Buenas, yo he estado usando photoshop tiempo atrás, y no hay color, te recomiendo que uses anímate para las transformaciones de png a swf que requieran cambio de aspecto, por ejemplo de 1080 a 1024 o de 3840 a 1024, o que no lo requieran y simplemente sean 1:1,  vas a notar la diferencia de imagen borrosa a una nitidez increíble,  te va a dar calidad HD
A simple vista parecen iguales, pero agranda la imagen, a ver si ves la de photoshop y anímate, observa las letras del PEGI por ejemplo.
For best quality you should use 1080p image resized into flash but it will take more cpu power,  to do so use PNG_to_SWF_dark13_1080p_exact_scale_BK , it should work also with 4k images as the script specifically resize the image at 1024*768. I never tested but I guess HS will crawl to death with 4k images, flash was created to deal with 1024*768.
If you make an universal theme check cpu usage, there seems to be a bug when rescaled .swf is used inside it, I had HS using 25% cpu power even when a game was launched.
Hey dark, can you expand on this? I don’t quite understand what it is that causes higher CPU usage.
You didn’t get any replies? I will test the theme you linked on my system. I understand you’re saying that there’s a performance hit but is this when using any of your scripts?
As far as I remember the problem appears in swf rescaled with my script and with swf directly rescaled inside flash/animate cc
Wow, yeah I just tested the theme you posted and even after alt tabbing onto task manager the CPU usage stays at 79% on my system.
So just to be clear, you're saying that using any of your scripts on artwork for a default theme will cause this issue? I'm trying to find any themes currently on my system that have this same problem but haven't found any so far. When I alt tab over to the task manager the CPU usage is high on some but it gradually drops to zero pretty quickly.
This is why I asked people to test 1080p artwork inside a .swf for an universal theme, I didn't run further tests. I noticed the thing as I was preparing that theme for a weak laptop and I noticed a serious performance hit. Usually cpu usage can be very high with HS focused but cpu usage drops when HS loses focus.
Lo que me estas diciendo, es que yo coja una imagen que tenga descargada de internet y que yo abra esa imagen descargada en Adobe Animate. Una vez dentro de Adobe Animate, que yo reescale esa imagen de 1080 a 1024  y me va a quedar mucha más calidad que si yo esa imagen descargada la meto directamente en Photoshop y la reescalo con Photoshop. ¿ Es eso ?
Si a esa imagen que yo reescalo con Adobe Animate, le aplico despues el Scritp de PNG_to_SWF_dark13_NO_SCALE_NO_SMOOTH, ¿ mejorará aun mas la calidad ?
What you're telling me is that I take an image that has downloaded from the internet and that I open that downloaded image in Adobe Animate. Once inside Adobe Animate, I reescal that image from 1080 to 1024 and I'm going to get a lot more quality than if I put that downloaded image I put it directly into Photoshop and rescue it with Photoshop. Is that it?
If I rescue that image with Adobe Animate, then apply the Scritp of PNG_to_SWF_dark13_NO_SCALE_NO_SMOOTH, will it further improve the quality?
¿Si no te es mucha molestia me podrias decir como redimensionar las imagenes con Adobe Animate? Porque si yo entro y le doy a " Nuevo", desde aquí por ejemplo a "Animacion de Personajes" y creo una escena de trabajo de 1024 x 768.
Le doy a "importar a escenario" . Yo elijo la imagen jpg . Yo solo veo la opcion de poder trabajar la imagen dandole a Modificar / Transformar / Escalar.
Una vez escalada de esta manera yo le doy a Exportar / Exportar Pelicula.
¿ Esta es la manera correcta de hacerlo ? Gracias
If you don't mind, could you tell me how to resize images with Adobe Animate? Because if I go in and hit "New", from here for example to "Character Animation" and create a 1024 x 768 work scene.
I give you to import to stage. I choose the jpg image. I only see the option of being able to work the image giving it to Modify / Transform / Scale.
Once scaled this way I give you export / Export movie.
Is this the right way to do it? Thank You
Edited by vampiresaaa
Correccion porque he descubierto exportar pelicula
Aqui podeis ver las primeras pruebas. Este es el orden en el que esta colocado:
- Guardar el archivo desde Adobe Animate como PNG-24
- Guardar el archivo dándole a exportar desde Adobe Animate como Pelicula
- Guardar el archivo desde Adobe Animate como PNG-24 y aplicarle el Script de NO SCALE Smooth
- Guardar el archivo desde Photoshop como PNG-24 y aplicarle el Script de NO SCALE Smooth
Como se ve, los que guardo desde Photoshop me cambia el tono de color, lo pone mas anaranjado, que realmente me gusta mas, pero no es el color original. Y el que es mas fiel al color y que de mejor calidad se ve sin duda alguna, es el de guardar desde Animate, la he reescalado para que entrase dentro de una pantalla de 1024x768 dándole a Modificar / Transformar / Escalar y luego le he dado a exportar como película que ya lo transforma directamente a swf.
