Mame Compiler 100% Automated
Rain
Are you sure your using the correct Mame version for your computer?
314 members have voted
  1. 1. Are you sure your using the correct Mame version for your computer?
    • Yes
      117
    • No
      62
    • Not sure?
      177
Yay, first build worked great. The app also saw a failed download of the source (due to internet issues atm, ping times during prime time are never good) and redownloaded the file. So your CRC checking is working!
Took 14 mins 27 secs to build.
Biggest complaint is it doesn't save any options. It's annoying having to go through and set all my settings each launch.
Besides, great job!
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • Replies 589
Thanks for the tips, glad it built a Mame version for you! The next update I am adding save options and a more handsome GUI.
That's the point of mameplus, is it not?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Not installing for me?
I click the Setup file & it says install .netframe. I agree to the yes/no then I get Application cannot Be Started. Contact the vendor.
I am running Win7 64bit
RELAX and just have fun!!
Remember, it's all about the games.
You probably need microsoft .NET framework 3.5 or 4.x.
tried installing .NET 4 again from MS, still the same outcome
Rain this seems like a real solution an issue that a lot of people have!!
Thanks so much for this
Going to give this a go also.
I have been able to create my own but this seems a lot quicker than having to go through the guide at Mr Do's site :)
Not to say that his guide isn’t good however it’s just that my memory sucks and I have to go through learning again with each major upgrade :)
Working on the newest version of MyMame now. I think that the name is going to change on this release. Also, I will be rolling back to .NET 3.5 due to some compatibility issues floating around out there.
Just need a compiled MAMEUI32 0.143 (no nag) if someone could upload a link for me?
Ta
Here is a screenshot of the upcoming release of Ultimate Mame Compiler:
This version is still in the building process however it looks very promising as of yet. I will be adding many more options to the initial program as well as some options that were not released in the beta release of MyMame.
The new version is expected to be released in a month or so. I am having to take a little while off for personal reasons, but rest assured I will still be around. Until then, just keep using the old version and reporting any errors that exists - so that they do not show up in the new version.
Thanks guys!
Rain, I just tried a build that failed:
http://pastebin.com/YQTQUBPH
Settings were mame 143u6, new build rule, cpu amd64, quad core, high score/no nag, show in folder.
Same settings and dual core also failed. Was trying to find the best option for my AMD A8-3850 Fusion APU.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Did you check clean build in the extended options tab? From what I am seeing is the source has been corrupted. This is not uncommon with Mame 143u6 (I have not been very pleased with that update as of yet.) I will try to recreate the error over here.
I am rebuilding with your specs will check it again. Looks to me like a header file in the source is a little corrupt.
Tried it again clicking clean build, same thing. Something is up, clean compile is not downloading the source again. I can't compile a 2nd time no matter what options I choose. As soon as I hit compile, I get failures.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
The problem is with the MinGW compiling environment. On the next release that is being dropped like a bad habit. I am converting the program over to another major GNU cross compiler. MinGW has a lot of little quirks that make it very flawed, and with the release of u6 - things have just gotten worse.
A few of my builds failed, so I just opened up My Documents/MyMame/Mamesrc/Archives and deleted 0143 folder and started from scratch and every now and then it would compile without fail. This is a known problem with MinGW, as it confuses the STDOUT/IN procedures needed for clean compiling. Although it is recommended by MameDev I have serious reservations making it available in the next releases.
Long & Skinny, over here 0143u6 compiles without error. Every machine is a little different. But thanks for submitting your bug report! :D
I think you need a button that when clicked, deletes all source files, or something similar.
Is the app trying to patch 143u6 to the 143 source every time? If I run it twice in a row to build the u6 version, it can't patch again, the source was patched already.
After deleting the src folder, it's building clean now.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yeah, it was trying to add a patch to a patch. I am building patch detection into the next release. A global cache cleaner has already been built in for the next release as well as a more comprehensive GNU C++ compiler system that I have modified just for this application.
I think you will be happy with the next release, I have put so much time into it. Have not really gotten any feedback off of this release (except for you) therefore development is going much slower than expected.
Thanks for your suggestions! :D
That's what I'm here for :)
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yep.
Linking mame.exe...
Compile: Compile Complete...
Terminating Build : Build has been terminated.
0 Hours 15 Minutes and 50 Seconds.
Clean Up: Path cannot be the empty string or all whitespace.
I don't think show in folder works, I never get an explorer box showing me the exe.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yeah, I forgot to add the explorer context in that build. But the exe should be at the root. Glad it worked though. I will work on those cache issues.
Sent from my MB508 using Tapatalk
I have decided to go ahead and give the application one major update before I go on my two week vacation. Details will be available soon!
