treepop Posted September 9, 2011 Posted September 9, 2011 When I launch mame it gives me a list of every mame game ever. How do I make it show only games I own? Thanks
level42 Posted September 9, 2011 Posted September 9, 2011 You have to remove the game entry from your, for example, Nintendo 64.xml Located in your DATABASE folder. I suggest just using HyperList to create a new XML file for you based on your list of roms, that way you will have only working games in HyperSpin. My HS Progress: MAME: 100% Daphne:100% Turbo Grafx16: 100% Neo Geo: 100% Atari2600: 100% Atari5200:100% Atari7800: 100% Atari Lynx: 100% NES: 100% SNES: 100% GameBoy: 100% N64: 100% SMS: 100% Genesis: 100% Sega CD: 100% Dreamcast: 100% Sega 32X: 100%
blur Posted September 10, 2011 Posted September 10, 2011 do dir /b in your roms directory and you will get a list of roms you have put this list n favorites.txt for your wheel choose option start on favorites for this wheel then you'l have only games you have My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
iblemz Posted September 10, 2011 Posted September 10, 2011 do dir /b in your roms directory sorry for the ignorance. but what is dir/db ? thanks
iblemz Posted September 10, 2011 Posted September 10, 2011 do dir /b in your roms directory sorry for the ignorance. but what is dir/b ? thanks
Wildbill Posted September 10, 2011 Posted September 10, 2011 where is the download for hyperlist?. Thanks
SubZero Posted September 10, 2011 Posted September 10, 2011 just download the themes for the games you have, then go to HyperHQ and set themes only at your MAME wheel.
treepop Posted September 12, 2011 Author Posted September 12, 2011 Okay I got it. Thanks guys. I used the post on the main page about creating a rom list and updating the xml. Thanks for the feedback!
Lashek Posted September 12, 2011 Posted September 12, 2011 where is the download for hyperlist?. Thanks There is no download. There is a link at the top of the page. -Lashek I invented HyperList! http://hyperlist.hyperspin-fe.com Please do not ask me support questions about HyperList, I am no longer a part of the team/project.
tommymsw Posted January 30, 2014 Posted January 30, 2014 I don;t know what the deal is. I can never get anything to work the way it should. I also want to make my wheel just have the games I have (something you think EVERYBODY would want) but when I try to make a custom .xml list, the only way I can think of was to export a list of the games I have with using Don's hyperlist generator into a text file. I then copied that list and pasted it into the "create list generator" and it generates me a list with ZERO roms. But if I type them in one at a time EXACTLY as they look when pasted in, it works. Trouble is that I don;t want to type in 200 games! The MUST be an easier way here. There should just be something that you can point to your ROM directory and it only adds THOSE roms to the wheel. Am i wrong?
Dime333 Posted January 30, 2014 Posted January 30, 2014 In the XML generator, I Think you have to go to the bottom of the list and and press backspace until the cursor is behind the last rom in the list. If there is a blank line below the last romname, you will end up with 0 roms in the list. That almost drove me crazy. However, you can run HyperHQ (not hyperlaunchHQ) and set your rompath and extension. This way you will be able to check the "roms only" checkbox and that will make HS show only the roms you have.
phongsway Posted October 3, 2014 Posted October 3, 2014 In the XML generator, I Think you have to go to the bottom of the list and and press backspace until the cursor is behind the last rom in the list. If there is a blank line below the last romname, you will end up with 0 roms in the list. That almost drove me crazy. However, you can run HyperHQ (not hyperlaunchHQ) and set your rompath and extension. This way you will be able to check the "roms only" checkbox and that will make HS show only the roms you have. when I do this it wont let me see the list for sega Naomi unless I keep "roms only" unchecked. I cant get it to show working roms only any help?
dougan78 Posted October 3, 2014 Posted October 3, 2014 Do you have the rom path and extensions setup for the system in hyperhq?
Nexus23 Posted October 3, 2014 Posted October 3, 2014 Hi, you can build a custom xml, use "HyperROM2XML". Say HyperROM2XML where your Rom`s are and build a xml from it.
phongsway Posted October 4, 2014 Posted October 4, 2014 Do you have the rom path and extensions setup for the system in hyperhq? yes
