dustind900 Posted December 6, 2010 Posted December 6, 2010 Ok it took me forever to figure this out. Couldn't find much in the forums. In my opinion the easiest way to use xpadder is to place the xpadder.exe in the folder of every emulator you want it use it with (not many need it). Make sure xpadder.exe is in the root folder of your emulator. Open each xpadder.exe and create profiles that match the control settings you want to use for that system. Once you are done with that create a shortcut to xpadder.exe in the same folder. Dont be fooled when you make the shortcut it will show xpadder.exe but the actual file is xpadder.exe.lnk. Rename the file to xpadderExit.lnk Now right click on the shortcut and go to properties. Click the shortcut tab and edit the target to show - "DriveLetter:\Hyperspin\Emulators\Atari Jaguar\Project Tempest 0.95\Xpadder.exe" /C. (whatever path you use) The "" and the /C are necessary. Click apply then ok. Now you need to edit your Hyperlaunch.ahk. Right click and open HyperLaunch.ahk with notepad or notepad++ either will work. Here is an example of what it should look like - ;**********************************ATARI JAGUAR*********************************** else if (systemName = "Atari Jaguar" && executable = "PT.exe") { hideDesktop() Hotkey, %exitEmulatorKey%, CloseProcess Run, "%EmuPath%%Executable%",,Hide UseErrorLevel Run, "%EmuPath%Xpadder.exe" DetectHiddenWindows, on sleep, 500 WinActivate, Project Tempest WinWait, Project Tempest, Send, {ALTDOWN}{ALTUP}fo WinWait, Open ROM File, IfWinNotActive, Open ROM File, , WinActivate, Open ROM File, WinWaitActive, Open ROM File, sleep, 500 clipboard= clipboard=%romPath%%romName%%romExtension% ClipWait Sleep,100 Send,^v Sleep,100 send, {ENTER} WinWait, Project Tempest, IfWinNotActive, Project Tempest, , WinActivate, Project Tempest, WinWaitActive, Project Tempest, Process, WaitClose, PT.exe Run, "%EmuPath%XpadderExit.lnk" WinActivate, HyperSpin } Put this line directly under the line that launches your emulator - Run, "%EmuPath%Xpadder.exe" Put this line under the line that closes your emulator - Run, "%EmuPath%XpadderExit.lnk" And it usually helps to add - WinActivate, HyperSpin - to the end Just trying to do - Process, Close, xpadder.exe - wont work because it doesnt close xpadder properly. Last thing is to save the hyperlaunch.ahk then right click on it and compile (only works with AutoHotkey installed). Well i know this is probably all jumbled (i was never good at writing) but if you look at the example and follow what i said it should work perfect. Make sure to do this individually with all emulators you want to use xpadder with
horseyhorsey Posted February 6, 2012 Posted February 6, 2012 Nice guide. Do you have this working for latest? I'm having trouble with exiting. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
exoscoriae Posted February 6, 2012 Posted February 6, 2012 errrr, why not just one xpadder profile across the board for all emulators, and have xpadder boot with with windows? That is what I'm doing and I have no problem at all.
horseyhorsey Posted February 6, 2012 Posted February 6, 2012 lol errrrrr because I want to run just one emu with it. In case you didn't know his script runs xpadder and exits when you exit emulation back to hyperspin. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
baddeolv Posted February 6, 2012 Posted February 6, 2012 lol errrrrr because I want to run just one emu with it. What would it matter? just don't pick up the controller...this script seems pretty redundant. i use xpadder for 3 emus only, the rest of my emus run off the arcade control panel. xpadder starts with windows and i never even know its there, why would you need to keep opening it and exiting it? Instagram : baddeolv Facebook : Brian Addeo
horseyhorsey Posted February 6, 2012 Posted February 6, 2012 Instead of copying exe to every folder create xpadderprofiles so it loads blank on exit. Run, "%EmuPath%profile1.xpadderprofile" Run, "%EmuPath%Blank.xpadderprofile" works for me , cheers Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
sparky1821 Posted February 7, 2012 Posted February 7, 2012 I have a question, I have 29 of my 30 systems running great with xpadder, however, I found out ssf.exe for saturn you cannot change the keyboard default buttons for ssf..from what I read, if this true...how can I incorporate an independent xpadder profile that is setup just for ssf? is this possible?, or do I need to change the other 29 systems to just match the un fudgable ssf default keys and say F it? Please let me know someone if you have any ideas
exoscoriae Posted February 7, 2012 Posted February 7, 2012 horseyhorsey - you are making it harder then it has to be. have fun with that. sparky1821 - my version of SSF has a redefine controls option right in the menu. SSF 0.12 beta R3 was released Jan 12th and works with the hyperlaunch 2.0 ssf module.
