Thanks for the info Floatingyeti. I hadn't updated the mame core yet so I have been able to save it under the version name and change it in the rocketlauncher settings..
I also use different versions of Retroarch in order to "freeze" certain systems in their working state (hopefully).
Have you been able to pinpoint the problem in the retroarch module and/or determine what change caused the problem in the updated mame core ?
I think the solution (for now) is to set RA Options: Resolution = 1280x720.
I have had resolution set to 1920x1080 since I started using RA(MAME) with absolutely no issue.
I just tested a few systems that were crashing on the new core when launched from RocketLauncher.  They seem stable now, but I need to go through every system again today.
I don't know if this is a module issue.  I think this is specifically a version 0.247 issue. I will figure this out and update the compatibility guide today.
Probably the easiest "fix" is waiting for 0.248 but I will do my best to sort this out now.
  • 6 months later...
1 hour ago, Mangusto said:
Well, I had a similar problem solved when I was able to deal with the module, so you are generally correct.
What was the problem and how was it fixed?
Create an account
Register a new account
Sign in
Sign In Now