  • 1 year later...
Hello. I need your help.
First of all, thank you for these scripts, I don't understand how to modify them so that they modify my images, I explain trying to make myself understand.
I need for my hypespin theme a box image of 148 x 400 pixels, to which in animate I put a larger image and in properties I tell it not to compress it, it comes out like this
I have tried to modify the scripts without success, because the only one that I was able to get close to was with the script PNG_to_SWF_Zero_Dreams_1920x1080_to_1024x768.jsfl and the size is fine but in the player I see that it is not like the one for animate, I modified these two parameters
bmp_tl.width = 180;
bmp_tl.height = 400;
The batch file works fine, the resulting image has correct measurements, but I don't know how to fit the green canvas to the image.
I've tried all the scripts, but they don't do what I need.
Adapt a larger image to 148 x 400, for my boxes and for CD images I use 200 x 200. Thank you for your comments.
Is it a problem in HS? HS completely ignores stage resolution of the swf,  it simply considered the first and last non empty pixels on y and x for positioning. If you want to use boxarts as wheel you need to center the position of the image,  if i remember correctly if you have a 200x200 image position must be -100 on y and x.
I'll check if I can modify the script later,  cheers.
Thank you very much for your comments.
In HS, it is not a problem, it is positioned correctly in the theme, but it was easy to solve by correcting some parameter that I cannot understand and the batch file would make the images like the manual option that I showed in the first box that fits to the image. I didn't see stage size measurements in the scripts...I don't understand if it's 200 x 200 then the position is -100 on y and x.
png2swf();
function png2swf()
    var folderURI = fl.browseForFolderURL("Select a folder.");
    if (folderURI == null) { return; }
    var folderContents = FLfile.listFolder(folderURI);
    var doc = fl.createDocument();
    doc.backgroundColor = '#00FF00';
    var imported = 0;
    for(var i=0; i< folderContents.length; i++){
        var pngURI = folderURI + "/" +folderContents[i];
        if (pngURI.substr(pngURI.length-4) != ".png") continue;
        doc.importFile(pngURI);
        // get item
        var bmp_lib = doc.library.items[imported];
        bmp_lib.compressionType = "lossless";
                bmp_lib.allowSmoothing = true;
        var bmp_tl = fl.getDocumentDOM().getTimeline().layers[0].frames[0].elements[0];
// Scale from 1080p to 1024*768 and apply 16:9 ratio correction
                bmp_tl.width = 1024;
                bmp_tl.height = 768;
                bmp_tl.x = 0 ;
                bmp_tl.y = 0 ;
// set doc size
        doc.width = Math.floor(bmp_tl.width);
        doc.height = Math.floor(bmp_tl.height);
// export
        var swfURI = pngURI.substr(0,pngURI.lastIndexOf(".")+1)+"swf";
        doc.exportSWF(swfURI, true );
        // remove previous from timeline
        doc.selectAll();
        doc.deleteSelection();
        // increase imported count
        imported++;
    doc.close(false);
    alert(imported + " files created.");
Change set doc size for the stage and bmp_tl height and width
If you use a swf the artwork must be centered, aligned at the middle of the image on y=1 and x=1, so something like this if the image is 200x200
                bmp_tl.x = 200/2-200 ;
                bmp_tl.y = 200/2-200 ;
12 hours ago, dark13 said:
png2swf();
function png2swf()
    var imported = 0;
        // get item
                bmp_tl.x = 0 ;
                bmp_tl.y = 0 ;
// set doc size
// export
        doc.selectAll();
        imported++;
    doc.close(false);
BRUTAL, thank you very much dark13.
This worked for me:
                bmp_tl.width = 200;
                bmp_tl.height = 200;
                bmp_tl.x = 200/1-200 ;
                bmp_tl.y = 200/1-200 ;
👏👏👏. Thanks, teacher.
This is needed only when you want to use a swf as wheel image, for Artworks and Background layer just use :)
bmp_tl.x = 0 ;
bmp_tl.y = 0 ;
