pavlovtiger Posted September 23, 2014 Posted September 23, 2014 Figured I'd ask in a separate thread before giving up on it if nobody has advice. Street Fighter Zero 3 (Japan) doesn't want to run in any of the three SSF versions I've tried, nor the latest build of Yabause, and if anyone here has it functioning on their system I'd love to know how if you'd share that with me. It's a great version of the game and I'd play it if I could. Cheers.
gigapig Posted September 23, 2014 Posted September 23, 2014 I downloaded it and tried it but after the Capcom splash screen vthe screen just goes black.
pavlovtiger Posted September 23, 2014 Author Posted September 23, 2014 Same thing here, on all 4 emulators/versions I tried. It's listed on at least one compatibility list as playable, and a Youtube video stating 11 Alpha R5 SSF is running it, but mine won't.
Styphelus Posted September 23, 2014 Posted September 23, 2014 Same here. The same game is available on Mame, Dreamcast, Playstation and Playstation 2. Why play on the Saturn? It has the worst graphics of all the systems I just listed.
Rick74 Posted September 23, 2014 Posted September 23, 2014 The PSP version is probably the best... IMHO
guyverjay Posted September 23, 2014 Posted September 23, 2014 Game works fine for me, don't forget this game used the ram cart
gigapig Posted September 23, 2014 Posted September 23, 2014 Game works fine for me, don't forget this game used the ram cart Thanks, I'll have to try it. Is there anything we should know about setting the ram up? I've seen it in the options, I assume it creates a file or files somewhere.
guyverjay Posted September 23, 2014 Posted September 23, 2014 Thanks, I'll have to try it. Is there anything we should know about setting the ram up? I've seen it in the options, I assume it creates a file or files somewhere. Nope just choose it in the options and that's it
gigapig Posted September 23, 2014 Posted September 23, 2014 If thats the "Cartridge" set to 4mb, then it's still not working for me. Are you using R3 or R4?
pavlovtiger Posted September 23, 2014 Author Posted September 23, 2014 Again, same for me. SSF's options lets you set the 1 or 4MB RAM cart, I leave it on 4MB but unless I'm meant to actually download a file for the cart then I don't know how to do anything differently.
pavlovtiger Posted September 24, 2014 Author Posted September 24, 2014 Tried two different ones, it's possible those are just not gonna work in SSF for whatever reason. They're the only two I can find, unfortunately.
kyoken Posted September 24, 2014 Posted September 24, 2014 I think you need to use a real Bios, SSF works without Bios but i think SFA3 don´t work if you don´t put a japanese Bios, I´ll try later when i´m at home
guyverjay Posted September 24, 2014 Posted September 24, 2014 Kyoken could be on to something as I do use a Japanese bios
gigapig Posted September 24, 2014 Posted September 24, 2014 Sorry for this being slightly off topic and some of you probably know this already. So I've just had some troubles setting the controls and I usually test them on certain games so I know they work; well this time they didn't. I entered the new controls and test the game but the controls don't work. I then checked out this folder in SSF J:\Roms and Emulators\Emulators\Sega Saturn\SSF_012_beta_R4\Setting\Saturn. There's a bunch of ini files in there relating to games I've run, and each ini has specific settings for that game and also control settings. So if there is an ini file in that folder, SSF will ignore the main SSF.ini and read that instead. Kind of good if you also want per game controls or even tweak the graphics settings etc. I'm not sure what can be set manually, but see below the contents of the ini file. Maybe this can be added to the module? # RADIANT S.G [T-32902G ] CartridgeID="5c" Areacode="1" DataCartridgeEnable="0" DataCartridge="" WideScreen="0" Volume="1.00" VDP1DrawThread="0" VDP1ThreadNumber="1" VDP1ThreadAlwaysRunning="0" VDP1Division="1" VDP2DrawThread="1" VDP2ThreadNumber="11" SoundThread="1" CDBlockThread="0" CDBlockNoWait="0" ScanlineBaseTiming="0" DSPThread="0" DSPThreadAlwaysRunning="0" DSPDynamicRecompile="1" DotClock="2.50" 1BlockClock="80" CheckSlaveSH2IdleLoop="1" SlaveSH2Speed="90" SH2RecompileBlockInstructions="40" SH2RecompileBufferSize="8" SH2RecompileBlockNumber="40000" AlternativeSH2Recompile="0" CheckSpritePriority="0" CheckCyclePattern="1" VDP2RAMRevisionAccess="1" VDP2RAMWriteTiming="0" VDP2RAMWriteTimingBufferSize="24" MemoryAccessWait="0" SH2Cache="0" EnableInstructionCache="0" BusWait="0" BusWaitClock="1" SH2DMARealTransfer="0" SCUDMADelayInterrupt="0" CDTrackIndex="0" BranchInstructionClock="0" MeshTranslucent="0" Deinterlace="0" PortFlag0="0" PortFlag1="0" PadType0_0="0" PadType0_1="5" PadType0_2="5" PadType0_3="5" PadType0_4="5" PadType0_5="5" PadType1_0="0" PadType1_1="5" PadType1_2="5" PadType1_3="5" PadType1_4="5" PadType1_5="5" VariableRapid0_0="0" VariableRapid0_1="0" VariableRapid0_2="0" VariableRapid0_3="0" VariableRapid0_4="0" VariableRapid0_5="0" VariableRapid1_0="0" VariableRapid1_1="0" VariableRapid1_2="0" VariableRapid1_3="0" VariableRapid1_4="0" VariableRapid1_5="0" EnableRapid="0" Pad0_0_0="1/33025/1/33026/1/32769/1/32770/1/0/1/256/1/512/1/768/1/2048/1/2304/1/1024/1/1280/1/1792/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_2_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_2_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_2_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_2_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_3_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_3_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_3_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_3_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_4_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_4_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_4_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_4_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_5_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_5_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_5_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad0_5_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_0_0="1/98561/1/98562/1/98305/1/98306/1/65536/1/65792/1/66048/1/66304/1/67584/1/67840/1/66560/1/66816/1/67328/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_2_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_2_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_2_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_2_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_3_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_3_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_3_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_3_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_4_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_4_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_4_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_4_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_5_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_5_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_5_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Pad1_5_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_4="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid0_5="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_0="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_1="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_2="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_3="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_4="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0" Rapid1_5="0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0"
kyoken Posted September 24, 2014 Posted September 24, 2014 Kyoken could be on to something as I do use a Japanese bios Yes I think it´s solved with this. Gigapig, I just redefine keys in Options, then I set my saturn Xpadder profile, and it works perfect in all games.
pavlovtiger Posted September 26, 2014 Author Posted September 26, 2014 I tried the Japanese BIOS too, still nothing. This hasn't got to do with the ST-V BIOS, has it? I don't -think- SFZ3 was on the ST-V hardware... anyway I've tried all three major BIOS regions and still that annoying black screen after boot up. I hate when something works for other folks and I can't work it out.
gigapig Posted September 26, 2014 Posted September 26, 2014 Well your not alone, perhaps someone who has it working can post some screen shots? Perhaps it's a bad dump I have? I have read that SSF does not require any bios files to run, I'd like to proce that wrong, so if anyone knows of any other games that require the bios please let me know. I tried the ST-V BIOS as well.
