fmetz374 Posted September 20, 2018 Posted September 20, 2018 I apologize in advance if this topic has already been covered in previous posts, but I am hoping to retain the ability to exit to the Windows Desktop when needed, but want this mapped to a separate and hidden button so players can't access this. (I don't want players to muck with my Windows and only want them inside the Hyperspin front end). I do not follow how to go back in the Hyperspin wheel to choose another emulator without hitting the same button again and exiting to Windows. Is there a way to back out of one HyperSpin wheel to choose another emulator, yet not exit to Windows if the same button were pushed again? I realize you can disable the exit feature of HyperSpin, but this then means when I actually do need to exit to the Windows Desktop, I would need to perform a CTRL-ALT-DEL to pull up the task manager and kill the hyperspin process. I'm sure this is a very simple concept that I'm just failing to grasp.
Spawk Posted September 21, 2018 Posted September 21, 2018 Alt+f4 will kill almost any windows app. This is very easy to do if you use joytokey... not sure about ipac or anything though.Sent from my SM-A520W using Tapatalk
dark13 Posted September 21, 2018 Posted September 21, 2018 Buy a thing like this as it will be handy https://www.amazon.it/Tastiera-Wireless-Portatile-Ricaricabile-Raspberry/dp/B01N5PZ7R3 (something that works with windows). Haven't tested with 10 but if you shell hyperspin from group policies you can use CRTL+ALT+DEL, open the task manager and run "explorer.exe" to load the windows GUI Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
fmetz374 Posted September 24, 2018 Author Posted September 24, 2018 Both great suggestions! Thank you!
Bungles Posted September 25, 2018 Posted September 25, 2018 Depending on how far you want to go with it. I use an application called Rainmeter to add a launcher ontop of my Hyperspin to run other things. However you could use it to run a script to taskkill Hyperspin on a password entry or something. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
