Loading Screen/Splash Screen with the Old Hyperspin System! How i can add this???
newer
Hallo everybody
I will aks you how i can add in the Old Hyperspin 1.2 Setup Loading Screens or Splashscreens...
Maybe drmoney can help me.. a Friend of mine told me that.
Many thanks for Infos...
Greetings to all Hyperspin Fans in the World
You will need RocketLauncher, plain and simple. It's called the fade feature in hyperlaunchHQ. This does not mean you need to mess with hyperspin and it's settings, just hyperlaunch. You will probably need to update the emulators as well if you decide to update hyperlaunch.
See GHutch92's comment above.
Thanks,
Ron
I dont use RocketLauncher..because i have to setup all my Emulators again..
I serach for a other Way to add Loading Screens....
There is a way of corse....
Then code it yourself like I told you in your other thread. Don't expect anyone to help you with it since anything other than RL is not supported anymore.
Make a backup of your setup and go for a brand new install with RL. It's so much quicker and easier to setup and it's currently supported.
Okay Zerojay and HazzardActual you Guys are right.... I have to go this Way..
Right Now i make a Backup of my Old Setup and ill make a complete New Install.
Thanks to the Guys who want help me and of Corse thanks to Brolly......for his nice Words....
I had the same thing happen to me when I was making my bartop touchscreen. I found a program called Windowed Boarderless Gaming (google it) in the Steam forums. It essentially makes the game run in windowed mode but looks like it's full screen. That solved my problem. It was a little weird setting it up but well worth it. Make sure you run it at the same resolution as you desktop or the game will not fill the screen. Also, if you have any of the Bejeweled games, it helps if you turn off "Flicks" in the Pen and Touch section of your Control Panel (I'm just assuming you have Windows 7). It seems to interfere with a smooth swiping motion and makes it aggravating to play those games. Hope this helps.
Haha yes the wrong one...
Thanks anyway and take a rest... Nice Time from Germany to you...
