243 | RL | INFO | +3000 | GuiClose - User exited via GUI 22:02:36:273 | RL | INFO | +31 | ExitScript - Started 22:02:36:397 | RL | DEBUG | +125 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:02:36:445 | RL | DEBUG | +47 | Registry.Read - Registry Read finished, returning 0 22:02:36:477 | RL | TRACE | +31 | StringUtils.Contains - "false" does not contain "true|kill" 22:02:36:507 | RL | TRACE | +31 | StringUtils.Contains - "false" does not contain "do_not_restore|kill_&_do_not_restore" 22:02:36:545 | RL | INFO | +31 | SystemCursor - Restoring mouse cursor 22:02:36:596 | RL | INFO | +47 | ExitScript - Restored cursor 22:02:36:625 | RL | INFO | +32 | ExitScript - Ended RocketLauncherUI wasn't opened.
jfp Posted February 17, 2017 Posted February 17, 2017 Go into your hyperspin folder then settings folder and upload you settings.ini
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Nintendo Entertainment System Hyperlaunch_Path=H:\RocketLauncher\RocketLauncher.exe [Resolution] FullScreen=false Width=800 Height=600 Scanlines_Active=false Scanlines_Image= Scanlines_Scale=2 Scanlines_Alpha=0.1 [Optimizer] CPU_Priority=normal Quality=HIGH Image_Smoothing=true Animated_Backgrounds=true Inter_Backgrounds=false Level1_Backgrounds=true Level2_Backgrounds=true Level3_Backgrounds=false Level4_Backgrounds=false Special_Backgrounds=true Wait_For_Special=false Animated_Artworks=true Level1_Artworks=true Level2_Artworks=true [IntroVideo] Use_Intro=true Stop_On_Keypress=true [Sound] Master_Volume=100 Video_Volume=100 Wheel_Volume=20 Interface_Volume=100 [AttractMode] Active=true Time=60 MaxSpinTime=10 HyperSpin=true Wait_For_Video=false [Keyboard] Key_Delay=true [P1 Controls] Start=13 Exit=27 Up=38 Down=40 SkipUp=37 SkipDown=39 SkipUpNumber=70 SkipDownNumber=86 HyperSpin=32 Genre=71 Favorites=76 [P2 Controls] Start=69 Exit=81 Up=87 Down=83 SkipUp=65 SkipDown=68 SkipUpNumber=74 SkipDownNumber=77 HyperSpin=88 Genre=72 Favorites=90 [P1 Joystick] Enabled=false Joy=0 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [P2 Joystick] Enabled=false Joy=1 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [Trackball] Enabled=false Sensitivity=90 [Spinner] Enabled=false Sensitivity=90 [Startup Program] Executable= Paramaters= Working_Directory= WinState= [Exit Program] Executable= Paramaters= Working_Directory= WinState=NORMAL [LEDBlinky] Active=false Path= [HiScore] Active=false Y=550 Delay=2 [HyperLaunch] Last_System=Nintendo Entertainment System Last_Rom=After Burner (USA) (Unl) Exit_Script_Key=~q & ~s Exit_Emulator_Key=Esc Toggle_Cursor_Key=t MultiGame_Key=NumpadSub MultiGame_Select_Key=Enter MultiGame_Exit_Key=Esc Path_To_Daemontools= Path_To_CPWizard= Fade_In_Interrupt_Keys=anykey Keymapper_Path= Keymapper_Profiles_Path=H:\hyperspin\Keymapper Profiles\
jfp Posted February 17, 2017 Posted February 17, 2017 damn well i don't know man it should work. :/ only thing left is 2 make sure your frontends are setup correctly in rocketlauncherui you should add hyperspin and select hyperspin plugin for both fields and the correct path to hyperspin.. then mark it default
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 Yea, I've got the correct paths for front end and have added hyperspin and it's the default for both
jfp Posted February 17, 2017 Posted February 17, 2017 Btw you said you reinstalled hyperspin and rocket launcher? do you have the old installs on one of your hdd if so delete them. if you ever create a shortcut to the wrong one it'll mess with you
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 I had the same problem with the first install as I am having now so started again on a different drive, no shortcuts, just a new install from fresh, and followed the official vids. I'll delete the first installs just in case. Edit: deleted the first install, no joy, still the same. Roms run ok if I test them in rocketLauncherui, just not with Hyperspin.
jfp Posted February 17, 2017 Posted February 17, 2017 one last thing, run a game in rocketlaucherui as u say it works, then exit and post your rocket launcher.log one last time
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 Hmmm....now it's telling me it can't find my roms, maybe running hyperspin was looking at the old install and not the new? i'll try adding the roms againeven though they're in the new install.
angryfruitsalad Posted February 17, 2017 Author Posted February 17, 2017 Lol, I hope so....i've had trouble with this since friday gone.
