TTX help
thenoob
Hello
searched on here to find the problem and I can’t, but confused.
as my pic says , RL is telling me it can’t find said XML
I’m not new to this. My XML is sitting in Hyperspin/databases/taito type X/taito type x.xml
from the prompt I’m given, it looks like RL is looking at the wrong place for the XML?
i looked at the file structure where it’s looking for it, inside the rocketlauncherUI/databases folder , and there’s nothing there but a Systems.xml, no xml’s for any of the 30 other systems I have already setup.
what am I doing wrong and do I need to redirect RL where it’s looking for the XML?
thanks!!
I will add
all the games in the XML file in the proper database folder are coming up on the game where. Inside HS so I don’t know why I’m getting this prompt, something in the INI?
And a second add-
   Inside RL / taito type X / edit global module settings,
  it’s missing games from the XML file in the game  list it loads for me , seems like somethings not communicating properly?
That suggests that HyperSpin is not your active and default frontend or you have not set Hyperspin as the default plugin.
How would i find that out
and fix it? My system runs fine with every other arcade/consoles I have put on my hyperspin setup.
Sorry you said you weren't new to this so I thought you may know.
You will find those in RockLauncherUI, if you don't know where then I will get you some screen shots.
I am not sure exactly whats going on with your setup but the path in that image looks... curious. You have RL inside the HS folder. It is typically setup in its own folder these days as it is no longer part of HS. Also you have HS inside a folder called "new volume"??? Not necessarily system breaking, just odd.
Anyway, you can add any games in the xml into the module list and then specify the exe and appwaitexe and they should work.
I just copied and pasted the database contents from its usual place to where it was looking and things are back to working, except ttx, it’s a confusing one, I’ll keep plugging away. I’ve managed to get a few games successfully launched, but things like Raiden Iv flip the screen and other weird stuff.
funny tho , when I posted that original post, said everything was working fine, come to find out it wasn’t, now that I’ve moved that database folder, it’s back? Lol weird.
  • 2 months later...
