Ridu83 Posted August 4, 2014 Posted August 4, 2014 Hello, i am building a bartop out of some old computer parts which are left over from my last pc. It´s like: ASROCK G31M-GS R2.0 2 Gig G-Skill DDR2 800 Intel E8400 3.0GhZ DualCore 700W BeQuiet Geforce 650 GTX I want to play everything till dreamcast. maybe some PC-Games like Mortal Kombat. Do you think this sxstem will be enough or should i replace the 2GB ram with 4 or 8? Thanks for your answers
gigapig Posted August 4, 2014 Posted August 4, 2014 Should be Okay, you may want 4gigs of ram instead of 2, but I would set it up and try it before throwing more money at it. Perhaps put the PC together, get the OS on and then run some emulation on it to be sure.
nofxbam Posted August 6, 2014 Posted August 6, 2014 Hello, i am building a bartop out of some old computer parts which are left over from my last pc.It´s like: ASROCK G31M-GS R2.0 2 Gig G-Skill DDR2 800 Intel E8400 3.0GhZ DualCore 700W BeQuiet Geforce 650 GTX I want to play everything till dreamcast. maybe some PC-Games like Mortal Kombat. Do you think this sxstem will be enough or should i replace the 2GB ram with 4 or 8? Thanks for your answers That's a mirror of my new bartop system I just set up last week! Only thing is I added another 2 gigs of ram. I think it helped with Hyperspin animations but I thought it ran fine before with 2 gigs. I am running MAME, Dreamcast, SNES, NES, Genesis, Game Boy, Atari 2600, N64, and PS1. The 3D games on MAME can be a little rough but when I see problems with processing, I usually look for Dreamcast, N64, or PS1 alternatives since they support graphics cards. I see them run faster and less pixelated. Most of the MAME games I want to play aren't 3D anyways. Good luck with getting Hyperspin set up! For what you're looking to do I think your system will work great. Happy to answer any questions about how particular games or systems perform. EDIT: Put an SSD in there, it's worth it for the quick boot up alone
dark13 Posted August 6, 2014 Posted August 6, 2014 4gb is enough, also because ddr2 basically cost twice as ddr3 these days. 4gb will help with windows gaming. Mortal Kombat Komplete has a big problem: it does not drop frames, if your cpu can't render 60fps it will slow down. My q6600 gtx660 can run it flawlessly but if it's one of the games having problems with only 2 cores it may slow down a bit. Don't expect pcsx2, demul and dolphin being at 100% with every games; some of them will be playable, some won't. Sadly with that motherboard chipset and a 1333hmz cpu I guess you can't overclock, e8400s reach interesting frequencies Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
acidarmitage Posted August 9, 2014 Posted August 9, 2014 this is exactly the setup i put together a few months ago except with a geforce 610, runs pretty much everything awesome but id replace the motherboard... you can't overclock with it and it will frustrate you when a game runs at 98% speed lol "i just need to push it a little...farther.....NOPE"
marloncol Posted August 10, 2014 Posted August 10, 2014 Hello, i am building a bartop out of some old computer parts which are left over from my last pc.It´s like: ASROCK G31M-GS R2.0 2 Gig G-Skill DDR2 800 Intel E8400 3.0GhZ DualCore 700W BeQuiet Geforce 650 GTX I want to play everything till dreamcast. maybe plr some PC-Games like Mortal Kombat. Do you think this sxstem will be enough or should i replace the 2GB ram with 4 or 8? Thanks for your answers 4 GB ram is a must, and everything else looks fine to me.
albert_c Posted August 10, 2014 Posted August 10, 2014 Upgrade to an absolute minimum of 4GB of RAM. Also, since this a bartop you will be running off of an LCD display. As such, you should enable HLSL settings which replicate the look of playing off an old arcade CRT. HLSL looks makes those games truly come alive again and I recommend them to be switched on. But until the guys on the MAME Dev Team optimize that code, we will all experience some issues with HLSL settings turned on. Here are the settings borrowed from another person on the Shmump forum that I feel are the best for HLSL: http://wiki.arcadeotaku.com/w/File:Mame_hlsl_jezze_cools.zip When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
Ridu83 Posted September 17, 2014 Author Posted September 17, 2014 Sorry for beeing late but thank you guys
