mrracer Posted October 23, 2017 Posted October 23, 2017 Hello, I have an issue I cannot find an answer to and hoping someone can help. I am running HyperSpin 1.3.2.0 and HyperLaunch and when I go into Favorites it freezes HyperSpin and I am unable to get any feedback from my arcade console (slikstik). It was working perfectly and without issue until this past weekend. If I choose a game from the main menu it works just fine; but the moment I choose Favorites it freezes and locks up. Your help is much appreciated, thank you! I've loaded the log files HyperLaunchHQ.log log.txt
Metalzoic Posted October 24, 2017 Posted October 24, 2017 It was working fine? How far back was the last time you used that feature? Did your Windows update recently? And if so is it waiting for you to restart windows to apply the update? If so that always causes weird behavior until you do an actual restart (not power cycle)
mrracer Posted October 24, 2017 Author Posted October 24, 2017 11 hours ago, Metalzoic said: It was working fine? How far back was the last time you used that feature? Did your Windows update recently? And if so is it waiting for you to restart windows to apply the update? If so that always causes weird behavior until you do an actual restart (not power cycle) Played on Saturday and Sunday and it was working fine, booted up the following Saturday and it was working and then the Favorites function just freezes. The PC is not connected to the internet and is running Windows 7 it shouldn't have been able to get an update. It did however ask for a windows key apparently it had not been registered (I upgraded to professional a month ago) took care of that. The time-frame for both do go hand in hand and the PC has been powered off and on a couple of time but the issue of the Favorites remains. I'm going to do a restart and see if that fixes solves it as I have only power cycled and post the results back. Thank you!
mrracer Posted October 24, 2017 Author Posted October 24, 2017 Unfortunately restarting did not help, it still freezes. Everything else is working fine but as soon as I press the button I have associated with Favorites, everything Freezes and I am unable to make any selections. Within a game I have selected, if I select Favorites nothing happens.
Metalzoic Posted October 25, 2017 Posted October 25, 2017 Damn. Was hoping that was it. First things I would check would be the favorites database XML to see if something got borked in there, the other thing I'd check would be the favorites artwork and folder naming to make sure it's all correct.
SupraKarma Posted October 25, 2017 Posted October 25, 2017 Might want to try opening all of the artwork to make sure the files aren't corrupted.
adamg Posted October 25, 2017 Posted October 25, 2017 I believe this is artwork related too. I would be willing to bet one of the games you have on your favorits list has corrupted artwork. In my experience it is the wheel artwork 9 out of 10 times.