djvj Posted February 7, 2012 Posted February 7, 2012 If you guys are able to make use of xpadder w/o it being incorporated into hyperlaunch itself, what good would it do if it was? How would that make your life easier? "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
Hypnoziz Posted February 7, 2012 Posted February 7, 2012 If you guys are able to make use of xpadder w/o it being incorporated into hyperlaunch itself, what good would it do if it was? How would that make your life easier? The only time I've needed to incorporate Xpadder in my modules is when I need to switch profiles on the fly. Even then, you don't really NEED to switch profiles. I was just doing it the lazy way because I didn't want to remap my buttons since some weren't compatible layouts for certain emulators. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
blur Posted February 7, 2012 Posted February 7, 2012 you can switch profiles without scripting you just program xpadder - when one exe is active use one profile, otherwise use other profile My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
djvj Posted February 7, 2012 Posted February 7, 2012 So basically those who asked to incorporate xpadder into hyperlaunch just don't understand how to use xpadder or too lazy to set it up? I think there were the few cases where someone wants different profiles for the same emulator, which might be a different story. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
Hypnoziz Posted February 7, 2012 Posted February 7, 2012 Chill djvj! Chill! A lot of people come here with questions and don't know every workaround. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
horseyhorsey Posted February 7, 2012 Posted February 7, 2012 horseyhorsey - you are making it harder then it has to be. have fun with that. Sorry mate I dunno what you're on about or what your problem is with how I go about my config. Even if I want to just run one emulator with xpadder all I have to do is create mapping in the emus directory with a blank profile and add them 2 lines of code into whatever the emulator ahk is. When "x" emulator opens mapping it defaults to blank mapping on exit. Which takes all of a couple of minutes. How hard is that? Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
blur Posted February 7, 2012 Posted February 7, 2012 So basically those who asked to incorporate xpadder into hyperlaunch just don't understand how to use xpadder or too lazy to set it up?I think there were the few cases where someone wants different profiles for the same emulator, which might be a different story. yup, that could be a good reason to write it in ahk - for example spectrum games - when every game has different keys for me going strictly to ahk and loading and unloading xpadder with each emu is not even an option - cause i need it in hyperspin menus also i have 4 gamepads and they are all mapped to up and down arrows for scrolling through games - hyperspin config supports only 2 gamepads, and even on that two for some reason pad buttons don't work for up and down My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
horseyhorsey Posted February 7, 2012 Posted February 7, 2012 yup, that could be a good reason to write it in ahk - for example spectrum games - when every game has different keys Pretty much , you got it. Speccy , Amstrad, Atari ST , Vic20 , Amiga & Pinball. My version of xpadder doesn't seem to have any option to do that is why I havn't seen that, but does that way even know when you've finished with said profile? Exit emulator back into hyperspin and xpadder knows i've closed it? Either way this is more than good enough for me. For not only the fact my mappings are stored inside the emus directory rather than say my documents and if I happen to switch comp/system , saves alot of grief. Easier to migrate. for me going strictly to ahk and loading and unloading xpadder with each emu is not even an option - cause i need it in hyperspin menus also Well you have your hyperspin profile as default on loading windows. Exit emu loads that default. Doesn't matter though I wasn't even trying to say whats better or whats not. It's a personal preference and I'm happy with what I have now. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
baddeolv Posted February 7, 2012 Posted February 7, 2012 Chill djvj! Chill!A lot of people come here with questions and don't know every workaround. This isnt a work around, its redundant just setup xpadder as blur and yourself said. This script only makes since to use as a per game method as dj said. For the record, I dont think he was getting very uppity at all, not sure why he needs to chill, I think he is just trying to understand the reason for the script so he could help out Sent from my LS670 using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
rob3d Posted February 7, 2012 Posted February 7, 2012 My reason for incorporating xpadder into the modules is because I use different controllers on my system. A hard wired set of snes controllers and the wireless xbox controllers, mostly. Xpadder recognizes which contoller I have plugged in at the time and runs the appropriate profile. As for using it to control the HS menu, instead of exiting xpadder when an emulator closes I just load a profile with the HSmenu keys bound. Works great and I can swap controllers on the fly. Took 10mins to set up 15 or so systems and its rigged to work with my snes,n64,psx,and xbox controllers and I never have to worry about it. All this might be redundant on a cabinet where the control panel is the only input device. But on my snesPC I use several different controllers and it works seamlessly.
