fishman Posted September 9, 2021 Posted September 9, 2021 So is there any themes out there or can the theme creator make a theme for sega genesis where the box art flows across the bottom of the screen like cover flow? Here is a image from kodi with movies, and i want to do this with games!
rexryan Posted September 9, 2021 Posted September 9, 2021 8 hours ago, fishman said: So is there any themes out there or can the theme creator make a theme for sega genesis where the box art flows across the bottom of the screen like cover flow? Here is a image from kodi with movies, and i want to do this with games! Switch Front End...
BATTLEDONKEY Posted September 10, 2021 Posted September 10, 2021 Somewhat a Kodi looking theme, not sure if its still being worked on or whatnot, have a look through the thread and see. As for the box art I have seen a few PSP themes here on the forums that do exactly that (If I remember correct they used box art in place of the wheel images and they scrolled left and right), if you can find one of those themes it doesnt take much effort to swap out the PSP assets and replace them with Sega Genesis stuff and create the exact theme you want (minus the text info in the upper left corner of your video, no idea how thats done, but maybe you can find some info about it in that nox theme thread I linked) But ya, like I said have a look around for PSP default themes that have the box art scrolling left and right and it can be converted to whatever system you want just by swapping out the art assets in the .zip file for new ones
dark13 Posted September 11, 2021 Posted September 11, 2021 You can't get a real "coverflow" with boxarts changing orientation while scrolling but you can get something like this Settings/YOURSYSTEM.ini change "style" to "horizontal wide" then use boxarts as wheel [code] [wheel] alpha=1 small_alpha=1 style=horizontal wide speed=high pin_center_width=500 horz_wheel_y=620 vert_wheel_position=right y_rotation=center norm_large=170 norm_small=130 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=145 horz_small=135 letter_wheel_x=220 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [/code] Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
