jevansoh Posted April 12, 2018 Posted April 12, 2018 Is there ANY other emulator that will work for Atomiswave and/or Naomi besides Demul? Demul is hanging on exit on my system with both of those systems plus I can't get the controls working right. Demul is just not cooperating and I'm wondering if there is anything else at all I can use. Thanks, --J
thcdgaf Posted September 3, 2018 Posted September 3, 2018 Is there ANY other emulator that will work for Atomiswave and/or Naomi besides Demul? Demul is hanging on exit on my system with both of those systems plus I can't get the controls working right. Demul is just not cooperating and I'm wondering if there is anything else at all I can use. Thanks, --JThere are several versions of demul I think 5.8.2 is used but can't confirm it I haven't seen it in a while might updated http://demul.emulation64.comSent from my H710VL using Tapatalk
gigapig Posted September 3, 2018 Posted September 3, 2018 On 12/04/2018 at 9:47 PM, jevansoh said: Is there ANY other emulator that will work for Atomiswave and/or Naomi besides Demul? Demul is hanging on exit on my system with both of those systems plus I can't get the controls working right. Demul is just not cooperating and I'm wondering if there is anything else at all I can use. Thanks, --J Does it hang outside of Hyperspin and Rocketlauncher? If not turn off fade on exit. And the controls are quite straight forward and there XBOX config files for controls if you use one.
thatman84 Posted September 3, 2018 Posted September 3, 2018 The retroarch reicast core not has Atomiswave and Naomi but afaik its not mature enough to replace demul. One to keep an eye on I guess Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
hassen Posted September 7, 2018 Posted September 7, 2018 My demul can't retain the controls, is it normal ?
gigapig Posted September 7, 2018 Posted September 7, 2018 37 minutes ago, hassen said: My demul can't retain the controls, is it normal ? Rocketlauncher has the ability to load controls directly to the Demul ini, so that may be the issue. You should read the module notes on how to load your own or if you use a 360 pad there are config files in our downloads section.
gigapig Posted September 7, 2018 Posted September 7, 2018 6 minutes ago, hassen said: is there a youtube tuto on that plz ? I may have covered it in here.
thatman84 Posted September 7, 2018 Posted September 7, 2018 2 hours ago, hassen said: is there a youtube tuto on that plz ? @ninja2bceen lol Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ninja2bceen Posted September 16, 2018 Posted September 16, 2018 Ha one day I’ll have everything on YouTube. Slowly taking over the world lolSent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
rastan Posted September 20, 2018 Posted September 20, 2018 I can say this for a fact at least for me.. I had to try a few different versions of that emulator before I got one that would work. these things are trial and error.... what works for someone may not work for you.. but when that emulator works it works. the controls on that emulator seem like some of the easiest to setup.