sparky1821 Posted February 7, 2012 Posted February 7, 2012 you can switch profiles without scriptingyou just program xpadder - when one exe is active use one profile, otherwise use other profile Ok cool, it sounds like the solution I need, but how do I do this?, bear with me, I've only been working with xpadder for a week or so So I guess what I'm saying is...my "profile 2" on xpadder is specific to ssf...how do I get that profile to fire up right when ssf launches? Thanks
rob3d Posted February 8, 2012 Posted February 8, 2012 In the xpadder settings there's an option called autoprofile. Choose your profile then assign an exe to "watch". Every time you launch the selected exe that profile will be loaded. If u need xpadder to revert to another profile on exit then u can just add that to your .ahk right underneath the code that exits your emulator. edit: Just noticed it looks like you can just choose a default profile that xpadder will revert to once you close the exe. hope that helps
horseyhorsey Posted February 8, 2012 Posted February 8, 2012 I don't have a version with that in but it doesn't matter now. It would of been easier for someone to mention it in the first place instead of asking questions and let me try to work a way around it. Seems to be how it works around here. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
djvj Posted February 8, 2012 Posted February 8, 2012 That's typically how you troubleshoot things horsey. In order to get help properly, the person helping you has to know exactly what you are doing and what you are trying to do. If you want erroneous advice, then you have a better chance of getting it when someone who is helping you who didn't ask many questions before giving said advice. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
exoscoriae Posted February 8, 2012 Posted February 8, 2012 It would of been easier for someone to mention it in the first place instead of asking questions and let me try to work a way around it. Seems to be how it works around here. When I asked why you weren't using a universal profile it was because I was suggesting it might be easier, not criticizing your method. That is considered help. Instead you responded like an ass. So you get what you give.
imsospiraleyes Posted September 21, 2013 Posted September 21, 2013 What would it matter? just don't pick up the controller...this script seems pretty redundant. i use xpadder for 3 emus only, the rest of my emus run off the arcade control panel. xpadder starts with windows and i never even know its there, why would you need to keep opening it and exiting it? Have you thought about what would happen if you configured it to control the stylus of DeSmuME?
showstopper Posted January 14, 2014 Posted January 14, 2014 Hey can anyone help me with this please? So i want to use xpadder (with 360 controller). I have setup a Hyperspin profile which works fine. I have also created a mame profile that, if i edit in HLHQ has all my buttons mapped out correctly (it also tests fine). However when i load mame from HS it isnt loading my mame xpadder profile. If i do a button config mame is just seeing my joystick as a joystick and not as xpadder. If i exit mame, my programmed escape key still works, however if i map a key in mame it is not the same as xpadder. For instance button A on controller is set to keyboard Return. So in mame i would expect button A to come up as Return, but it comes up as Joy Button 1 (or whatever number). I know a lot of people like to use one default xpadder profile but i would like individual profiles as i would like to map the mouse for amiga emulation. Any help please? How to update HyperLaunch
