PiperCalls Posted August 29, 2019 Posted August 29, 2019 I have several of the obscure platforms working via the RetroArch-Mame Softlist method. One has me stumped though...Bally Astrocade. I have it set up exactly like the others, with confirmed working BIOS & ROM. I can launch into Bally Astrocade with no problem...but whenI do then it is only showing the 4 built-in games and not the game/rom that I actually launched. They way it is supposed to work is when you first boot in, it shows the 4 built-in games AND the game you launched and you select what you want to play. I have the exact same setup on my PC and it works like it is supposed to. Anyone that has this setup and working, help would be appreciated. Thanks...Piper
rambo32 Posted August 30, 2019 Posted August 30, 2019 I will get that information for you shortly. I have most of these old ones setup and just trying for the first time today RCA Studios 2 and Bandai 8000, so far I haven’t had any success
rambo32 Posted August 30, 2019 Posted August 30, 2019 So finally had a chance to have a look. All my roms are zipped up in a folder named “astrocde” in my system folder in retro arch, if I unzip the roms they are in bin format. In my bios directory I have both an astrocde.zip and a astro.bin, not sure which one actually does the trick but I can confirm Astrocade is up and running on the shield tv. After trying some of these old systems out today it seems as if something has changed with the controller support, buttons no longer seem to be configured correctly
PiperCalls Posted August 30, 2019 Author Posted August 30, 2019 Hi rambo32, thanks for offering assistance. How you have it setup is interesting. The way I have all the other softlist systems setup is to have a softlist rom folder (in this case astrocde) in my roms folder with all the game roms and the bios rom zipped in it. So I have [roms folder]/astrocde/ with all my game roms and the astrocde.zip bios file but I only get the 4 built-in games when I launch any game rom. So I tried what you have and changed my setup to... [retroarch system folder]/astrocde/ and put a game rom (in this case astrobat.zip) in there and then in [retroarch bios folder] I put astrocde.zip and astro.bin in it but, I get the same results...only list the 4 built-in games when I launch the game rom. I know the astrocde.zip bios and the astrobat.zip game rom are correct (I've unzipped and checked them vs what the xml says they should be and the game launches fine on my PC with this bios and game rom. I'm thinking it might be some setting in retroarch on my shield tv that is causing the issue, it is like it is not seeing the actual game rom but just launching the bios every time since I only see the 4 built-in games no matter what game rom I launch. Would you might taking a look at for retroarch settings and see what you have? Also, what version of retroarch are you using? Since the new playstore version of retroarch has the auto-detect and switches to 64-bit on my shield tv, I can't get the mame git core so I went and got the retroarch 32 from git and am using that on my shield tv for softlist systems. Thanks for any help...Piper
thatman84 Posted August 30, 2019 Posted August 30, 2019 Have you got boot to bios option on? Quick Menu->Core Options. I dont have astrocade setup anymore but iirc it booted to games from Hyperspin. To access the in-built games i had to duplicate some games as additional entries and set a game option override with boot to bios turned on. Something like that anyway Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
PiperCalls Posted August 30, 2019 Author Posted August 30, 2019 Hi thatman84, I checked and boot to bios option was turned off in core options. I turned it on and launched the game but got the same results (4 built-in games). I enabled verbose logging and got this... Starting game:/storage/EC34609334606316/NVIDIA_SHIELD/Bally Astrocade/astrocde/astrobat.zip Path extraction result: File name=/storage/EC34609334606316/NVIDIA_SHIELD/Bally Astrocade/astrocde/astrobat.zip Path extraction result: Game name=astrobat Path extraction result: System name=astrocde Path extraction result: Game path=/storage/EC34609334606316/NVIDIA_SHIELD/Bally Astrocade/astrocde Path extraction result: Parent path=/storage/EC34609334606316/NVIDIA_SHIELD/Bally Astrocade Searching for driver astrobat Driver astrobat not found -1 Driver not found astrobat Searching for driver astrocde System type: CONSOLE Game name: astrocde, Game description: Bally Professional Arcade Creating frontend for game: astrobat Softlists: 1 I'm not a mame/retroarch expert but it almost looks like it is trying to run astrobat.zip and then says "I don't know what to do with this" and then it falls back and runs astrocde.zip (bios file) which would expain why it only shows the 4 built-in games...this one is frustrating. Thanks for any help...Piper
thatman84 Posted August 30, 2019 Posted August 30, 2019 It does def sounds like it’s trying to launch astrobat. I have not done much logging on software list consoles. just to confirm the basics, Roms match hash file and hash file and romset are from similar versions? romset and hash file are working with mame on RA I believe you said? your Hyperspin xml matches your romset? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted August 30, 2019 Posted August 30, 2019 Did a little testing on my phone and all seems to be working correctly when launching games direct in RA. I can only suggest you make sure the hash xml is in retroarch/system/mame/hash you have no overrides or game-option-overrides messing it up Or no mame or astrocde.ini/mame.ini files confusing things if read configurations option is turned on Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
rambo32 Posted August 31, 2019 Posted August 31, 2019 Sorry but thatman84 pretty has it covered, can really add anymore
TheAck Posted September 21, 2019 Posted September 21, 2019 I had tons of problems with Bally Astrocade, but finally got it working. My only real advice is to make sure the astrocde.xml file is correct. Mine was corrupted. I cleaned out the hash directory completely and pulled the latest from github and that resolved the issue. The mame core is so frustrating. Some systems work immediately... and it seems like they work even with questionable rom names... others you fight and fight with. I'm trying to get the Archimedes emulation to work now. It seems to ignore the hash file. Good luck.
rambo32 Posted September 21, 2019 Posted September 21, 2019 Great news, these mame systems can be challenging.Update to my posts earlier, i do now have RCA studio 2 and Bandai 8000 running, just a bit if tinkering
TheAck Posted September 21, 2019 Posted September 21, 2019 16 hours ago, rambo32 said: Great news, these mame systems can be challenging.Update to my posts earlier, i do now have RCA studio 2 and Bandai 8000 running, just a bit if tinkering How is the Studio 2 working for you? I got it to run, but the games were distorted. I'm looking at Emma 02 now for them.
rambo32 Posted September 21, 2019 Posted September 21, 2019 You need a keyboard and hit f3 and then q
sanchezmike01 Posted September 25, 2019 Posted September 25, 2019 I havent tried studio2 but I got many many mess systems up and running...the hardest were the old russian computers and basically I had to either watch videos on the actual games on a real pc or try 2 download instruction manuals for the games...basically did that to configure the buttons ...that's basically what u gotta do unless u already know the keys
