Replay knocker substitute
I can get a knocker in for you when you order if you're stuck...$35CAN with an order of boards/equipment. Wherever you order from, make sure that you get a knocker with a 26-1200 coil on it for 30v operation. The 800 series coils are 50v operation and you will need a 50v power supply
I know so much about so little that I could teach you everything there is to know about nothing....
The one I have has "g-23" "750" on the side, whatever that means. I tried the 12v power line from an old psu I use for testing purposes and it fired albeit obviously not as powerful as it should do.
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
yeah, that's a 48v 10A coil. At 12v it's only pulling around 2.6A. It needs around 3 - 4 times the power to be effective. Just get a 26-1200 coil with a diode and replace the coil in the assembly and you'll be happy at 30v
That's the one, put a diode on it.
Lol, I know as much about electrics and soldering as I do about nuclear physics, that's why I ordered your zero effort boards :)
I may still be ordering that knocker assy yet :)
