Iggy Posted September 24, 2014 Posted September 24, 2014 Interesting read for you artists out there concerning how to achieve perfect rounded corners in photoshop....head to the Rounded Rectangle section so see different methods used and comparison of each: http://www.smashingmagazine.com/2011/02/07/mastering-photoshop-noise-textures-gradients-and-rounded-rectangles/ [sIGPIC][/sIGPIC]Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
dark13 Posted September 24, 2014 Posted September 24, 2014 A little suggestion while working with vector masks that has very little coverage in many tutorials: The biggest flaw in photoshop is you cant' combine 2 vector mask (many knows them as "shapes" ) on 2 separate layers. Well... actually you can combine them and use booleans operator on them. 1- Select layer 1 and click on its shape (vector mask) with selection tool to hilight path and copy it (ctrl+c) . Alternatively you can select every point and copy it (ctrl+c) 2- Select layer 2 and hilight its path with selection tool or select every points if you're working with points. Paste (crtl+v) the previously copied path/points. If you're gonna use boleans operator be sure to have a single path in your vector mask/shape. A vector mask/shape can contain more than a single path in photoshop, to use booleans operator with it (use selection tool) you obviously need to have only 2 path in your vector mask or photoshop will have problems to understand what are you exactly trying to subtract/add/intersecate/etc. To join 2 path in your vector mask select it with selection tools and press "join" on the top panel that will appear when 2 path on the same vector mask are selected (it may be "combine", my PS is in italian). In the same flavour you can ctrl+c/ctrl+v paths from illustrator to photoshop and from photoshop to illustrator and have the very best of the two worlds Ah... there is a way to circumvent crazy pixe per pixel shapes/vector masks in photoshop. If you create a shape that has a line between a single pixel instead of use moving tool (that will move the path per pixel basis) simply use "scale" and align it on pixel's end moving it. Useful when building a single path using multiples shapes Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
THK Posted September 25, 2014 Posted September 25, 2014 You can also combine shape layers, turn the path it into a selection and whilst the selection is there, add a layer mask to the designated layer, done. ..........................back with a vengeance........................
