mikty Posted August 29, 2017 Posted August 29, 2017 Hi, I have created several default themes for cd system as dreamcast, mega cd, etc.. I would like to use the spinning effect on the discs but in order to create an hd theme, I have decreased at 75% the width to show a disc with equal dimensons on the theme. but the problem is that if I apply the spinning, the disc become oval during spinning (normal because one the width is reduced) is there a way to use the spinning effect on hd theme with a good dimensions of the disc without deformation ? thanks for yours advices regards
sparton Posted August 29, 2017 Posted August 29, 2017 nope, I mean, just talking outside of Hyperspin, if you take a circle and squash it, it's going to become oval. It's fine to do this on a box (art3), because it's just a box., but there's nothing you can do with this, you'll have a tough time getting it to look right if you squash it, this, just use the original disc art, it's the best you will get.
mikty Posted August 29, 2017 Author Posted August 29, 2017 ok thanks, but lots of theme using the spin on discs artwork seems fine on youtube videos. they must be all in 4:3 theme if not, I don't know how they proceed. regards
sparton Posted August 31, 2017 Posted August 31, 2017 I'm pretty sure they are just using the 4:3 ones, that's what I am using here on a 16:9 themne
SupraKarma Posted August 31, 2017 Posted August 31, 2017 @sparton can you point me to where you got those Playstation Discs from?
sparton Posted August 31, 2017 Posted August 31, 2017 1 hour ago, SupraKarma said: @sparton can you point me to where you got those Playstation Discs from? You caught me in the middle of doing some hs work here you go:https://drive.google.com/file/d/0B3Bv5lO_Zvm_M0hRQUNRaE9SdXc/view?usp=sharing
mikty Posted September 1, 2017 Author Posted September 1, 2017 ok thanks but it seem a bit flattened. I will do with this thanks
